GBRf Class 99 - 30 locomotives now ordered
Covshire1
4 Jan 2018
There is a 0L47 1830 Leicester L.I.P. to Hams Hall Gbrf in for Monday afternoon, so a good chance that 4L47 will have a flake in it somewhere.
Peter Sarf
Croydon
Tanks for that, the next indication could be if an extra STP 4M47 gets added to the schedules for an identical start time on Tuesday 23/06/2026.
Last time (Wednesday 17/06/2026) the normal 4M47 (ie non-STP) got used for a while into the journey and was then cancelled and the STP 4M47 got used - that threw me off somewhat.
99009
4 Apr 2025
Chesterfield
The current locations and status of 99's as of 05:00 Monday 22nd June 2026 is as follows:
99001 - 161 confirmed mainline workings - Currently at Peterborough yard since 15/06/26 arriving on 0Z12.
99002 - 132 confirmed mainline workings - Currently at Peterborough yard since 19/06/26 arriving on 0Z79.
99003 - 57 confirmed mainline workings - Currently at Leicester depot since 19/06/26 arriving on 0Z78.
99004 - 65 confirmed mainline workings - Currently at Old Dalby since 17/06/26 arriving on 6M12.
99005 - 70 confirmed mainline workings - Currently at Old Dalby since 17/06/26 arriving on 6M12.
99006 - 45 confirmed mainline workings - Currently at Old Dalby since 08/06/26 arriving on 0Z22.
99007 - 22 confirmed mainline workings - Currently at Old Dalby since 08/06/26 arriving on 0Z22.
99008 - 28 confirmed mainline workings - Currently at Leicester depot since 19/06/26 arriving on 0Z98.
99009 - 19 confirmed mainline workings - Currently at Leicester depot since 19/06/26 arriving on 0Z78.
99010 - 2 confirmed mainline workings - Currently at Peterborough yard since 19/06/26 arriving on 0Z79.
If anyone believes any of this is wrong please let me know.
Assuming all the above remains true, it means one of 99003, 99008 or 99009 will work 0L47 Leicester - Hams Hall this evening.
0L47 Leicester - Hams Hall:
Meanwhile this morning the current Peterborough trio of 99001, 99002 and 99010 are allocated to go to March and collect another set of sand wagons before heading back to Peterborough station and then north to Doncaster.
0Z37 Peterborough - March:
4Z37 March - Peterborough Station:
4D30 Peterborough Station - Doncaster Decoy via the ECML:
99009
4 Apr 2025
Chesterfield
I see the 18.30 path has been activated but do we know which loco or locos please?
If the 0L47 path from Leicester runs it will be either 99003, 99008 or 99009.
However if this VSTP path from Old Dalby runs instead, it will be either 99004, 99005, 99006 or 99007.
0L48 Old Dalby - Hams Hall:
Covshire1
4 Jan 2018
New 4M47 path for Tuesday:
Class15
30 Dec 2021
North London or Mildmay line
172007
2 Jan 2021
West Mids
Bizarre path which seems to be 2 minutes behind and 3 minutes ahead of passenger trains on the North London line?
4M47 late and seems stuck awating a path onto mainline.
Be a good test of the cooling systems on it.
On time now
subria
23 Jul 2014
There are heat restrictions on the North London Line today - everything is very slow and running behind. It eventually wandered through Kensal Rise with 66799 behind around 1422 instead of 1352...
Can only imagine it'd be much cooler inside the 99 cab then the 66!
Unobrow
19 Nov 2024
Manchester
The Sahara is usually much cooler than the cab of a 66!!!!!. How quiet are the flakes?
99009
4 Apr 2025
Chesterfield
Just in case anyone was wanting any 100% confirmation, 4L47 Hams Hall - London Gateway passed Barking just after 05:00 this morning with 66799 leading 99006 and then about 45 containers.
While on 4L47, 99006 became the first 99 to go on the Hillmorton Jn - Hanslope Jn via Roade section of the WCML.
4M47 London Gateway - Hams Hall is also 100% confirmed as 99006+66799+20 containers.
Does anyone know why 4M47 London Gateway - Hams Hall got heavily delayed at Nuneaton please?
Adrian Barr
2 Jul 2020
Doncaster
Not sure exactly, but 4M29 (Felixstowe - Birch Coppice, booked to run round at Hams Hall) was also delayed by around 40 min at Nuneaton around the same time, with the delay shown as "waiting acceptance" to Hams Hall.
That in turn may have resulted in 4M47 waiting at Nuneaton for 4M29 to complete it's run round at Hams Hall
Tobytrain10
2 Feb 2026
Lincoln
From looks of it a bunch of freight got stuck at nuneaton, not just that so i doubt it has anything to do with the 99
99009
4 Apr 2025
Chesterfield
Thanks to everyone who replied about 4M47 at Nuneaton. 99006 is now at Leicester.
99001 may have had a problem today as 4H31 Doncaster Decoy - Peterborough was delayed and 99010 was added to it. Neither 99001 or 99010 have worked again today with 99002 doing 4Z60 and 4Z61 (and possibly 4Z63/4Z64) by itself.
800001
24 Oct 2015
Good morning, would any kind person have the latest allocation/locations for today for the 99s? TIA
99010 has working 0Z64 from Peterborough to Doncaster Decoy and is now currently on 0Z65 Doncaster Decoy to Toton.
47286Dan
27 Dec 2018
Wednesday morning update
@800001
99001 GBNX PBOREFLDJ PBOREFLDJ 4 N
99002 GBNX PBONYGBRF 454D30CC24 4 DONCDNDCY N
99003 GBNX LESTER SD LESTER SD F N
99004 GBNX OLD DALBY OLD DALBY 4 N
99005 GBNX OLD DALBY OLD DALBY 4 N
99006 GBNX LESTER SD LESTER SD F N
99007 MBEL OLD DALBY OLD DALBY F N
99008 MBEL LESTER SD LESTER SD F N
99009 MBEL LESTER SD LESTER SD F N
99010 MBEL DONCDNDCY 230Z651B24 F TOTONJCN N
Dan
24 Oct 2015
@800001
Dan
Thanks Dan, appreciated
Peter Sarf
Croydon
Yesterday I saw 99006 + 66799 + containers come North through Harrow and Wealdstone on 4M47.
Pantograph was up, all very quiet and no sound of even a ticking over diesel engine from either locomotive.
Adrian Barr
2 Jul 2020
Doncaster
Yes, 4H31 delay yesterday recorded as being a loco issue. 99001 still at Pboro, with 99010 working 0Z64-0Z65-0Z67-0Z70-0Z76 today (Pboro - Doncaster - Toton - Doncaster - Pboro - Leicester).
99002 has continued shuttling between Peterborough and Doncaster - worked 4Z63 + 4Z64 last night and 4D30-4H31-4D32-4H33-4Z60 today, with a set of 6 empty IIA sand wagons.
99009
4 Apr 2025
Chesterfield
Yes, 4H31 delay yesterday recorded as being a loco issue. 99001 still at Pboro, with 99010 working 0Z64-0Z65-0Z67-0Z70-0Z76 today (Pboro - Doncaster - Toton - Doncaster - Pboro - Leicester). 99002 has continued shuttling between Peterborough and Doncaster - worked 4Z63 + 4Z64 last night and 4D30-4H31-4D32-4H33-4Z60 today, with a set of 6 empty IIA sand wagons.
Thank you for all of this, extremely helpful!:D
Platform 2
23 Nov 2018
On Friday, 26/06, the following were at Leicester LIP: 99003, 99005, 99006, 99009 and 99010, with at least one more inside the shed building.
99009
4 Apr 2025
Chesterfield
As far as I know, 99's at Leicester depot on Friday (and today) are 99003, 99006, 99008, 99009 and 99010.
So, assuming the above is true, does anyone know how 99005 got from Old Dalby to Leicester please? RTT shows 2 cancelled schedules from Old Dalby to Leicester on Thursday (0Z12 and 0Z90). Did one of these actually run and the cancellation is an error?
Tobytrain10
2 Feb 2026
Lincoln
I thinks its quite possible 57306, 57303 and 99005 went back on one of these, because 57306 got allocated to a train at leicester on friday... that was cancelled, but nevertheless it was still allocated to it either way showing it probably was there
99009
4 Apr 2025
Chesterfield
Update...
The post by @Platform 2 is correct and almost certainly your post @Tobytrain10 is also correct. I've now seen photos this morning of Leicester depot. 99006 and 99010 are outside closest to the running lines. 99003 and 99009 are behind them. Then inside is 99005 with a Not To Be Moved board and another 99 behind it, almost certainly 99008.
So now the question is, can anyone find out please how 99005 got from Old Dalby to Leicester and what time it arrived at Leicester depot? I'm assuming it was on Thursday afternoon and also assuming it was either 0Z12 or 0Z90 with 57303+57306?
