GBRf Class 99 - 30 locomotives now ordered
themiller
4 Dec 2011
Cumbria, UK
Those trailers are only for movements inside the port areas and on the ships. Either the locos will have to be transferred to transport trailers for a road haul to their destination or they’ll be transferred to the railway for haulage from the port to destination.
23 Nov 2015
You would think that rail transport would be easier, but you never know in this wacky world.
Given that there is no road access for locos into Leicester depot (they need putting on rails elsewhere (Knighton Jct?)), that the transporters they are currently on aren't good for anything other than internal moves, then logically you put them on rails at Portbury. But this is the railway... (although GBRf are admittedly rather more senible than the bulk of the industry!).
Paul AC
3 Aug 2025
Timperley
Rail transport over which section of the route between the Stadler factory at Albuixech (north of València) and the UK are you thinking of? There is no standard gauge connection out of the factory onto the main line - and though the main line past the factory has dual gauge track, there's no direct standard gauge freight route towards the border with France yet; and France is notorious for making passage of other countries' trains across its network as difficult as possible. It's much easier, quicker and cheaper to 'road' the locos on transporter vehicles as has been done here.
If anything is wacky here, it's how long it is taking to get the standard gauge installed between the Barcelona area and the València area.
kennythelad
25 Apr 2011
Saw on FB earlier that they’re due to move by rail on Sunday as 0Q80, 1438 off Portbury, with 47747 doing the honours. Not showing on RTT yet. Info came from one of the shunting staff at Portbury.
Don’t shoot the messenger
43096
23 Nov 2015
Is that 47727 or 47749?
47747 was scrapped 12 years ago!
92002
27 Mar 2014
Clydebank
Once you solve the Spanish and standard gauge problem, you then have signalling problems. With Spain having their standad one and ETCS on High Speed lines. Different ones in France don't make it easy either. Think Eurostar that have a number of domestic and ETCS systems in 4 or probably more countries shortly. As well as different OHL voltages.
So if you were to move the 99s by rail from Spain they would need to be hauled and staff with route knowledge would be a given.
They could probably drive through the Channel Tunnel on electric, but it falls apart on the UK side with no 3rd rail they would need to switch to diesel. The original two managed a trip to Tonbridge a few weeks ago from Leicester. So maybe not impossible but does need a good amount of planning.
Probably the easiest way is as part of a freight train from Dollands Moor or even Calais.or further away.
However there are enough coming to the UK to make it worthwhile and maybe more to follow in further years.There could be 93s too perhaps from the same factory.
littledude
21 Nov 2011
People’s Republic of South Yorkshire
I don’t think anyone was at all suggesting they should move under their own power through Spain and France…
Northampton
99s arent fitted with TVM so not moving through the channel tunnel on their own.
JKF
29 May 2019
There’s two moves booked into the docks at the moment, presumably for the collecting loco(s), one from Eastleigh:
https://www.realtimetrains.co.uk/service/gb-nr:R23454/2025-11-30/detailed
And following on one from Leicester:
https://www.realtimetrains.co.uk/service/gb-nr:R23728/2025-11-30/detailed
I don’t know if this means two locos coming, or if they just have two paths with one as a back-up if there’s a problem with the loco coming from Leicester.
Northampton
Which is a pretty big similarity…
The hardware and transmission modes are completely different.
TVM 430 uses coded track circuits with a specific receiver hardware.
ETCS uses a mix of balise transmission with a balise reader hardware and GSM-R radio.
Trains fitted with ETCS first have to be fitted with the TVM hardware and a computer module to emulate the system on the ETCS display.
Theres other differences. Its sufficiently different that in france some lines are running with both TVM and ETCS in parallel.
Oh, and the channel tunnel requires a completely bespoke set of TVM parameters.
JKF
29 May 2019
I did cross the Avonmouth bridge mid morning, could only afford a brief sideways glance as I was driving but couldn’t make out the locos (nor could my son from the back seat who could look a bit longer). There did appear to be a couple of red cranes in operation at the automotive terminal so possibly they were being unloaded from the trailers. I did expect that the trailers would have ramps so they could be winched off, so maybe what I saw was unrelated.
47749 is the loco booked to run from Leicester for the pick-up.
MickeyN
29 Oct 2021
Barrow-in-Furness
The light loco move from Eastleigh has been cancelled.Will the loco from Leicester take both?
1D54
1 Jun 2019
I believe that was always the plan, 47749 to take both 99s from Portbury
99003 and 004 are currently on the way to Leicester L. I. P. hauled by 47749. They passed Bristol Parkway about 10 minutes ago (0Q80)
ABB125
23 Jul 2016
University of Birmingham
Currently sat in P1 at Bristol Parkway, I assume to wait for the XC Manchester service to depart then follow it
Seen here north of Cheltenham in failing light:
Taken from their social media
003 and 004 have arrived in the UK
A bit more info and on locos 003, 004 arrival at Royal Portbury Dock on
a world shipping site, having come on a LNG fuelled ship Nereus Highway
On 27 November, locomotives 99003 and 99004 arrived at the Bristol Port Company’s Royal Portbury Dock aboard the LNG-powered Nereus Highway. Arrival aboard the versatile car carrier was another seamless operation for GBRf. It followed the June 2025 delivery of 99001 and 99002 aboard the freighter MV Constance.
As with the previous delivery, the locomotives were offloaded using specialised lifts and transferred by Terberg tractor to the port railhead (there are no tracks directly at the quay). It’s an intricate logistics procedure that the port is geared up for and familiar with. Portbury positions itself as a facility able to interface between maritime and rail operations in bringing heavy and high-value equipment to the UK.
The Class 99 locomotives are part of GBRf’s strategy to expand and decarbonise freight operations. With dual-mode capability — electric on 25 kV AC lines and diesel on non-electrified routes — they offer flexibility for the UK’s rail network, helping to reduce emissions and improve cargo transport efficiency.
Supporting rail freight growth​
“The new locomotives will enable businesses to transport freight more efficiently,” noted John Smith, CEO of GBRf. “With both renewable fuels and electric capability, our Class 99s are built for a changing network and to meet evolving customer needs.”
“Receiving 99003 and 99004 is a welcome pre-Christmas gift, mused Alex Kirk, Commercial Director. “These locomotives herald a rail freight revolution in 2026, reinforcing the synergy between shipping, ports, and rail operators.”
These deliveries underline the importance of port infrastructure in supporting the UK’s rail freight ambitions. The UK government aims for a targeted 75% increase in rail freight by 2050. The efficient integration of maritime and rail logistics will be crucial to moving goods sustainably and reliably. There’s more to the transition than just moving more boxes. There are 26 more of these locomotives for a start.
Welly
15 Nov 2013
Watched this good YT video of the 47 running light then collecting the 2 new Flakes.
99009
4 Apr 2025
Chesterfield
If anyone knows what worked 0Q99 Leicester - Leicester on Thursday 27th November 2025, or has access to a system that can find out, please can you reply here or DM me? It's the only blank of an ID in my records for the 99's so far. I don't think another loco was involved, so the answer has to be either a) 99001 solo, b) 99002 solo or c) 99001+99002 together.
Speaking of Leicester - Leicester moves, another one is happening tomorrow, this time via Loughborough then via Toton and with different headcodes.
0Q74 via Loughborough:
0Q76 via Toton:
