GBRf Class 99 - 30 locomotives now ordered
Sonik
7 Jun 2022
WCML South
It sounds like, after the engine starts, the RPM increases after a few seconds of idling
I think that's an anti-smoke function.
It allows the engine to warm up a little before increasing the revs, otherwise you tend to get a lot of unburnt fuel/white smoke on starting.
I've seen the exact same sequence on gensets that use the same engine.
hwl
5 Feb 2012
Very interesting, is that the first clip on YouTube of an engine start for the class? It sounds like, after the engine starts, the RPM increases after a few seconds of idling, as heard in clips from both 001 and 002.
As for the engines themselves, it sounds like there's a lot of deadening in place, as to be expected. It will be interesting to see how they sound under load soon!
The QSK50 engine is basically a V16 built from many of the same parts as a QSK19 (straight 6) but there is far more in the exhaust system to reduce pollutants (compared to Voyagers/Meridians) that also happens to be good at reducing the noise levels.
The main harmonic frequency of the exhaust system will equivalent to 2x straight 8s as the exhaust system for each bank is kept separate similar to the Cl.68 (unlike 59s and other traditional US loco V16s).
Rail Quest
8 Apr 2023
Warrington
Very interesting, thanks both!
JKF
29 May 2019
Barely visible from St Andrews Rd, hiding behind the gravel. Hoping to stake them out on Monday for the move north.
47286Dan
27 Dec 2018
Paths are now in for the move to Leicester
Eastleigh to Avonmouth
Avonmouth to Leicester
https://www.realtimetrains.co.uk/search/detailed/gb-nr:AVONHGB/2025-06-17/0000-2359?stp=WVS&show=all&order=wtt
Dan
cj_1985
6 Mar 2010
Lanarkshire
What kind of services are these going to be seen on first?
If i were guessing... services from Felixstowe... and the Ford trains that run almost entirely under the wires... maybe even the Hams Hall to Mossend/Seaforth circuit (again, almost entirely under the wires)
sad1e
26 Aug 2024
How long will the training and testing for these take.(Hopefully not as long as the 810s) I wonder how long it will take to get them running services.
ayubdaud
11 Mar 2020
Bolton
Hams Hall to Mossend must 100% be one of the services. The current timetable already has electric 'Y paths' with 4S57, planned as 4S94 which depart at the same time. The Monday to Friday ends up about 1.5 hrs quicker (although weirdly the timings change back to diesel from Beattock Summit, which seems unnecessary) and on Satuday it's 4 hrs quicker to Mossend.
Monday to Friday
Saturday
The Bear
11 Sep 2019
Cumbria
Diesel galas?
And doubt that the red pen brigade will chomping at the bit.......
Monday to Friday
Saturday
Yes, hopefully the Seaforth - Mossend will be one of the first working to get Class99s, as its painful watching 66s staggering over Grayrigg & Shap at 20odd mph.
Which really isn't desirable from a pathing point of view.
It will interesting to see how their performance stacks up against Class92s (which is what the 99s performance will be compared with).
It's shame the Dollands Moor- Irvine china clay tanks don't run any more as that would have been the best comparison test.....
D365
29 Jun 2012
On the topic of services, has there been any further developments/announcements wrt 10 off Class 99/4 (ETH fitted) ?
99009
4 Apr 2025
Chesterfield
Not that I know of. Presumably still all under consideration or in discussion between GBRf and Stadler.
As for what the 99's will work first, I expect it to initially be as others have posted. Container and automotive services that spend the vast majority of their time running under wires. That will probably include services to/from London Gateway, Felixstowe, Dagenham and Mossend. Driver training will need to take place before any of that can happen, so where this driver training takes place may offer us the first real clue.
BRX
20 Oct 2008
Some speculation on what they might work is here:
JKF
29 May 2019
Captured them crossing the M49. With apologies for the sound quality, it’s a noisy spot!
(Video shows 66307 towing 99001 & 99002 across the M49 overbridge on the Henbury line)
BRX
20 Oct 2008
Does it seem reasonable to speculate that the arrival of these locos is the most significant development traction-wise, for uk freight, since the 66s?
I know there are also the 88s and 93s so they don't mark the beginning of bimodes in the uk but somehow, the serious look of them and the fact that they are being deployed by GBRf gives me the feeling that we're going to see them become commonplace quite quickly, and that the clock starts ticking for 66s.
Rail Quest
8 Apr 2023
Warrington
I completely agree with this. Even just looking at the numbers, if GBRf decide to extend the order, it'll become the largest freight locomotive order since the last sheds arrived. If other FOCs then decide to order some, the numbers could be huge, especially given the immense on-paper capabilities of this class.
pokemonsuper9
20 Dec 2022
Greater Manchester
Even if more orders aren't done directly as Class 99, if they prove themselves the era of the EuroDual (88, 93, 99) could well be here.
800001
24 Oct 2015
I’ve heard from a reliable source that both 99s are planned in for testing next week between Crewe and Carlisle using coaching stock as a load. No idea or times or which days as yet.
JKF
29 May 2019
It's left on time however it's been held near Yate due to a line block.
It went through Yate quite slowly (based on a YouTube video), which was good for the people out to watch it there!
There were about a dozen people at Avonmouth split between two bridges, and apparently quite a crowd at Parkway (who were also there for 60103).
Nottingham59
10 Dec 2019
Yes, I think it does: their tractive effort exceeds a class 66, and they have three times the power under the wires.
A 99 can haul a full-length 1800t intermodal up the single track hill from Felixstowe in the gap between the passenger services (unlike a 93, which doesn't have the power); and they can get up long steep gradients like Shap in a third of the time taken by a 66.
