GBRf Class 57
Wyrleybart
29 Mar 2020
South Staffordshire
The ETS Voltage is different for the Mk.5 Sleepers, it could be changed / updated, but it would be expensive given the ETS Equipment on a 57 is located on the underframe rather than in the former boiler compartment where it is on the 47s (after 47556 before someone jumps in to say that!) (where it would be even harder to change).
So no, it's not a 'simple change' for the 57s to be able to haul and ETS supply the sleepers.
Fair enough "Nym". Thanks
28 Sep 2017
73s ETH runs at 900v rather than 800v to lower the current draw as the demand from 8 coaches on ths Inverness and even the fort william with 6 sometimes is so high. There's nothing else diesel with the same ETH index and voltage that I'm aware of.
ExRes
16 Dec 2012
Back in Sussex
Have I missed something or has this thread diverted onto the Down Speculative Line? As I understood it these locos are mainly to replace the 47s on stock movements and on RHTT work, nothing that I've seen mentioned sleeper work at all, although I realise that may be down to my missing the relevant info
Benno
28 Apr 2010
You are correct. They will work the RHTT Anglia circuit (based out of Broxbourne I believe) and then join the stock movement fleet based at Beale Street when not on RHTT duties.
ExRes
16 Dec 2012
Back in Sussex
57305, 57306 & 57310 ran today on 1014 0Z57 Crewe Gresty Bridge DRS to Peterborough Maintenance Shed GBRf, 305 & 306 were dropped at Leicester LIP with 310 continuing solo to Peterborough
