Gatwick TVMs not recognising today as a Bank Holiday
Gatwickflyer
11 Apr 2018
Is this just a Gatwick problem, or all Govia Thameslink stations? The TVMs are not properly recognising today as a Bank Holiday, so as you can see from the screenshot, it is displaying the normal weekday fare to London Thameslink of £12.10, instead of giving the Super Off Peak fare of £9.70. Also the default Travelcard shown early this morning was the peak weekday fare. Network Railcard discounts were not being given till 10am, and Groupsave fares were not coming up till after 9am.
If you know how to do it, you could manually select the correct Super Off Peak fare, via the A-Z destination search, but the typical tourist isn't going to know how to do this.
All in all, a huge rip off for GTR.
ForTheLoveOf
7 Oct 2017
Ridiculous but no surprise at all. You can put in a complaint to GTR but I seriously doubt they'll even understand what you're talking about, let alone have any intention of paying their TVM supplier money to fix it.
maniacmartin
Fares Advisor
15 May 2012
Croydon
Looks like a problem with the fares data, not the TVM, to me. BRFares shows the £9.70 fare (any many other fares from Gatwick Airport) has a hidden electronic restriction:
Outbound journey:
Restriction(s) below apply on these days only: Mon 27 May 2019
Not valid to depart any location at any time on any TOC
ForTheLoveOf
7 Oct 2017
Outbound journey:
That would be the same fares data controlled by GTR, then.
JP
1 Dec 2011
Not just at Gatwick. The same TVMs, again controlled by GTR, do the same at Potters Bar. Super off-peaks weren't offered on the homescreen either today nor on the May Bank Holiday.
Hadders
27 Apr 2011
Isn't it the case that the most popular fares sold by the TVM appear on the front page? Therefore if an Anytime fare happens to be the most popular ticket sold it will appear on the front screen.
Not defending the position at all. Quite disgraceful really.
Kite159
27 Jan 2014
West of Andover
Isn't the first time TVMs haven't picked up it's a bank holiday, and it certainly won't be the last time. Certainly the one at my local SWR station has been confused in the past.
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
Outbound journey:
That's actually not an issue due to the way the date bands overlap - if you look above this (full screenshot included below) you'll see "This restriction code applies on the following dates/days:" with the dates/days starting on Tues 28 May 2019, i.e. the restriction code doesn't apply at all today.
I think all the outrage in this thread is maybe a bit overdone, as the OP hasn't provided any evidence to back up the claim that the machines aren't selling the Off-Peak fares, only showing that the "home screen" isn't advertising them (which of course, like Hadders above, I am not defending!).
A Challenge
24 Sep 2016
At the very bottom of the screenshot (under Outward Journey) it says Not valid to depart any location at any time on any TOC, applies from Monday 27th May 2019 until further notice.
Gatwickflyer
11 Apr 2018
If you re-read my original post, I did state: "If you know how to do it, you could manually select the correct Super Off Peak fare, via the A-Z destination search, but the typical tourist isn't going to know how to do this."
All the super off peak were available for sale.
On a Saturday or Sunday, the front screen does change to show the London Thameslink fare as being £9.70
As I also stated, the machines were also enforcing railcard restrictions as though it were a normal weekday.
maniacmartin
Fares Advisor
15 May 2012
Croydon
My apologies. I had assumed that the union of the dates in the main body of the of the restriction code and those for the Outbound and Return journeys specifically applied. Maybe BRFares UI could be changed slightly to clarify this.
Yes but the restrictions listed in that section do not apply on 27 May.
In other words, the restriction code does not apply at all to any journeys made on 27th May.
