Gatwick Airport to Reading - Sunday 4th Feb
tomsy47
23 Jun 2017
The Bunk
Hi All. I am looking for some help and advice on what to do. A few days ago, I bought a Gatwick Airport to Reading single, route via Gomshall. This is for travel on Sunday 4th February. I now see that the GWR website is saying that there is planned engineering work between Reading and North Camp with replacement buses, but it also says that due to industrial action, GWR trains will not run between Blackwater and Gatwick Airport (screenshot attached). As my ticket isn't valid via any other route (that I am aware), I cannot see how I can actually get home using this ticket. Given this situation, would this ticket be accepted along an alternative route, such as via Clapham Junction? I am unsure what to do, so any advice would be welcome.
sonic2009
19 Jan 2010
Crewe
Should be able to claim a refund of the ticket due to the strike action - and then travel via London with contactless? Believe this is cheaper, unless you hold a Railcard.
tomsy47
23 Jun 2017
The Bunk
Thank you both. Excellent information and advice. Yes, I do have a railcard. I've managed to find a split ticket via Clapham and on SWR to Reading, for pretty much the same price as my current ticket. I'll therefore claim the refund and buy this alternative ticket, and at least I am no worse off money-wise. Also, I know my ticket will be valid, so no potential issues.
paul1609
28 Jan 2006
K
Personally, I avoid using rail at all during the industrial action as it is so unreliable.
if all else fails Gatwick Airport has a relatively frequent national Express service to Heathrow Terminal 5 from where you can catch a frequent railair bus to Reading Station. There are tvms at both gatwick terminals for the nat exp leg. Journey time is generally around 2 hr 20 mins.
On a rail industrial action day is will be both busy and expensive.
I don't rate anyone's chances of turning up and getting accommodated on a coach at Gatwick at a reasonable price, and the railair coach from Heathrow to Reading isn't exactly cheap either.
The original poster appears to have found a rail journey via Clapham Junction they are comfortable taking. Even with a reduced timetable, travelling from Gatwick to Clapham Junction is still likely to be straightforward
paul1609
28 Jan 2006
K
You've edited my post to remove the bit where I said it would be both busy and expensive.
Sadly everytime that GTR has industrial action especially at a weekend (only GTR serve Gatwick to Clapham) even the advertised service totally falls apart because of lack of train crew.
infobleep
27 Feb 2011
I would still take the risk rather than an expensive coach. Even if it fails apart, something will be running. It's not as if its just one train an hour.
