Games where I can be a signaller
GusB
Elginshire
Hi all,
I‘m looking for games where I can signal a real-life style railway system, as train simulator doesn’t appear to do this. Many thanks.
Have a look at Simsig.
There are a few free routes available, with varying complexities. I'd suggest starting off with one of the smaller ones to get a feel for it.
Class15
30 Dec 2021
North London or Mildmay line
Hi all,
Simsig a million percent. The actual signalling experience is pretty realistic. The only thing really missing is stuff like line blocks, possessions, engineering work (etc), though if keen you can simulate that yourself.
JohnMcL7
18 Apr 2018
I've not tried it myself but was watching a video on SimRail which has multiplayer servers with a mix of AI and human trains also allowing people to be signallers:
Class15
30 Dec 2021
Thanks.
Simon11
7 Nov 2010
I enjoy Rail Route which you can get on Steam which is less realistic compared to ROC! but easier to play for someone who is new to signalling.
Surprised it hasn't been mentioned yet and only 13 quid now?
PF19
7 Dec 2022
North West - England
I do enjoy that but it's too Arcady for myself hence I didn't suggest it - for someone wanting to simulate "being" a signaller I wouldn't put this very high up the list, personally - still a great game though, well made
etr221
10 Mar 2018
A free game is Train Director - see https://www.backerstreet.com/traindir/en/trdireng.php - but this is more a 'train control' than a 'signalling' (per se) game, I would suggest, but (at the price) worth a try to see what you think: it is an Italian copy/clone of an American game (Train Dispatcher - which now appears to be defunct). There is now a UK signals package, and a couple of UK (Scotland) terrtories (but not, I think, a set of UK trains). Build your own layout/timetable/scenario is possible, if you fancy the challenge...
The other game I'm aware of - but haven't tried - and am surprised hasn't been mentioned is PC-Rail
Snapper37
11 May 2021
Hook Norton
SimSig is awesome, some Sims better than others and it misses a couple of features that would be nice but overall I enjoy playing on it!
Let us know if you are need/want to chain together!
Swindon is a good one to try with Simsig, not too complicated, but busy enough to keep you on your toes. Of course once you have mastered that, the panel was preserved at Didcot railway centre, so you can have a go on the real thing!
Andy Pacer
11 Jul 2017
Leicestershire
Another advantage with Simsig is the community forum on the website, so if you get stuck there will usually be someone out there to give a quick answer to a problem.
John Webb
5 Jun 2010
St Albans
....The other game I'm aware of - but haven't tried - and am surprised hasn't been mentioned is PC-Rail
I have a number of their simulations. The Heritage ones are of particular interest to me - you 'move' levers, send and receive bell codes and operate block instruments. I've never tried Simsig so I cannot give any comparison between the two.
DaveHarries
12 Dec 2011
England
Line blocks can be put in place in a way which, as per the VDU setup in an IECC, will make the track turn blue.
Assuming you have a Windows setup, press F11 which brings up an Incident Control Panel (see ss_icp.jpg). Click the "Track Sections" tab which will bring up a list of all the track sections in the sim you are using. Click on the small mouse icon at the top right of the list and then click on a track section in the sim. Then, in the ICP, click the dropdown list under "Isolations" and from that menu select ENG. This will turn the track blue and any attempts to set a route on the blue track sections will not succeed. The track may not turn blue but even if it doesn't the non-blue track section will still behave as if blocked making route setting impossible. Any isolated (ENG-covered) track sections will highlight in the list of track sections in the ICP.
To lift the block on a blue bit of track the process is the same but select "None" from the isolations menu and the blue, if it is there, should disappear: on a non-blue track section with an ENG isolation the effect will be the same though and as any isolated (ENG-covered) track sections will highlight in the list of track sections in the ICP the process should be a bit less time consuming because you can click on the TS in the list and select "None" from the Isolations menu.
Unfortunately you have to repeat this process for each track section you wish to block / unblock which makes it time consuming: you cannot select multiple track sections at a time.
If all goes well with imposing a block then you should have a situation as demonstrated in the screenshot which is also attached to this post: using the above method I put a line block in platforms 3 and 4 of Crewe the simulation of which, covering the whole Crewe area, was released on Monday (17th April): it is a complex sim covering Crewe station and all the fringe boxes (Salop Goods Jcn, Basford Hall, etc.) which has been sometime in the making but it is also the most expensive one on SimSig.
HTIOI,
Dave
GusB
Elginshire
How would i get it on mac?
It's not officially supported on Mac, but there are a couple of workarounds that you can try. Note that if you have one of the new M* processors it won't work.
This is from the SimSig forum:
If you have an Intel Mac you have multiple options. You can use bootcamp to run Windows natively (you'll need your own copy of Windows), or you can run Windows inside of MacOS by using Parallels or VMWare (I use Parallels with 3 monitors, works fine). There is also Wine.
With the new Apple Silicon M1 Macs your options are much more limited as they have a completely different architecture. No bootcamp, Parallels and VMWare won't work. I'm not sure about Wine.
Another way of running Windows on Mac is through VirtualBox. I've never tried any of these methods as I've always had a PC to run it on.
