Future of the 350/2s
Most Northern Guards would never have seen the interior of a 350
A 350/1 or 350/3 are ok but the 350/2 is quite cramped walking thru and not much different to a 323 with 2+3 seating
It's considerably different - because of the square profile it feels much less cramped, plus there is aircon. The 323 is really quite an old design now.
Oxenholme has 3 platforms - none of which are bays.
Sorry, I meant the branch platform. I suppose it could be used for a terminating service while the train was up the other end (subject to possible signalling changes?), but that would mean poor connections. Adding another platform would be major work, and terminating services in the WCML platforms really wouldn't be viable.
FrontSideBus
11 Feb 2025
The 350/2 interior is dreadful, in every way, but it's nothing that a refurb wouldn't solve.
Better seats than the new 730's though, with their 90' seat backs and a the interior is a million times more pleasant than a 323, especially in Northern's hideous colour scheme!
Better seats than the new 730's though, with their 90' seat backs!
I don't mind the 730 seats apart from that they're too close together. Very much a matter of opinion there.
350/2 ones are decent, though, certainly better than 323s which seem to have a collapse problem (almost since new) similar to the 80x, with the frame clearly possible to feel through the far-too-thin foam.
185
29 Aug 2010
Northern Piccadilly guards park side by side with 350s at Crewe, Stoke and Liverpool. Many Liverpool guards also go home on them.
It's nothing to do with seating interior - it's the well designed door controls, which are vastly superior to all Northern stock. Despite no ASDO, they've been around for 20 years and if staff don't want to come in to work their day off due to the rolling stock, this is a fair compromise. The fly doors at the front are also a bonus.
That said, I've heard there's other technical aspects which the company and Aslef raised which Im assuming may kibosh this idea.
deltic08
26 Aug 2013
North
Trouble with Oxenholme is it only has one bay so an EMU to Oxenholme would not work very well. Perhaps that would suggest the 350/2s should be tarted up with new 2+2 seating and sent to TPE to increase capacity on the Manchester Airport service (including adding a later last train) thus increasing capacity on those services from the present inadequate 5 car services? 8.350 was definitely a better match to demand than 5.397 is.
Not wiring to Windermere when the WCML was done was just nuts. It would have cost next to nothing and would have no doubt established a two hourly Manchester-Windermere service with a shuttle in between (connecting at Lancaster to Carlisle with most or all trains running through), which would have better dealt with demand than the present mess.
All three platforms at Oxenholme are through platforms and all are wired. Running EMUs from Manchester to Oxenholme with a DMU shuttle from there to Windermere is perfectly feasible. The Windermere platform can take a 4-car EMU and 2-car DMU at the same time for same platform interchange if 4-car is enough capacity, otherwise 2x3-car 331s would have to substitute freeing up 2x3-car DMUs for use elsewhere. If this is the case, the EMUs would have to back out so far when empty to allow the DMU in.
I agree that it was a stupid decision not to electrify the branch in 1973 and even more stupid to cancel electrification in 2017 by failing Grayling. Almost as stupid as cancelling MML electrification when the next stage is 80% complete.
If completely closed, the branch could be wired in 3-4 months as it is single track all the way with no bridges to raise if the track is in the middle of the solum.
Mamorin
21 Sep 2020
Cheshire
What technical aspects can be an issue?
My only guess would be fitting the 350/2s into some of the tight bay platforms on the Northern network, for example Stoke.
Having door control panels are all doors would be an improvement for guards compared to 323s.
Then again a lot of Northern guards in the North West barely leave the cabs on 323s at off peak times as is and I would guess the same would apply with 350/2s.
If the 350/2s went to Northern in 1-2 years' time, how much of the Trans Pennine electrification will have been complete? If are some DMU services that run entirely under electrified and soon to be electrified stretches (such as York-Leeds via Micklefield), that could see some older DMUs binned off and 195s cascaded, as well as some older EMUs.
Halish Railway
26 Apr 2017
West Yorkshire / Birmingham
Not enough to facilitate the use of anything bar bi-mode trains. The completion of electrification from Leeds to York and Huddersfield depends on the completion of the sizeable civil engineering works at Neville Hill depot and between Dewsbury and Huddersfield, which isn’t expected to be done until 2028 if I remember correctly.
Peter749
27 Apr 2016
Salford
Platform 3 at Oxenholme is not set up for multiple trains.
If the Dmu comes in from Windermere what happens to it to allow the Emu from Manchester to arrive?
There is only the one loop on the Down side before the station
I've created a new thread for this side discussion:
anthony263
19 Aug 2008
South Wales
Maybe you don't remember that the Northern CAF order was forced through by DfT SoS Patrick McLoughlin, overruling his civil servants, to ensure the removal of the hated Pacers - a political decision.
There was still a limit on how many new trains were affordable (and there still is).
To be fair to.him he was one of the best transport ministers this country has had. I think if he was still in his position Mr sunat wouldn't have had such an easy time cutting back hs2
D365
29 Jun 2012
By which point the new build Northern EMUs (12 x 3 car) should be under construction.
D365
29 Jun 2012
I can entirely understand a micro-tender for EMUs being dropped. Are the 333s still in good condition?
It’s not a ’micro tender’. Although Northern might award the three Lots (EMU, MMU, BEMU) to individual rolling stock manufacturers, there is a strong weighting towards multiple working capability between the three types of unit.
sad1e
26 Aug 2024
323's would be awesome with a "Renatus" style refit!
There's no point of a renatus style refurb of old EMU's when a large order of new EMU's are on the Horizon , the 321's proved this themselves as they got replaced quite quickly after the extensive refurb.
Its better just to keep 323s clattering around in their current state instead of subjecting them to for only a short few years in service with nowhere viable to send them off too after replacement other than the scrapyard.
Class15
30 Dec 2021
North London or Mildmay line
The Renatus 321s were scrapped because leasing costs for new trains were cheap at the time and the 720s could be used as a common fleet. Leasing costs for new trains have risen considerably since then.
You wonder why Northern didn’t take the Renatus 321s on to replace some of the 323s, would have been much better in my opinion.
I agree! Some would likely have been shortened to 3 coaches though, to allow 6 car formations. 4- and 6- car 321 formations could have been very good!
tfw756rider
30 Nov 2024
Wales (sometimes in England), thanks for replying!
And what do you think will happen if they go to Northern?
(Hint - class 170 and 333)...
Those were fitted for "good" reasons though - 170s to be able to still work in multi nowadays with 15x I believe? (although has that actually happened, and ScotRail did the reverse - 158s to BTROS) and 333s to replace the magnetic tape system. I can't think of any reason that Northern would want or "need" to "TrainFX" the 350s if they acquired them?
I refer you to a brilliant sarcastic post by @Transilien
The same @Transilien that said that the Class 197 is an outdated design (!) is implying that it would be OK for 1992-1995 323s to not be replaced by 2008-2009 350/2s in 2026.
Also I don’t see why a poor PIS has anything to do with the actual quality of a train and why it is life-expired.
Even if it was replaced with one that was decent, it would still be a train that's too old.
EMUs typically have a lifespan of 40 years. In other countries, trains are normally kept until they become life expired.
That would mean the 323s would start being withdrawn in 2032 or so. Which I wouldn't actually mind if there wasn't anything newer available to replace them, but there is, so...
By comparison, the 350/2s wouldn't start being withdrawn until 2048. And I'd much rather have 350/2s until 2048 than 323s until even 2032.
Everyone's entitled to their own opinion, yes, I understand that. But still, it utterly baffles me that anyone (whether operators or enthusiasts) can look at pre-1997 units and think "yes, these are perfectly acceptable to still be used in the second half of the 2020s and into the early 2030s, I don't see what the problem is"... and I'm saying that as someone who has childhood nostalgia for 1990 158s.
The 323s are a lot better than the 331s that "replaced them" - Modern CAF units are rough riding even on good track as the suspension is too stiff.
I'm well aware that modern trains have ride quality / suspension issues, and other issues (I'm not one of those people who pretend that they don't). In an ideal world, they wouldn't. And it's much less of a difference when comparing the 323s to the 350/2s, rather than the 331s.
But modern trains also don't look old-fashioned or out-of-place in modern times, don't sound old-fashioned (although we will of course miss the epic pull-away sounds of the 323s in particular), and don't feel old-fashioned either. Again, everyone's entitled to their own opinion - you think the 323s are better and I think the 350/2s are better.
Peter749 said: When the train stops because of lack of power you can Open The Windows unlike the modern units where you are stuck without any fresh air
Fair point.
Peter749 said: The Accessibility Equipment - disabled Loos(?)
  • Universally accessible toilets
  • Audio-visual Passenger Information Systems (external and internal electronic screens and automated announcements)
  • Wheelchair spaces compliant with modern regulations
  • Handles/buttons etc. that are easy to see and reach by all
Peter749 said: had to retrofitted to all trains because of a law that came out well after they were built.
Exactly! Retrofitted! When something's so old that it has to be retrofitted with some modern equipment to remain legal to continue to operate, you know it's too old...
61653 HTAFC
18 Dec 2012
When Northern got the 319s everyone was moaning about how slow they were. The Renatus refurbishment didn't do anything for the performance of the units, and although 321s weren't quite as sluggish as the 319s they were still old technology. Performance wise they wouldn't have been able to keep to the timetable written for 323s, even reduced to 3 cars.
Besides, when we're discussing the feasibility of replacing 323s with newer 350s I can't see the logic in instead replacing the 323s with 321s. The 321s were only a few years older than the 323s but a whole generation older technology-wise. It would be like replacing 315s with 312s.
Why would this be bad? The 323s can be replaced by 350s but there are no spare modern DMU or BEMUs to replace 150s and 156s.
You might not be aware, but DfT updated its procurement spreadsheet 11th September, and there are two entries for Northern. One replacing oldest 15x (line 11) and the one with 3 lots consisting of EMUs, BEMUs and MMUs (line 12). Clearly the 350/2 could be part of the first of the two Northern entries
You will also notice the entry about replacing oldest 15x seems to have a very precise value, (rather than a round number) and earlier complettion date than other row which suggests more is decided.
Mamorin
21 Sep 2020
Cheshire
The EMUs are for TRU, and those will be new trains.
Nothing on that spreadsheet has changed regarding the 350/2s, at the moment Northern is not taking them.
43096
23 Nov 2015
No, if it is too old, then it gets replaced rather than retrofitted. So clearly the 323s were not too old.
Another example: the 458s had their PIS screens replaced when around six years old, due to change of legislation. Did that make them too old?
Russel
30 Jun 2022
Lichfield
I may be missing something obvious here...
Can you elaborate on what you think the precise value suggests?
It's no longer an estimate or ballpark figure.
Rather suggests the £value has come from an advanced negotiation or an offer from a lease co, which is close to final (even if not announced yet)
skyhigh
14 Sep 2014
The Northern 170s always could (and did) multi with 15x before TrainFX was installed. The system was changed because it was non-standard.
A non-standard system replaced with a common one to reduce the spares needed and make it easier to maintain.
It's exactly the same as the 350s situation.
Nym
2 Mar 2007
Somewhere, not in London
Except that 350s won’t multi with anything else so as long as spares are available, why change it all out?
