Future of the 350/2s
sad1e
26 Aug 2024
This is highly speculative but would either manufacturing or converting a coach to put a Diesel engine in it to convert EMU's into DMUs or Bi modes be feasible. Like the GA 755s with their short power unit coach.
If so they could be sent off to northern to replace some of their old knackered 150s or something along those lines.
Failed Unit
26 Jan 2009
Central Belt
Sadly most attempts to do this have not really worked - thinking 319
mr_jrt
30 May 2011
Brighton
Would there be any major obstacles to lengthening the short platforms from 6 cars to 8 cars? That would seem like a good investment for the future, and could be cost offset for by getting advantageous terms on stock that would otherwise go to the scrapheap.
pokemonsuper9
20 Dec 2022
Greater Manchester
Porterbrook own the 350/2s, and given their history with the 319s if no one wants the 350/2s they may well try anything to get them out again.
Especially since the 350/2s are quite a bit younger than the 319s were.
DMU conversions have largely gone badly. But fitting "last mile" type batteries for use on routes like Manchester Airport to Barrow and Windermere isn't entirely out of the question - indeed wasn't it being looked at at some point?
N1
10 Aug 2022
Pretty much every North Clyde and Argyle line station is setup for 120m trains (334s are effectively 20m), only a few would be long enough for 160m trains. Also the capacity is just not needed, definitely doesn't justify platform extensions. 120m is plenty in peaks and 60m sufficient off peak. TBH 4 car 350 would be fine on the shorter low level services. There would probably be more obstacles to overcome. Signal sighting being one, with the gangways. Not necessarily a complete no.
Announced but done absolutely nothing about it since? Similar to the battery assisted 450 proposals about Basingstoke - Salisbury - Exeter. Yet they’re often mentioned in the forum.
Does anyone know if any practical work has ever started, you’d think Porterbrook would be pretty quick with the PR if it had…
(I just did a search, there’s 36 posts in this thread about battery conversion… o_O )
Trainbike46
18 Sep 2021
belfast
East Kilbride is still entirely diesel, won’t be diesel/electric until December.
I'm slightly ahead of events then. The point still stands though as it won't go fully over to electric due to a shortage of sufficient EMUs.
Similarly to Northern, ScotRail is intending on a significant train order. Bi-mode and multi-mode units to replace their remaining ex-British Rail DMUs/EMUs and, eventually, the Class 334s.
And when they go ahead with ordering their new (B)EMU fleet, it will be very good for train services across large parts of Scotland. I just hope they actually go and progress the order process.
InTheEastMids
31 Jan 2016
Can't comment on the second part, but if the 350/2 withdrawal thread is anything to go by, the first LNWR ones were stood down in Autumn 2024.
That Porterbook haven't yet announced a conversion either means they think they don't need to (i.e. can lease it as a pure EMU) or are unwilling to take the significant design costs to speculatively convert one.
If it's the latter, the issue they may face is that buyers at DfT/GBR etc may be pretty sceptical given Cl769 project and wider industry failures to deliver rolling stock on time.
DfT are supposed to be doing a procurement for 29 multi-modal units for transpennine. I wonder if the batterified 350/2 are being pitched for that, which would leave a maximum of 8 units with no home to go to.
Energy
29 Dec 2018
I haven't heard about it since, though the 350/2s have been busy with LNWR till recently.
SWR seem to be far more serious about battery 450s.
I think battery/Scotrail/Northern predictions are unlikely. I reckon they'll go to GWR, and their 387s will go to another Southern/SouthEastern cascade.
Energy
29 Dec 2018
The TPE is asking for 29x at least 5-car 200km/h (124mph) trains with an option for another 26. They intend that all services are full-length units, and the units will be multimode to avoid procuring several fleets.
[source]
The 350/2s don't really fit this criteria.
Zomboid
2 Apr 2025
Oxford
There would need to be a lot of (pretty much invisible) design work done before anything tangible happens.
I don't know if it is happening, but there's no great rush whilst the 159s still have a reasonable lifespan.
Sonik
7 Jun 2022
WCML South
Please, no dodgy conversions...
Have any successfully worked, long term?
There is a fundamental commercial barrier to effective conversions IMO.
There is a limit to how much it's worth investing in an old train, and proper engineering costs a lot of money. Therefore (and no disrespect to those involved) conversions are inevitably a bit of a low-budget bolt on job, with predictable results.
Albeit GWR seem to be doing OK with their batteries, but that's part of a longer term renewal/investment plan (i.e. it's technology research, not a ROSCO trying to offload some buffed up old stock)
gingertom
19 Jun 2017
Kilsyth
I've had a snapshot on Real Time Trains to see what's being deployed on the Glasgow Central - Ayr route. The consists are 3 car, 4 car, 6 car and 7 car. This suggests to me that a bunch of 350/2s could be dedicated to the Ayr route as 4 or 8 car sets, releasing sufficient 3 car 380 sets to operate elsewhere; East Kilbride #1 contender.
Transilien
10 Mar 2024
Ayrshire
Some of the platforms on the smaller staions of the Ayr line like Barassie aren't long enough for 7-carriage trains. SDO would need to be instaled in order for this to work.
hwl
5 Feb 2012
Porterbrook and Siemens have installed a large power supply (SFC based) at Long Marston and are busy upgrading the track on the outer loops to increase speed for continuous running battery testing purposes.
AJDesiro
10 May 2019
Rugby
Work has already been done on the 350 fleet to install ASDO, I am not sure on whether this includes the 350/2s, but the actual job itself will be doable with recent experience from Siemens for installation. The ASDO isn't in use yet but it's planned to be implemented once the 730/2 fleet is fully introduced.
The Ham
6 Jul 2012
Even at a station with 500,000 people a year on a line with 2tph would likely see 35 passengers per train in the peak hours (about 8 people per door, but that's getting on and getting off) whilst it would be better to have them be able to use both halves of a 8 coach train, it's not the end of the world of they can't.
If there are stations with 500,000 passengers a year then platform lengthening would probably be justified if the extra length isn't very much, whilst if they have less than 250,000 passengers (so 4 per door or less) almost certainly isn't.
SWR have short platforms on lots of services run by 450's with ASDO, however prior to that they were by unit selection and it still appeared to work.
cle
17 Nov 2010
It's a bit nuts that there isn't an obvious home for them... they could run the Heathrow Express if 387s were needed elsewhere - they can hit 110 after all.
Maybe something on Great Eastern?
Pumbaa
19 Feb 2008
350/2 excluded from scope. But all others fitted and waiting to be commissioned.
anthony263
19 Aug 2008
South Wales
I suspect then we could see a 350/2 in the future equipped with batteries to show it works. Now if the wires got to Bristol TM perhaps.if there's enough range along with equipped them.with 3rd rail shoes maybe let gwr have some for the Cardiff to Portsmouth Harbour service
Zomboid
2 Apr 2025
Oxford
A pretty likely scenario if there are no takers for them as AC units, IMO.
Adding shoes might be a step further than they'll go though, if they can create a reliable AC BEMU conversion fleet then there should be plenty of opportunity for someone to take them on. Though I wouldn't be surprised if it didn't get beyond a prototype.
anthony263
19 Aug 2008
South Wales
Could be handy for gwr especially with 3rd rail shoes. North downs line etc
The work involved in getting them on a service like Cardiff-Portsmouth is probably too costly and risky, which is a shame as having 8-car tri-mode units would be a real crowd-buster on that route and maybe a magnet for further passenger growth.
Zomboid
2 Apr 2025
Oxford
Yes, but adding shoes and batteries is likely to be fraught with opportunity for things to go wrong. Better to add batteries to a train that's already dual voltage if that's the target.
There's plenty of other places which could make use of an AC BEMU - including GWR on some of their other routes, depending on charge speed. They'd probably be able to find uses in and around Liverpool, Manchester, Leeds, Newcastle depending on the off-wire range they can offer.
Peter Mugridge
8 Apr 2010
Epsom
Has anyone suggested using the 350/2s to boost capacity in the c2c routes from Fenchurch Street?
They would allow more 12 car 357 sets to operate, and could operate as 12 cars themselves. Despite the recent arrival of the 720/6s, there's still a lot of very busy 8 car rakes in use.
Downside is it gives them three separate fleets to juggle, of course.
