Nothing planned yet aside from the 317722 trial which will take place soon. Watch this space.
That's wrong for a start. 321448 is a Doncaster having a complete overhaul to be a test bed in a similar vein to 317722.
I've heard on the grapevine that 321448 isn't having the complete overhaul anymore. It's just having the same work all the other bins have had. I maybe wrong....
Methinks you are hearing correctly. Funds froze up after they couldn't get confirmation from the powers that be that the 32x will have a revenue earning future.
321s are not too bad to drive-ok very under powered like a 317 (a 365 will reach 100 on the down fast by new barnet, a 321 or 317 will only just reach 100 by Hatfield-they struggle to get above 85 until potters bar-they actually loose speed in full power from wood green to Hadley wood). The brakes arnt bad but different to 317s etc and you find step 1 isn't nearly enough and step 2 is too much so you have to constantly fan them. But they have nice comfy cabs, quite smooth, and nice for lower speed work where you arnt getting much above 75. Just a nightmare in the slippy season.
The 321's brakes I find are better (except in left fall season when they seem to lock up very easily) as you have far more feel to the brakes. As regards to power it all depends if you have got a good set of motors or not, they are DC motors on 321 still.
Why are all the top people so obsessed with a new train set the politicans talk about the new trains since privatisation what about the fares
I would rather have trains that go are well maintained and safe rather than new shiny toys no one can afford to travel in
The 321 s need better seats possibly new bigger motors for a bit more power sort out disabled access and good for another 20 yrs
They may be obsessed but the Thameslink order is barely off the ground... And the long gaps we have between orders? The 317 project aims to achieve what you desire; new interiors and seats, DDA rebuild, Bombardier traction and other modifications which should keep rebuilt sets going 20 more years, as opposed to buying these "shiny toys".
Anyone know why when they replaced the track from Colchester to Walton and Clacton they did not put it 6" lower and allow step free access
I drove 321448 the other day, that one has just had an internal refresh![]()
I understand that; a uniform, high-acceleration fleet is needed to enable a high frequency service, of which we have none in Britain. However, we should seek to continue using our existing assets as efficiently as possible, and only buy new where we can justify it.
For example, is the extra cost of buying new 110mph rolling stock for GWML suburban worthwhile as opposed to refurbished 319s? Ditto replacing Greater Anglia 317s/321s (and 360s, with 379s?) instead of refurbishing the former two. Although when buying new stock, displaced stock can be reused elsewhere.
But the refurishished 319s weren't built for 110mph so unless you rebuild the body you might as well buy new and use the 319s elsewhere. Plenty of places where you could use more electric stock, especially now.
However you missed my point as I said neither new build or refurishished units alone is the soluation but both. In fact I mentioned displacement in my post as well.
However calling those who are asking for new stock obsessed is wrong as it referring to new units as 'shiney toys'. You forget there's a need for additional electric trains that means simply we need new to meet all the requirements. Transpennie is a good example of this. Thameslink order just doesn't affect Thameslink but has wide ranging effects that could affect today's Southern, FGW and Northern. People are worried, rightly, what they are going to get after finally getting the wires up. To use remarks like that over looks that and you seem to be suggesting we can only refurish units and everything will be ok. It not.
Hi one of my collegues has said one of the rail magazines states 321448 is going to be used for this test.
Ignore me. I have it on good authority 321448 is still at Doncaster, and is not due back at Ilford until January.
This was what originally was going to happen, but its not now (or maybe it is). I thought you drove it the other day? :P
But this fella drove it the other day (!) :P
Very confused now. Abrail list it as being in Red & White colours, implying it has come back.
Adam![]()
