Future for Class 180 Adelante fleets
Russel
30 Jun 2022
Lichfield
Why? Salisbury's 158/9s and 159s are the most reliable (ex-BR) diesel fleet in the country. Why replace them with the 180s? As a certain Paul Tyreman once said, you'll be going nowhere.
They would keep the firefighters of the west country in a job though!
3RDGEN
6 Mar 2023
Hull
With GWR taking the 175's it does raise the remote possibility of GWR taking the 180's to work the Bristol - Plymouth - Penzance services, this would allow the 80x's to be cascaded internally and free up a few175's to work some of the local services replacing 150/16x units.
stevieinselby
6 Jan 2013
Selby
Third time's the charm? (F)GWR have already got rid of the 180s twice!
3RDGEN
6 Mar 2023
Hull
Third time lucky maybe, but unlikely. Once the 175's are in place and sorted the four off lease 180's could be recommissioned and refurbished and sent to GWR. Once that's done GC could be releasing the remaining 10 units so refurb them and the full fleet can be reunited at GWR for a final 8-10 years, we are promised a rolling stock strategy so there's a start.
Russel
30 Jun 2022
Lichfield
That's one way to shaft GWR, the 180s have always been a liability and dumping them on GWR when they are nearing end of life is only going to have one outcome.
The lease at Ely has expired, so unit(s) moved to Derby is what I have been told.
There was a thread about a rumour Ely Papworth Sidings are closing soon, but was closed considering lacking evidence. If the lease is expiring on stock still there with no obvious future, that might explain where the belief came from.
43096
23 Nov 2015
If that’s the case, why have Angel moved HST vehicles into Ely in the last few weeks?
liamf656
2 Aug 2020
Derby
Both 180109 and 180113 have been loco hauled to Eastleigh now having spent some time at Derby Litchurch Lane. Does anyone know what's happened/happening with these units? They weren't in the best shape when EMR ran them so I'd be surprised if there are plans for further service for them
ENC Rail
5 Dec 2023
West Yorkshire
Could they go to Grand Central to replace their two 221s to go to Cross Country? However as you say, the condition of these units could be an issue.
liamf656
2 Aug 2020
Derby
I've heard mutterings now that they could be for Grand Central, releasing the 221s
Southern Dvr
13 Oct 2010
They’re knackered, surely it’s just a move to Eastleigh for component recovery and scrap?
XFeed
25 Nov 2025
Chester
I`ve never traveled on or been a part of 180 maintenance, what are the overriding factors as to why they are knackered ? for people like myself that has never been involved with them.
The thing I do know is that reliability has been an issue over the years at times.
I think that there maybe a 180 slagfest incoming :rolleyes:
Southern Dvr
13 Oct 2010
See GWR Class 175 debacle!!
See GN Class 379 debacle!
Similar traction to the 175, stored outside, not started, not maintained, not given any running time.
XCTurbostar
13 Sep 2014
I don't this is correct. Grand Central stated when the lease begun that 142 and 143 were leased to add 'resilience to the fleet, facilitated a heavy maintenance programme on the Class 180s'.
GC have 10 180s which should be more than enough for the two routes.
XFeed
25 Nov 2025
Chester
I am very aware of the 175 issues as I was involved with them for over 20 years, I was hoping to get a better understanding and insight of the problems and issues that have rendered 180s knackered.
XFeed
25 Nov 2025
Chester
Amos390
22 Jan 2025
A path has been put in from Ely - Eastleigh , presumably either 180110 or 111 being transferred.
It says on this that it's timed for only 50mph, is that followed and if so what's the reason, is it simply just they have just come out of long-term storage so will not be in the greatest condition?
sad1e
26 Aug 2024
It's probably due to the fact that the 180 in the drags is not through braked and needs to be Run T&T with barrier wagons.
Amos390
22 Jan 2025
Oh that’s a drag, didn’t realise, thanks. I had presumed the 180 would go under its own power but I suppose a drag makes much more sense.
lesthebus
30 Jan 2025
Stafford
Back on Decemer 5th last year 180113 ran under it's own power from Widnes, to I think Ely. Going fine when I witnessed it passing Stafford.
wickham
3 Feb 2021
Knaphill
Does anyone actually know why these units are being moved to Eastleigh Depot (not works accoring to the schedules), there is a lot of speculation above but no facts !
Might they simply be going there for continued store, the Airport Sidings are now pretty empty now that they are not needed for SWR 701s.
sad1e
26 Aug 2024
It's a possibility , but I would find it strange for them to take units out of store from Ely on Monday just to put them back in store at Eastleigh. Wouldn't it be easier just to leave them be at Ely.
3RDGEN
6 Mar 2023
Hull
It's a possibility , but I would find it strange for them to take units out of store from Ely on Monday just to put them back in store at Eastleigh. Wouldn't it be easier just to leave them be at Eastleigh.
There are facilities at Eastleigh if the units are to be recommissioned whereas Ely is in effect just a yard, GC 180's did get work done at Eastleigh previously so maybe they are there for return to service works. GC maybe taking them on in the short term to release the 221's, perhaps GC have been told releasing the 221's would help their track access application to Cleethorpes?
The four 180's not in service have been stood down for an extended period so you would expect similar issues as those on the 175's requiring a full package of work if they are to be return to service. The 180's have past from numerous operators/maintainers over the years with no longer term future ever planned so they have suffered from that. Alstom only took on maintenance of the ten GC units when they bought Bombardier prior to that it was technical support and parts supply but no full maintenance contract like the 175's.
XFeed
25 Nov 2025
Chester
Thanks for the reply, although I worked on the sister fleet I never followed the fortunes of the 180s apart from hearing the reports of worse reliability than ours.
