It is never going to be possible to electrify everything all at once under any government or in any economic circumstances. That's life.
If we want our railways to be electrified, which I think we nearly all do on this forum, then doing it in logical incremental steps seems like the only way forward.
If confirmed next week, I think the electrification of the three sides of the Liverpool - Manchester - Preston triangle (with possibly the Stalybridge extension) is a very sensible and logical scheme.
Once achieved, there will then be some more logical extensions to pursue in order to reduce DMU usage further; Preston-Blackpool and Oxenholme-Windermere spring to mind. So we begin to have a comprehensive electrified network.
Whatever political party we may support, electrification has been off the agenda in the last 20 years. How astonishingly refreshing it is now to have a Minister of Transport who is actively pushing it. Yesterday's announcement, even if just in headline format, was a very pleasant surprise. I was not expecting that at all.
Blackpool North would have to be included in the first triangle scheme you mentioned, otherwise it doesn't make sense. Stalybridge is not going to happen, unless maybe the NTP route gets done, which equally shouldn't be done unless you're prepared to electrify to Scarborough and Hull, which I imagine any economist would baulk at.
At this risk of doing the railway enthusiast equivalent of farting in church, I don't necessarily believe that electrification is the way forward, and never have. Are Mk IVs better than Mk IIIs? No. Can HSTS keep the timings run by 91s? Near enough as makes no difference. The benefits of electrification of the ECML were in the signalling improvements and reallignments, so that HSTs can run as though they were electrics. This could have been done without the huge cost of electrification. The disbenefits on the other hand are chaos every time there are high winds, or huge disruption when engineering works need to happen.
Electrification should be applied to logical extensions of existing electrified self-contained systems only (such as Ashford > Ore). A piecemeal approach shows the despressing lack of forward thinking that is only too obvious in the railways over the past generation or two, and the 'Green' debate creates the false idea that electrification for electrification's sake is
always a good thing. Kind of feels like we should be grateful if anyone spends
any money at all on the railway, even if it's being spent misguidedly to electrify a line that only one train an hour can use throughout its length, rather than pointing out that this may, in fact, be crazy.
I've now become an
RPI, whatever that may mean. After my last post, maybe that should be
RIP!
