AJW12
Hi all,
Long time since I've started a thread so hope I've done this right...
I live in and commute to/from Richmond regularly, sometimes using the District Line and sometimes the London Overground, and alarmingly frequently the line is entirely suspended for long periods of time due to signal failures here. (The signals are operated by Network Rail, hence not putting this on the tube discussion).
I had a look at historic statuses* and this has happened rather a lot in the last few months:
Today, 26th June: no service due to a signal failure at Richmond
June 15th: continued signal failure from the 14th (they couldn't even fix it overnight!)
June 14th: signal failure at Richmond
May 10th: signal failure at Richmond
May 9th: signal failure at Kew Gardens (just up the line)
May 2nd: signal failure at Richmond
Mar 27th: signal failure at Richmond
This seems to be extremely frequent - I can't think of many places on the tube network that the signals consistently fail at in the same place as often as here. The signals on the SWR used lines are generally much more reliable; the infrastructure has its moments but it's definitely not as often as the Richmond-Gunnersbury line.
Interested in why this is? What makes this stretch of line so unreliable?
(Source: the @tweetthetube account on X which is a bot fed from TfL's status boards).
