Quick question, I passed the RSSB Train Driver Assessment last week for DBS. If I apply for this FL vacancy will I have to redo the assessment or does the one I passed count?
Ta.
As GB said, you will get a definitive answer from the FOC/TOC concerned. However, the general rule of thumb, is that you are not allowed to take an assessment if you have already taken one within the 6 months previous. If you have passed the psychometrics, it it usually valid for up to 5 years, but it can vary depending on who the FOC/TOC is. The new test has a simple pass or fail marking system at the moment, but there are certain FOC's/TOC's that choose to use and 'enhanced test' requiring a higher pass mark. For example FTPE. Unfortunately, you will only find out once the TOC/FOC checks with OPC, or whoever administered the tests, whether your test score is accepted or not. So, if you took a 'standard' test and you are required to sit an 'enhanced', you have to wait until after the 6 months is up. The scores you achieved are irrelevant, even if they would have passed the 'enhanced' test, as, allegedly, they are unable to check if your scores would have passed. Sounds ludicrous, but this actually happened to me last month when I applied for a Trainee position with FTPE after passing an assessment with Northern a month previous. Hope that helps.
