Freightliner Class 90 and Class 86
USRailFan
2 May 2011
Norway
Are the ex-GEML Class 90s all going to Freightliner? And does this mean Freightliner will get rid of the 86s?
D365
29 Jun 2012
1) Locos 003-015 are going to Freightliner and are reported to be in temporary storage. Locos 001-002 are going to Locomotive Services Limited.
2) That is the plan, yes, once Freighliner have commissioned the above locomotives.
childwallblues
3 Jul 2014
Liverpool, UK
90001/2 have been moved to Crewe HS, 90003-13/15 are in store at Norwich Crown Point whilst 90014 is at Crewe IEMD undergoing a heavy overhaul.
USRailFan
2 May 2011
Norway
How many Class 90s will Freightliner have after this? And are any other operator's Class 90s in use anymore?
ExRes
16 Dec 2012
Back in Sussex
Locomotive Services Ltd will have 2
Freightliner will have 24
DB Cargo will have 24
Some of the DBC locos will be going on hire to Grand Central for their service from Euston
USRailFan
2 May 2011
Norway
Does DBC really run that much electric freight? They couldn't even find use for all their Class 92s, so what do they need so many Class 90s for, especialy now they're no longer running mail?
ExRes
16 Dec 2012
Back in Sussex
Many of them, fifteen I believe, are either stored or for hire to Grand Central, Freightliner also have one which is used for spares
Mollman
21 Sep 2016
Preston
Does DBC really run that much electric freight? They couldn't even find use for all their Class 92s, so what do they need so many Class 90s for, especially now they're no longer running mail?
There appears to be a number of 66 hauled workings which could be 90s. Also if the government ever gets around to some infill electrification then there will be more routes they could be used on (such as London Gateway services). 92s had issues which meant the routes they could be used on were limited, especially now that Northern's new EMUs seem to dislike them (they apparently interfere with the electrical systems)
D365
29 Jun 2012
That sounds familiar. There was a whole paragraph on the Class 378 Wikipedia page claiming that harmonic interference from the Class 92s was causing the 378s to "shut down". Apparently this was fixed by Bombardier altering the tolerance settings.
captainbigun
3 May 2009
The CAF units were found to be problematic, not the 92s. It was they that were causing 390s as well as 92s to limp.
43096
23 Nov 2015
Neither have I, 90039 also seems to be in the same pool but its at Crewe IEMD. I wonder if they'll actually get used for sandite?
It’s a stored/holding pool they’re using with that description, that’s all. It appears to have only been used recently for locos stood down since COVID-19 reduced traffic.
USRailFan
2 May 2011
Norway
I thought at least one 90 had been retired due to fire damage? But this seems to indicate all 50 are still in existence?
D365
29 Jun 2012
Freightliner owns 90050 (the fire damaged locomotive in question) and now leases 23 further examples;
  • 13 locomotives ex-Greater Anglia (purchased from Porterbrook)
  • 9 locomotives that they’ve leased since privatisation (now purchased from Porterbrook)
  • 1 locomotive (90016) from EWS. Not sure what the ownership of that one is.
90050 has not been reported as scrapped yet, I am lead to believe that its remnants can still be seen in a Crewe depot.
23 Nov 2015
  • 13 locomotives ex-Greater Anglia (leased from Porterbrook)
  • 9 locomotives that they’ve leased since privatisation (also Porterbrook)
Freightliner now own all their Class 90s including 90003-15.
90016 was swapped ownership with 90050 when 50 was damaged and the issue was traced back to EWS. So 16 became a Porterbrook loco and 50 swapped to EWS ownership.
D365
29 Jun 2012
Thanks for the correction. I was under the impression that Freightliner did buy 050 back, unless that is down to Wikipedia inaccuracy.
43096
23 Nov 2015
That is correct. 50 has passed through EWS hands and was bought by Freightliner a while back for spares. Not sure LNWR didn’t have it for spares at one point as well when they maintained the ‘Liner 90s.
Dr Hoo
10 Nov 2015
Hope Valley
(Snipped)
Could you provide some examples of these, please? (I wasn't clear if you were referring to Freightliner or DB Cargo and am thinking about 'normal' flows rather the current reduced level.)
Whistler40145
30 Apr 2010
Lancashire
Obviously 90s could only cover such duties under the wires
USRailFan
2 May 2011
Norway
I would think the majority if not all Class 66-hauled services between Preston/Birmingham/Crewe to Carlisle or Mossend could be operated by electrics on the WCML?
hwl
5 Feb 2012
Ipswich Yard - Crewe would be another big gain
Mollman
21 Sep 2016
Preston
There were a number of DB Anglo - Scottish container workings that were 66s whilst 90s were still working sleepers. Obviously things are complicated by non-electrified routes. The Seaforth - Mossend workings for example are majority under the wires but suffer from lack of last mile electrification, as do workings to London Gateway
https://www.realtimetrains.co.uk/train/H44945/2020-04-23/detailed
Highland37
29 Jun 2012
Fantasy I know, but is there enough space inside a 90 to house the engine and equipment for "last mile" capability? Anyone got any internal shots from a 90?
