Freight trains in the south west?
isdoo
29 Mar 2015
Hi,
I need to photograph a freight train (ideally in the south west) of at least 20 of the same wagons ideally with the same logo on each!
Not asking for much
Any suggestions on where to locate such a beast.
Thanks for any suggestions....
Northampton
Best bet might well be somewhere near Westbury, for the Jumbo stone trains from the Mendip quarries. Other than that maybe the power station traffic between Liverpool and Drax, as they have nicely painted up wagons but not sure they're 20 wagons long.
Northampton
Thanks. Any idea where these run to?
The proper Jumbos will usually run to Acton Yard then split. They've been trialling having locos in the middle of the train recently, to speed up the shunting at Acton. I'm afraid I don't know the eventual destinations, although you could try looking through the Freight Flows thread.
Nottingham59
10 Dec 2019
There are lots of trainspotters who post on Flickr and places like that. I would have a look to see if you could find the sort of images you're looking for on there, and then see where those were taken. That would give you both a freight flow and a vantage point. Others on here might well be able to help find suitable examples.
EDIT: e.g. https://www.flickr.com/search/?text=freight train mendips
Dr Hoo
10 Nov 2015
Hope Valley
Hi,
Not asking for much
Your biggest challenge will be finding a train of ‘clean’ wagons that aren’t mostly marred by graffiti, sadly.
ExRes
16 Dec 2012
Back in Sussex
The 'cleanest' sets of wagons around are possibly the DCR blue JNAs, about the only picky point is that some may have the 'Cappagh' logo and some may not, in the south west the only 'regular' run currently is Willesden/Machen Quarry/Oxford Banbury Road Sidings
AndrewE
9 Nov 2015
whereas the Drax biomass trains are pristine... of have been whenever I have seen them, about monthly at Edge Hill.
They’re not very near the south west either, are they?
Chingy
24 Jan 2020
Frome
One of your best bets is to get the Merehead/Whatley to Theale workings. They're normally 20+ Hanson hoppers, all the same. These usually use the Westbury avoiders though, so either Pewsey/Bedwyn or a bridge around the Fairwood Jnc area will be best.
The Jumbo's, whilst they easily have 20+ wagons, they're not all the same. These can be 18 hoppers and 18 boxes for example, plus they may not all be logo's, at least not clearly.
Other options are the GBRf stone working from Ferme Park to Avonmouth. Not sure on the exact number of wagons, but GBRf usually have more modern, cleaner wagons, easily logo'd. Or perhaps the Theale to Milford Haven tanks, although admittedly, these aren't always logo'd.
isdoo
29 Mar 2015
Thanks all!
I will keep looking and trying to find out where the busiest locations are.
Where do the drax trains run?
I do travel occasionally further north :)
Northampton
Thanks all!
From Liverpool across the transpennine routes, not sure of the exact routings.
becky_rtw
11 Aug 2021
surrey
Lots of freight trains that run through Patchway / Filton Abbey Wood / Lawrence Hill to skirt around the edge of Bristol. Always seem to see 2-3 when waiting for one of the few passengers trains around that area.
Patchway has an overhead Bridge and is well sighted, but does have electric overheads if this will spoil your shot.
Undaunted
3 Aug 2022
Wessex
Two of the photographs on pages 66/67 of the August edition of Modern Railways appear to have the right combinations of train and location.
D6975
26 Nov 2009
Bristol
Thanks all!
Drax biomass trains run via Rochdale, Hebden Bridge, Healey Mills, Knottingley.
West of Rochdale they can run via Victoria and Newton le Willows or via Stockport, Northwich, Acton Bridge and Earlestown.
Nottingham59
10 Dec 2019
I will have a look there
You might want to have a look at Realtime Trains, in detailed mode.
Here for instance is a freightliner train that went through Patchway this afternoon: https://www.realtimetrains.co.uk/service/gb-nr:H28734/2022-08-03/detailed
And this is a list of all freigth train paths timetabled through Patchway tomorrow:
Note that many (most) of the freight paths will not actually be used on any one day. And freight trains often run well before or well after their timetabled path.
eldomtom2
6 Oct 2018
Slightly odd request - any particular reason why you want this or is just aesthetic preference?
Chingy
24 Jan 2020
Frome
Patchway is a bit busier than usual for freight currently due to the Lydney freight traffic being diverted that way.
Future
28 Nov 2021
Devon
Hi,
Not asking for much
There’s a once-weekly flow on either Wednesdays or Thursdays from St Blazey in Cornwall to Exeter Riverside NY with JIA wagons, all with Nacco branding. Trouble is length can carry depending on the amount of china clay required to be taken on the train
isdoo
29 Mar 2015
Looks like it might be running currently with 1,000 tons - no idea what that equates to.
Future
28 Nov 2021
Devon
Usually somewhere between 10 and 20 wagons from my experience. Unfortunately they are almost all graffitied as they are often left sitting around at Exeter Riverside for several weeks
