Freight trains - driving without a break
deltic
8 Feb 2010
What is the maximum time freight train drivers are allowed to drive without a PNB. Looking on Real Train Times I see it is not un-usual for trains to be timetabled to run non-stop for just over 3hrs eg mail trains from Willesden to Warrington and then Shieldmuir. The amount of tea I drink I dont think I could survive 3hrs without a leak.
DarloRich
Fenny Stratford
there are mobile pee break options available ;)
craigybagel
25 Oct 2012
3 hours isnt that long surely? Even at my passenger TOC on one route I regularly work as a guard the routine for me and my driver is normally
40 minute run to a big city.
15 minute turn around (usually time for a pee if necessary but no PNB is booked, so if you're late its a straight in and out job)
3-3.30 hour run to a slightly smaller city, passing through your home depot on the way.
Then you get your break.
Minilad
26 Feb 2011
Anywhere B link goes
We do Birmingham - Bournemouth in one sitting. That a touch over 3 hours. So it isn't just the freight boys who do it. We also do Birmingham - Cardiff and back which is 4 hours 15 mins and if you are late at Cardiff or the west end shunt takes longer than normal you can find yourself doing that without a break too
westcoaster
4 Dec 2006
DTOS A or B
At thameslink we regularly drive for 3hr 15 mins non stop luton-sutton-St Albans, but we also have 2 jobs at 4hr 19 mins of continuous driving bedford-sutton-bedford and one is 0430-0849 now that's some going. And because it's a loop service there is no changing ends or lay over at Sutton.
455driver
10 May 2010
We have some jobs where you can be on the train for nearly 5 hours, maximum turn around time is 5 minutes although most are just 3 minutes so no time for a wee wee.
scotraildriver
15 Jun 2009
We do Glasgow to Oban 3hrs 12 mins. If you need to go then you go. Stuff the delay!
Rich McLean
6 Feb 2012
Oxford - Pad (Pass) 60mins
15-20 mins turnaround
Pad Hereford 3hrs
PNB
Hereford Oxford (2hrs) - where another driver takes over
Not much opportunity there
hello
10 Jun 2008
Pad Hereford 3hrs
PNB
apart from the 1 hour and 20 mins before you do anything, and then the physical needs break inbetween doing something
do you not change ends in both of those instances?
Minilad
26 Feb 2011
I would hardly describe changing ends as a break
vikingdriver
11 Mar 2010
When I change ends, even if it is a tight turnaround, If I really really need to go, I'll go! At least then I can concentrate on the job again! Plus it makes room for a cuppa going the other way!
MichaelAMW
18 Jun 2010
Surely the point of the OP is that on a freight train there's really nothing you can do - other than those "mobile" options that have been mentioned! If you're driving a passenger train then there's always the opportunity to nip back into the train for a quick loo break at a station stop if things get desperate. OK, I know someone will now mention delays etc. but we're talking about one minute and a consequent huge improvement on subsequently being able to concentrate.
GB
16 Nov 2008
Somewhere
We have a service that departs one place at 1720 and arrives at the next place at 2310. Theres a 40 minute pathing stop en route but is not pnb stop and again, if the train is late it runs straight through.
route:oxford
1 Nov 2008
There are other options.
Self-catheterisation.
Adult nappies.
One the chaps I used to work with catheterised himself when he was studying to avoid losing focus.
theageofthetra
27 May 2012
Beckenham
Given that dehydration is linked (according to our 'health & wellbeing' group) with a drop in concentration levels, I wonder how many train crew don't hydrate enough due to inadequate toilet break provision?
6Gman
1 May 2012
Interesting question that. Some years ago we did a rediagramming exercise on the Cambrian which depended on Pwllheli men accepting "Change Cabs" at Barmouth as "a break from the driving environment". (i.e. exchanging cabs with the Machynlleth men coming the other way)
They accepted it.
Can't think of many other depots which would.
Bevan Price
22 Apr 2010
Other alternatives in quiet locations -
1. Cab Door opened - probably needs to be done in several short sessions to avoid dead man's control activating.
2. Stop at signal and "water" fence or vegetation -(last observed on branch from LBT whilst waiting to photo a Class 60).
D6975
26 Nov 2009
Bristol
How many freight turns are there where the train runs for 3 hours without being held at a red at a junction or getting looped?
I wouldn't have thought that there were that many, but the drivers on here will let us know..
deltic
8 Feb 2010
Precisely the point - I am surprised the unions and health and safety reps havent pushed this more, it is a major issue for female drivers, It is notable that many rail work sites now have welfare facilities provided where previously they wouldnt have bothered.
Quite a few - and how do you know if you are likely to be held at a red signal - not something you can usually plan for
FordFocus
15 Apr 2015
On tight turnarounds if I need a pee, I'll have a pee.
Simple as that, not interested in the 2 minute delay sorry. Diagramming should be made better.
We're all humans.
