Freight / enterprise trains definition question.
General Zod
5 Jan 2008
Hello,
I often come across the term "enterprise train" when referring to freight train diagrams e.g
"66006 heads south through Princes Risborough with the diverted 6X66, 02:01 Warrington to Wembley enterprise train with 60048 DIT."
What does the term "enterprise train" refer to / stand for ?
Cheers,
Zod
Mintona
8 Jan 2006
South West
thefab444
27 Oct 2006
The New Forest
They are used by EWS to transport various loads with a common destination or as the "bulk" section of a loads' journey. For example a typical Eastleigh Enterprise:
Containers from Port
Calcium Carbonate from Quarry
Fuel Oil
These are all bound for somewhere in the north, so they are taken together as one train to a yard in the north and then split into different trains, some terminating in the yard and others being moved forward to their destination on "trip" workings. The variable nature of enterprises mean they can often run very short, or with no load at all, or sometimes be extremely long. Services from Eastleigh sometimes appear to just be container trains because that is the main traffic, but they are still known as enterprise trains even if they only have one load on that particular day.
EWS have a so-called "Enterprise Network" which allows them to save money on paths and drivers by combining services.
HTH
37402
15 May 2007
'Enterprise' is the name of the operation when it was started by Transrail back in the days before EWS but the name doesn't really give any clues as to the type of traffic; think of it as wagonload.
The 'wagonload' name gives more of a clue as to the type of operation as it involves small numbers of wagons being transported from various origins to various destinations via one main trunk service and possibly a local trip. By combining various loads that wouldn't be viable to run on their own over long distances, you have a multi-user service for a fraction of the cost to each party in question.
In operation, the customer will confirm with the FOC the quantity of wagons a number of hours before departure and train capacity will be allocated on a first come first served basis until the train is full. This is one of the downsides of not having a dedicated train - there is no guarantee that the traffic in question will move if there is higher priority traffic, however the beauty of the wagonload network is that there is often more than one way to arrive at the final destination through using a different 'trunk train'.
For example to get traffic from Warrington to South Wales;
Warrington-Bescot, Bescot-Newport
Warrington-Wembley, Wembley-Newport
Warrington-Newport direct
