Four Passengers Reading - London GroupSave Best Option?
Thames99
11 Sep 2023
Reading
Next week four of us will be travelling together Reading to Paddington leaving around 10 am and returning the same day in the evening, so at off peak times. Two of us have Senior Railcards and two none.
Is GroupSave our best bet? Could we get tickets with London Travelcards using GroupSave?
It's worth noting that a Reading to London Off-Peak Day Travelcard has time restrictions in the evening, which exclude most GWR services that depart Paddington between 16:00 and 19:06. However, you can still take Elizabeth line services during this period.
If you wanted to take a fast GWR train during that period, it would probably be cheaper to eschew the GroupSave discount and to use contactless PAYG, since this would apply the off-peak daily cap to travel in the evening 'peak' too. That would limit the cost to £35.40 each.
Thames99
11 Sep 2023
Reading
Thanks for that Watershed, I don't think we are likely to be returning until a fair bit later in the evening, so should not be affected by those restrictions.
Our ticketing site should sell these tickets with no problem.
If you know your likely travel times and are taking fast services, you can also take advantage of our free seat selector; if you are lucky, there might be a table for 4 available.
If you don't know your return time, you may want to use our "open return" option (note: restrictions still apply if it's an Off Peak/Super Off peak ticket).
