Fouling Points
umontu
17 Feb 2011
Lancashire & Yorkshire
I've been looking into fouling point indicators.
http://www.railsigns.uk/sect11page2/sect11page2.html
The link above shows two types of indicators but says both are Scottish only; specifically they're used with RETB.
I've seen on heritage lines white posts with signs saying F/P like the one at Oxenhope in the link below.
http://www.rmweb.co.uk/community/uploads/monthly_07_2011/post-9324-0-71605500-1311873702.jpg
But how do they appear on the national network outside of Scotland and were they used in pre-nationalised days?
Railsigns
15 Feb 2010
They usually weren't/aren't marked. Occasionally, in depot areas, a sleeper may be painted to denote the position of a fouling point.
civ-eng-jim
16 Jul 2011
If the line has controlled signalling then there would not be a need for them as the S&C would be protected by a signal and prevent the conflict to occurring.
As "Railsigns" says, FP markers may be used where hand signalling takes place in depots or heritage lines.
Foul points and clear points are provided by the permanent-way designer to the signalling designer rather than for the driver's benefit.
Joseph_Locke
14 Apr 2012
... so that the signalling designers can place their signals and ask the permanent-way designer to provide insulated rail joints at the FP.
The signalling designer can't do FP as they are 16' from the related CP (metric, good innit!) which is a Pway thing.
civ-eng-jim
16 Jul 2011
IBJ should go at the CP....
Tomnick
10 Jun 2005
They certainly are provided for the traincrew's benefit on RETB lines, where the only confirmation that the train is clear inside the loop is given by the driver. The signalling system will prevent a train approaching a point of conflict but won't necessarily (e.g. RETB and some parts of a mechanical installation) prove that it's clear afterwards. I suppose you could argue that the fouling point markers are provided as part of the signalling design using the information provided by the P-Way designer though...!
