For journeys via X see code Y, etc. etc.
wintonian
15 Jan 2010
Hampshire
A little moan if I may,
Why is it necessary to have all of the following in the same restriction. Do the people who write these things even understand them?: :-x :roll:
  • A list of station each with a different restriction code
  • For travel via N the restriction from O also applies
  • Valid on trains scheduled to depart A at xx: xx
  • Valid on trains scheduled to depart B between xx: xx and xx: xx
  • Valid on trains scheduled to arrive For travel via P see restriction A1/A2
Winchester - Swindon SVR (YC) - for example
While we are at it perhaps someone can figure out why there is no cheaper via Salisbury fare for this one, given that the SVR is £28.70 and the SOR is £69.95, or at least some SDR/ CDR's?
Just for kicks I'll stick the restriction here as well minus the general conditions of course to try and keep at least some sensibility.
Restriction Code: YC
JOURNEYS TO/FROM/VIA
LONDON/READING
Available as listed below
MONDAYS to FRIDAYS. (By any
train on Saturdays, Sundays
and Bank Holidays)
OUTWARD TRAVEL:
Available: See notes below
Except: Birmingham New Street
Valid at or later than 1030.
RETURN TRAVEL:
Available on all trains
departing at or later than:
Avoncliff 0820
(if travel is via Bath Spa,
see notes below)
Bath Spa 0830
Birmingham New St
Available on trains timed to
ARRIVE at or later than 1015
Bradford on Avon 0755
see notes below)
Bridgewater 0715
Bristol Parkway 0845
(also valid between 0200 and
0530)
Bristol Temple Meads 0815
0510)
Castle Cary 0735
see notes below)
Cheltenham Spa 0745
(if travel is via Bristol
Parkway, see notes below)
Chippenham 0840
Dawlish 0735
Exeter St Davids 0810
(also valid on 0723 and 0743
XC services changing at
Bristol Temple Meads or
Parkway.)
Freshford 0800
see notes below)
Frome 0720
Gloucester 0748
Highbridge 0725
Kemble 0905
Nailsea & Backwell 0800
Pewsey 0755
Stonehouse 0845
Stroud 0850
Swindon 0905
0545)
Taunton 0840
(also valid on 0751 and 0811
Parkway.)
Teignmouth 0735
Tiverton Parkway 0830
(also valid on 0737 and 0756
Parkway.)
Trowbridge 0750
see notes below)
Westbury 0753
see notes below)
Weston Milton 0745
Weston-Super-Mare 0735
Worle 0750
NOTES:
TRAVEL VIA BRISTOL PARKWAY
(EASTBOUND) FROM CHELTENHAM
SPA/GLOUCESTER:
The restriction time shown
above for Bristol Parkway also
applies with tickets routed
'Any Permitted' from these
stations.
TRAVEL VIA BATH SPA
(EASTBOUND) FROM CASTLE CARY,
WESTBURY, TROWBRIDGE, BRADFORD
-ON-AVON, FRESHFORD AND
AVONCLIFF:
above for Bath Spa also
applies for journeys from
these stations when travelling
via Bath Spa.
RETURN TRAVEL TO OR VIA
LONDON WATERLOO is permitted
on all trains timed to arrive
at Waterloo at or later than
0952.
OUTWARD TRAVEL RESTRICTIONS
apply from the stations listed
below. Tickets are valid:
On services timed to depart
London Paddington between 0810
and 1640, and from 1831.
Reading between 0835 and 1710,
and from 1901.
Slough from 0755.
London Waterloo from 0815.
On services timed to arrive at
Salisbury from 0930.
TRAVEL FROM STATIONS NOT
LISTED ABOVE:
Off-Peak tickets from
stations not listed are valid
for connections into trains
departing as shown above.
ADDITIONAL RESTRICTIONS APPLY
FOR THE FOLLOWING JOURNEYS:
Validity Code WO applies to
all journeys via Newbury or
Didcot Parkway, not passing
through Reading.
Validity Code Q8 applies to
all journeys via Fareham,
Southampton or Salisbury.
Validity Codes 2C/9I
(restrictions listed as From/
via Euston apply from Swindon,
Pewsey, Westbury and Castle
Cary for travel via
London Euston to destinations
beyond Milton Keynes.
Validity codes 7E/9J apply to
all journeys via London St
Pancras International.
OVERNIGHT BREAK OF JOURNEY:
If travelling on the First
Great Western 'Night Riviera'
sleeper service in the
westbound direction, customers
may continue their journey
after alighting from the
sleeper in the morning without
further restriction.
RJ
25 Jun 2005
Back office
They make sense to the people who write/manage these codes, but I'm not convinced it has been properly considered if they're fully intelligible to the staff down on the ground who have to work with them, let alone the passengers. As witnessed with my recent incident at Liverpool which involved a number of ticket office staff not understanding the wording in restriction LK, sometimes they need to be worded in such a way that anyone who can read can understand them. It's not likely that anything will be done in a hurry about the codes in these circumstances.
That said, I have found that restriction codes are sometimes riddled with errors or omissions which can be used to obtain a pecuniary advantage when travelling at "peak" times. You can bet your bottom dollar that the TOCs will act promptly to change the wording or meaning of codes to prevent this, even if only one person in the entire UK has been identified as performing such activities.
Like the National Routeing Guide, restriction codes are just one of those things that only enthusiasts and a small minority of interested railway staff will actually read and get to grips with. With the code quoted above, a lot of people will just switch off after the first few paragraphs and abandon trying to make any sense of it.
soil
28 May 2012
These are the details in the database
Code:
Description      StartTime        EndTime          OutwardORReturn ArriveDepartOrVia
BIRMINGHAM N ST  02:30:00         10:29:00         O               D
COSHAM           02:30:00         08:29:00         O               D
DIDCOT PARKWAY   02:30:00         08:49:00         O               D
DORCHESTER WEST  02:30:00         08:49:00         O               D
FAREHAM.         02:30:00         08:34:00         O               D
FRATTON          02:30:00         08:19:00         O               D
GUILDFORD        02:30:00         07:19:00         O               D
LONDON EUSTON    04:30:00         09:25:00         O               D
LONDON EUSTON    15:01:00         18:44:00         O               D
LONDON PADDINGTN 02:30:00         08:09:00         O               D
LONDON PADDINGTN 16:41:00         18:30:00         O               D
LONDON ST PANCRS 02:30:00         09:00:00         O               D
LONDON ST PANCRS 16:30:00         18:58:00         O               D
LONDON WATERLOO  02:30:00         08:14:00         O               D
NEWBURY.         02:30:00         08:54:00         O               D
PORTSMOUTH & S   02:30:00         08:14:00         O               D
PORTSMOUTH HBR   02:30:00         08:09:00         O               D
READING.         02:30:00         08:34:00         O               D
READING.         17:11:00         19:00:00         O               D
SALISBURY.       02:30:00         08:49:00         O               D
SLOUGH.          02:30:00         07:54:00         O               D
SLOUGH.          16:41:00         18:24:00         O               D
SOUTHAMPTON CTL. 02:30:00         08:49:00         O               D
UPWEY            02:30:00         08:44:00         O               D
WEYMOUTH.        02:30:00         08:34:00         O               D
EXETER ST DAVIDS 05:00:00         11:10:00         O               A
LONDON EUSTON    07:20:00         11:29:00         O               A
LONDON ST PANCRS 02:30:00         10:04:00         O               A
SALISBURY.       02:30:00         09:29:00         O               A
AVONCLIFF        02:30:00         08:19:00         R               D
BATH SPA.        02:30:00         08:29:00         R               D
BRADFORD ON AVON 02:30:00         07:54:00         R               D
BRIDGWATER.      02:30:00         07:14:00         R               D
BRISTOL PARKWAY  05:31:00         08:44:00         R               D
BRISTOL TEMPLE M 05:11:00         08:14:00         R               D
CASTLE CARY      02:30:00         07:34:00         R               D
CHELTENHAM SPA   02:30:00         07:44:00         R               D
CHIPPENHAM       02:30:00         08:39:00         R               D
COSHAM           02:30:00         08:29:00         R               D
DAWLISH          02:30:00         07:34:00         R               D
DIDCOT PARKWAY   02:30:00         08:49:00         R               D
DORCHESTER WEST  02:30:00         08:49:00         R               D
EXETER ST DAVIDS 02:30:00         07:22:00         R               D
EXETER ST DAVIDS 07:24:00         07:42:00         R               D
EXETER ST DAVIDS 07:44:00         08:09:00         R               D
FAREHAM.         02:30:00         08:34:00         R               D
FRATTON          02:30:00         08:19:00         R               D
FRESHFORD        02:30:00         07:59:00         R               D
FROME.           02:30:00         07:19:00         R               D
GLOUCESTER.      02:30:00         07:47:00         R               D
GUILDFORD        02:30:00         07:19:00         R               D
HIGHBRIDGE       00:01:00         07:24:00         R               D
KEMBLE           02:30:00         09:04:00         R               D
LONDON EUSTON    04:30:00         09:25:00         R               D
LONDON EUSTON    15:01:00         18:44:00         R               D
LONDON PADDINGTN 02:30:00         08:09:00         R               D
LONDON ST PANCRS 02:30:00         09:00:00         R               D
LONDON ST PANCRS 16:30:00         18:58:00         R               D
NAILSEA & BWELL  02:30:00         07:59:00         R               D
NEWBURY.         02:30:00         08:54:00         R               D
PEWSEY           02:30:00         07:54:00         R               D
PORTSMOUTH & S   02:30:00         08:14:00         R               D
PORTSMOUTH HBR   02:30:00         08:09:00         R               D
SALISBURY.       02:30:00         08:49:00         R               D
SLOUGH.          02:30:00         07:54:00         R               D
SLOUGH.          16:41:00         18:24:00         R               D
SOUTHAMPTON CTL. 02:30:00         08:49:00         R               D
STONEHOUSE       02:30:00         08:44:00         R               D
STROUD (GLOS)    02:30:00         08:49:00         R               D
SWINDON (WILTS). 05:46:00         09:04:00         R               D
TAUNTON.         02:30:00         07:50:00         R               D
TAUNTON.         07:52:00         08:10:00         R               D
TAUNTON.         08:12:00         08:39:00         R               D
TEIGNMOUTH       02:30:00         07:34:00         R               D
TIVERTON PARKWAY 02:30:00         07:36:00         R               D
TIVERTON PARKWAY 07:38:00         07:55:00         R               D
TIVERTON PARKWAY 07:57:00         08:29:00         R               D
TROWBRIDGE       02:30:00         07:49:00         R               D
UPWEY            02:30:00         08:44:00         R               D
WESTBURY         02:30:00         07:52:00         R               D
WESTON MILTON    02:30:00         07:44:00         R               D
WESTON SUPR MARE 02:30:00         07:34:00         R               D
WEYMOUTH.        02:30:00         08:34:00         R               D
WORLE            02:30:00         07:49:00         R               D
BIRMINGHAM N ST  02:30:00         10:14:00         R               A
COVENTRY.        02:30:00         07:40:00         R               A
LEAMINGTON SPA   02:30:00         07:30:00         R               A
LONDON EUSTON    07:19:00         11:29:00         R               A
LONDON ST PANCRS 02:30:00         10:04:00         R               A
LONDON WATERLOO  02:30:00         09:51:00         R               A
As you can probably see, they have combined the various restrictions so you don't have to cross-reference other restrictions or figure out whether your journey is via X.
