First Manchester night ticket
James268
1 Feb 2014
I need to buy a first night ticket tonight, the website says it is valid 6pm-4am. I will be buying the ticket at bang on 6pm. The bus leaves the previous timing point (which happens to be the start of the route) at 17:57. If it is on time it will be at my stop at, or a minute before, 6pm. Will this be a problem?
The route is the 163.
Polo Mint
24 Oct 2013
It is tough to answer this question. Often First buses are late as opposed to being earlier, but things have improved by quite a bit.
You could walk down to the next stop further down to increase the likelihood that you can buy the ticket. Or wait for the next bus, as I believe the service is every 10 mins. I am not sure if you can use the night ticket on the 17/18 (between Middleton and Manchester, so not applicable in Heywood or Bury) so you could always catch a later 17/18 bus if it applies to you.
James268
1 Feb 2014
It's at the bury end, rather than Manchester. The next one is 15 mins later, but I ideally need that one to catch my connection, the 59 at middleton.
Shrimper
14 Apr 2012
When I was at Stagecoach Manchester the ticket machines had about 2 minutes grace before the official time so you could issue time limited tickets (and accept ENCTS cards) without having to delay the service or inconvenience passengers.
34D
9 Feb 2011
I would plan for the worst, and assume that the driver will refuse to sell it at 17:59.
James268
1 Feb 2014
Turns out it didn't matter, the bus was 7 mins late anyway. Thanks all for the responses
