cnjb8
Acquired from Ensign is former East Yorkshire Volvo B9R/Caetano Levante YY63OJD. Reported sat at Caledonia
Has 38223 officially been withdrawn now? I know it's been off the road for over two years awaiting a new axle, but the most recent photos on Flickr seem to suggest a few bits and pieces have been stripped.
It's been off the road since February 2019, however prior to then was in regular use. It has sat outside the workshops on the Mounthooly Way side of the depot for about two years. It's pretty easy to spot now as it's the only Enviro500 still carrying the old "The Bridges" branding.Don't think I've ever seen 38223 out and about in Aberdeen.
Do the bus companies have any recompense from the manufacturer for these long term faults? Must be an expensive repair not to mention the amount of time they are out of service.
I would have thought they would share the same drive axle as the Enviro500s in Asia too, but seemingly not, or at least if they do it's a part that's impossible to source in the UK. The whole situation seems a bit of a farce given that the axle was the only issue with 38223 and even at this stage it really doesn't need much to get going again.Is there something unique about the Aberdeen 500's? Can they not just retrofit the driveline to that fitted to any of the other batches of 500's? Would be more cost efficient than having a bus constantly off the road.
Has there been any talk of the E200MMCs leaving Aberdeen what with their unsuitability to the 13 or are they being redeployed on to other routes permanently do you know?Some updates...
Volvo B7RLE 69124 has now been withdrawn from frontline service and is currently undergoing conversion in to a driver trainer at King Street Depot, this leaves just 69123 as the only Euro3 bus left in frontline service in the fleet, however it doesn't have long either with it also earmarked for conversion.
Enviro500 repaints have stopped for now with all bar 38206/7/12/23 being done. 38206/7 were off the road receiving engine work with 38206 now back in service while 38212 is awaiting a new axle. I don't think much needs to be said about 38223... Focus has now moved back to the Streetlites with 63217 being repainted at the start of the month, 63216 this past week and 63211 being sent away yesterday.
First have lost the contract for the Balnagask & Cove Lochside Academy runs (Services 21 and 22) to Stagecoach Bluebird, they will still operate the Kincorth and Wellington Road runs (Services 31, 181, 182 & 183). Due to this the X27 has had a number of peak time journeys withdrawn, these would've formally interworked with a Lochside Academy run.
The Enviro200MMCs have been removed from the Service 13 as they cannot fit round the new temporary terminus at the Haudagain By-Pass development (Scatterburn end), as such the 13 is now being primarily operated by B7RLEs, E300s and E500s.
Citaro reliability has improved although they're still having suspension issues and 11110/14 consistently run about 5-10 minutes whenever they're allocated on the 1. 11106 returned to service in mid July for the first time since February, however it's return was short-lived as it failed in service on it's second trip and hasn't seen the road again since.
First Aberdeen Coach Hire are undergoing radical changes with plans to replace every vehicle in the fleet except the three Volvo B9Rs (20806/7/12). Coaches confirmed to be joining the fleet so far are as follows:
SG13 RYD - Volvo B9R Plaxton Elite
YY63 OJD - Volvo B9R Caetano Levante
BX65 WCY/WDF/WDG - Volvo B8R Caetano Levante II
NH63 DYH/FYH & NH14 BBH/FBH - Setra S415GT-HD (There are 3 more Setra's currently unidentified)
No word on the E200MMCs yet however keep in mind 10 more Streetdeck-FCEVs are due, as Volvo Dart notes if they go they'd have to be replaced by similar vehicles. The terminus at Scatterburn is just a temporary one so the E200MMCs should go back on the 13 once the works are finished, however they're still having issues on other parts of the route and on the network more generally. Despite all this 67085 did actually make it on the 13 today.Has there been any talk of the E200MMCs leaving Aberdeen what with their unsuitability to the 13 or are they being redeployed on to other routes permanently do you know?
Also is the focus to just get the fleet into the standard livery or are they going to start branding the E300s and Streetlites?
I don't think they do, the E500s are well out of warranty now. The issue they have is that there is 25 drive axles for 25 buses and with one pretty much away for repair constantly it means one E500 is always off the road. You'd have thought they'd just order a new axle but apparently they can't source any new or additional axles as they're unique to this particular batch of buses. It can take quite some time for each axle to be repaired and it just so happens that each time a refurbished axle has returned another E500 needs it, obviously it makes more sense to put the returned axle on a E500 that's only been off the road for a few days/weeks over one that's been off for two years.
I doubt the E500s would be going anywhere. They’ve all just been painted and plus they are required for the 1/2 routes.If the rumours are correct a small number of these could be moving to another part of First Bus - hope the recipients know what they are getting!
Five are due to be transferred down Cornwall.I doubt the E500s would be going anywhere. They’ve all just been painted and plus they are required for the 1/2 routes.
Happy to be proven wrong but i find that unlikely given they've almost all just been repainted. The four remaining Geminis 37635/36/43/44 moving to Cornwall would seem far more likely, especially given that at this end there's been rumours of them departing for quite a while, hence 37643/44 not being repainted out of Platinum livery.Five are due to be transferred down Cornwall.
Here's a full list of the coaches that have joined the fleet thus far. They're to gain a new green/gold livery with at least one example already done, rumour is that the new operating name for the coach hire business will be "King's Coaches".The fleet numbers for the new coaches are (according to First Fleet changes (wmbusphotos.com) )
20831
20851
24051
24052
24053
24054
24055
24056
24057
26001
26002
26003
Any idea to the identity of these coaches?
Thank you for this listHere's a full list of the coaches that have joined the fleet thus far. They're to gain a new green/gold livery with at least one example already done, rumour is that the new operating name for the coach hire business will be "King's Coaches".
20831 | SG13 RYD
20851 | YY63 OJD
Setra S415GT-HD
24051 | NH63 BYH
24052 | NH63 DYH
24053 | NH63 FYH
24054 | NH63 JYH
24055 | NH14 BBH
24056 | NH14 CBH
24057 | NH14 FBH
26001 | BX65 WCY
26002 | BX65 WDF
26003 | BX65 WDG
I imagine this will be from the King's of Dunblane name that they'll still have control of from when GRT bought them out?Here's a full list of the coaches that have joined the fleet thus far. They're to gain a new green/gold livery with at least one example already done, rumour is that the new operating name for the coach hire business will be "King's Coaches".
20831 | SG13 RYD
20851 | YY63 OJD
Setra S415GT-HD
24051 | NH63 BYH
24052 | NH63 DYH
24053 | NH63 FYH
24054 | NH63 JYH
24055 | NH14 BBH
24056 | NH14 CBH
24057 | NH14 FBH
26001 | BX65 WCY
26002 | BX65 WDF
26003 | BX65 WDG
Or also in reference to King Street Depot in Aberdeen?I imagine this will be from the King's of Dunblane name that they'll still have control of from when GRT bought them out?
It's a complete an utter joke, the council are now saying that the centre section of Union Street will be closed until they decide what they want to do with it long term, how long that'll be is not known but First/Stagecoach have been informed that it'll be at least until next March at the earliest.It was total gridlock in the City Centre at lunchtme today. There were 10 buses on Market Street and another 6 behind them on Union Street going nowhere.
Seriously, why aren't First and Stagecoach threatening to pull services until the matter is resolved?
It must be costing a fortune in fuel, creating worse pollution and it puts people off using the buses as they're taking over 20 minutes to navigate the Union Street closure.
(Image shows a view of Market Street, Aberdeen and buses queueing)
Bosses at Stagecoach Bluebird and First Aberdeen have revealed their buses have been sat stationary in traffic four times as much since they were diverted around the pedestrianised zone on the Granite Mile.
Their interjection came only hours before a summit with council chiefs to discuss long term plans for the pedestrianisation of Union Street – though Town House sources claimed the firms’ on-board tracking data only told “part of the story”.
This week, the local authority published proposals for the future of the city centre – including a “prioritised” push to have part of Aberdeen’s main thoroughfare permanently closed off to traffic.
It would cover the same section, between Market Street and Bridge Street, which is already blocked off as part of the Covid physical distancing measures.
Currently, only buses and taxis are allowed to turn in and out of Market Street from Union Street, with a bus gate set up at the Adelphi.
However, Aberdeen Journals recently uncovered that the camera had not in operation since the turn of the year.
Bosses of Aberdeen bus firms pen joint letter calling for access to be reinstated
Speaking exclusively to Aberdeen Journals, Stagecoach Bluebird managing director, Peter Knight, and First Aberdeen operations director, David Phillips, said: “The closure of Union Street has caused frustrating delays for people using buses to visit the city centre.
“From our on board vehicle tracking we can see that the time our vehicles are at a standstill in city centre traffic has increased by 300% when compared to that of when Union Street was open.
“We are fully in support of developments to make the city centre a more vibrant place to visit, live and work but any such development should not be at the detriment of sustainable travel choices – such as bus.
“We only have to look round the corner to Broad Street to see our very own shining example of how shared spaces can truly transform city centres.
“To support the recovery of the city centre we ask that there is no further delay in reinstating bus access to the section of Union Street which has been closed.”
In June 2020, the two firms accused the local authority of “misleading” them on plans for the temporary closure of Union Street – alleging they had been told they would retain access.
A spokesman for the ruling Conservative, Aberdeen Labour and independent coalition said: “I’m delighted that both Stagecoach and First Aberdeen fully support developments to make the city centre a more vibrant place to visit live and work.
“The bus companies will be aware the top 10 responses from the public included support for Union Street being at the heart of the city and for a pedestrianised central section of Union Street, from Market Street to Bridge Street.
“The report next Wednesday at committee is for councillors to consider all options, including the removal of current temporary spaces for people measures, and decide which options to bring back in November with detailed proposals.
“I would urge them to work with us to ensure that whatever the committee determines in November, it does so in full knowledge of the business case in front of us, rather than on board vehicle tracking that only tells part of a story.”
I'd like to know this other part of the story they reference... You don't need tracking data to show you how bad congestion is, just try getting any bus from Broad Street to Music Hall!“I would urge them to work with us to ensure that whatever the committee determines in November, it does so in full knowledge of the business case in front of us, rather than on board vehicle tracking that only tells part of a story.”
Travel like a King with King Coaches. Let us take care of all your transport needs with luxury coach hire available across Scotland. Travel in style wherever you want to go.
Our great value prices along with our clean and comfortable coaches means we can fulfill all your coach hire needs and is the reason why many of our customers have continued to use us for over 25 years.
Our friendly and professional drivers have hundreds of years’ experience between them and with their vast knowledge they will make sure your journey with King Coaches is one to remember. If there is anything we can do to make your journey more than just a journey, please let us know.
We've got a coach for every occasion!
- Business Conferences / Events & Exhibitions
- Social Events - corporate away days, concerts, sporting events
- Weddings
- School Contracts, Trips and Recreational Activities
- Private Coach Hire
- Sports Club’s
For a competitive, flexible quotation and further information on our full range of services contact our helpful staff by emailing info@kingcoaches.co.uk or call us now on 01224-219-225.
The Aberdeen coaching division is now called King Coaches:-
I think they've seen good results when they've distanced themselves from their own corporate image elsewhere as First as a brand might be recognised widely by the public but not necessarily in a good way so makes sense I reckon.What was wrong with FACH?
Or is it better to pretend not to be First![]()
