Fire in Camden Market
user15681
3 Jun 2012
Very sad to see this. Looks to be around where some of the Asian food stalls or restaurants are as you enter on the right. They're all very close together and as you'd expect, narrow passageways must only add to the spread of flames.
I've only ever had to make my way out of The Stables quickly in an emergency once and it was a nightmare, I got lost and couldn't find a way out. Exits, to me, aren't signposted well enough. It seems nobody was injured which is good.
Hopefully it's only superficial damage and nothing like bigger fires of past.
Just realised, this is right under the spur from Camden Road station on Overground to the WCML. Fortunately firefighters have managed to stop it affecting the railway. Trains still ran despite a lot of thick smoke over the WCML.
user15681
3 Jun 2012
Camden Junction to Camden Road is still closed (at 22:30) due to the fire, haven't been told how long this is likely to be for.
Instead of putting '-LB-' in the TD berth, it says 'FIRE' on the OTT maps still at 02:30. Would that suggest there is still an emergency block or does the describer showing 'FIRE' just mean that it's open but is a reminder to the signaller? If it's a block, then it's still closed hours later.
carriageline
11 Jan 2012
LB generally means line blockage, so WML wouldn't put LB in there, as it could cause confusion. They wouldn't leave FIRE in the berths because if a train came through it would take that as it's head code/overwrite it anyway.
I would of guessed it didn't update properly, or it was still blocked
Sent from my iPhone using Tapatalk
jon0844
1 Feb 2009
Isn't FIRE a headcode for a 180 run service, or perhaps a 442?
user15681
3 Jun 2012
Ah right okay, thanks for that!
GatwickDepress
14 Jan 2013
For 442s, BCON is preferred. <D
Jokes aside, it's relieving to see nobody got hurt and I hope the traders' livelihoods aren't affected - and if so, the losses can be recouped.
carriageline
11 Jan 2012
I thought there was some track circuits showing occupied on that OTT diagrams
