Fire at Laira Depot (17/04)
uvarvu
5 Apr 2016
The Evening Herald is reporting that a fire took place at Laira this morning, it started on one of the HSTs. Hope there wasn't any major damage.
http://m.plymouthherald.co.uk/fire-...-early-hours/story-30275048-detail/story.html
A fire broke out on board a high-speed train inside a Plymouth railway shed in the early hours of Easter Monday.
Four fire crews spent hours on the scene in Mullet Road, Laira, after flames were spotted coming from the shed at about 2.39am.
The blaze, which has been deemed accidental, damaged the shed's roof and the train's traction unit.
A spokesperson for Greenbank fire service told The Herald: "It took us a couple of hours to resolve as it was awkward to get to, but there is little damage to the train - it was mainly the roof above the train which was damaged.
"They were servicing it as it had been travelling up and down the tracks all evening.
"Its hard to say exactly what would have started it, I think it would be to do with overheating in the engine....
sprinterguy
4 Mar 2010
Macclesfield
Well the exhausts on them could certainly get a bit 'lively' (see attached image) back in Valenta days, but I didn't think that had been an issue since they were MTU fitted.
GW43125
8 Dec 2014
I've heard on social media that fast food packaging was found in the vicinity of the engine, which could have contributed to it.
SpacePhoenix
18 Mar 2014
What's the part that's most likely broken (presumably a part of the engine), resulting in the fire?
43096
23 Nov 2015
You couldn't be more wrong. More of an issue with fires now than there was back in Valenta days.
Cowley
15 Apr 2016
Devon
Why's that then 43096? Do the MTUs run at a higher temperature?
richw
10 Jun 2010
Liskeard
Fire brigade media spokesperson reported most damage was to the building roof, but no visible damage to the train, although he expects some engine service required
Spartacus
25 Aug 2009
Suspected injector failure from what I can gather. My first thoughts were that a birds' nest in either the exhaust or roof vent might have caused it, something not unknown in the past, though it's usually something that only starts to be a problem after being stood for a while.
43096
23 Nov 2015
It's largely been due to the temperature the turbos run at, and it was in notch 3 (rather than in notch 5 as you'd expect) that the biggest issues were experienced with.
There were some serious fires early on in the MTU programme, which saw some go back to Brush for repair. 43025, in particular, was seriously damaged; reported as the most serious fire damage a power car has ever had.
Cowley
15 Apr 2016
Devon
Thanks for that. Would it be that notch 3 was allowing carbon to build up and ignite whereas in 5 it would be running hotter and would be producing a nice clean exhaust maybe?
I must admit I hadn't heard about 43025 being damaged like that, I'll look it up later.
GW43125
8 Dec 2014
I heard there was a similar issue with the deltics-solution to an exhaust fire was thrash it to buggery!
7 Jan 2010
Was it 43025 that had the fire that was believe it or not, down to a coolant leak? I believe coolant had leaked onto the turbo and ignited.
