Finsbury Park gates & new 'waiting area'
MikeWh
15 Jun 2010
Crayford
That's how PAYG has worked everywhere for a few years - and it will be more than £5 in the peaks. It shouldn't deduct another entry charge if you have come directly from the underground though.
There was a time when the max cash fare on entry was higher for some NR services than TfL's equivalent, and at one stage the literature about Oyster PAYG seemed to suggest this charge was mainly a NR thing, but LU did charge a max cash fare as well.
AIUI the original PAYG system didn't charge a max fare on entry - but this was fixed after a while, MikeWh might know the exact timescales I expect...
Yes, the original system when Oyster was first rolled out to the Underground did not include a maximum fare deduction. It was introduced when they saw how many people from 'open' stations only touched when they needed to operate gates. I don't know when it changed, sorry.
As far as I know the maximum fare within zones 1-9 is always the same. There are different (higher) values at Watford Junction and the Grays area. Otherwise it is the relevant (ie peak or off-peak, discounted or full fare) fare for a 6-zone journey using both NR and TfL in zone 1. If you have a travelcard season loaded then the reduced maximum fare when touching outside the zones covered by your season is a zones 1-4 journey using NR and TfL in zone 1. I believe that this has been the case since Jan 2010.
W-on-Sea
18 Dec 2009
My recollection is that the maximum fare deduction was introduced about 18 months after Oyster was first introduced. (So, around April 2005?). Before then there was no charge for making an incomplete journey (ie not touching in or out at the start or end of the journey.)
My understanding that the initial manner of operation was simply a transitional measure, intended to allow people to become familiar with using Oyster pre-pay/PAYG, and that it had always been intended to introduce a maximum fare deduction - delaying its introduction was a means of minimising the number of instances in which passengers would be wrongly overcharged. There was an extensive advertising campaign telling people to always touch in and out when the maximum fare deductions began.
