FGW trains idling at Oxford sidings overnight
starrymarkb
4 Aug 2009
Exeter
I think that might be overdubbed, there are whistles and other noises that don't sound right for sidings
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
I believe that was a track been repeated - & recorded on a station whilst a DMU is Idling.
Yes there are whistles & I can make out a Door Closing Beep aswell.
the sniper
4 Sep 2007
At one point I'm sure you can hear an EMU departing in the distance! What poor deluded fool has put this video together? :|
And yeah, I'm pretty sure they are left on overnight, though they make nowhere near that amount of noise.
Dai.
2 Aug 2008
Wales
Oh right, the noise isn't a major issue if they aren't too loud, but then pollution is the problem.
route:oxford
1 Nov 2008
Always makes me laugh really.
Oxford City Council Councillors go on and on about vehicle "fumes" poisoning Oxford and place restrictions on new build properties from having parking in order to reduce the "fumes"... Yet the depot in the heart of the city pumps tonnes of CO2 into the air every year.
Oxford County Council could, of course, help the issue by co-sponsoring the extension of electricification from Reading to Oxford or even Banbury
RPM
24 Sep 2009
Buckinghamshire
We're having similar problems from local residents around Aylesbury South Sidings. The flats were only built recently but they seemingly have the law on their side in these matters. Now the trains have to be shut down after they've been cleaned at night so early morning passengers from Aylesbury can expect freezing cold trains and cancellations due to faults that would have been rectified had the trains been left running.
It seems anyone can build residential properties stupidly close to working railway yards and then the resulting residents can prevent the railway going about its legitimate business with the full force of the law. Crazy.
starrymarkb
4 Aug 2009
Exeter
Same happened with Exeter's nightclubs - there was a little entertainment corner on the quay, then someone built a large estate down the in the mid 80s (next to the pre-existing clubs), now all but one of the clubs have had their licences revoked on noise grounds (and the other IIRC is restricted)
Drsatan
24 Aug 2009
Land of the Sprinters
Usually in the sidings adjacent to New North Road (near Exeter St Davids) there are at least two 159s idling during the daytime waiting for use on Waterloo services. I've also noticed that an HST is stabled at those sidings overnight. But I'm not sure whether the engines are left idling at night.
I'd have thought that leaving the train's engines running at night would be very wasteful of diesel anyway - couldn't a train be 'plugged in' somewhere so that heating, lighting and other auxillary functions could operate?
merlodlliw
8 Mar 2009
Couple of comments.
1.In the the days of steam, all coal fired were kept running all night speciality in winter.
2. I understand the 57s on the WAG are kept on tickover all night,I am told they are awkward to start up cold.
3.As for carriages in the old days, did they not warm them from a stationary loco,ive often heard this quoted.
4.I noticed at Inverness a few years, the beds were plugged into the mains to keep them warm during the day.
5. As for waste of diesel by being kept running, who knows, I would not expect to see a new GM 66 etc, ticking over for hours while idle.
455driver
10 May 2010
You will see it with a 59 though, the batteries are so small it is unlikely they could start the engine if it got too cold.
I believe a 66 is electronically restricted to 85% power until the engine warms through so some drivers keep them running so full power is available from the start.
GB
16 Nov 2008
Somewhere
66's don't like being shut down and restarted all the time so if you go to any significant sized yard that has them Im sure you will find plenty that are left ticking over for quite a few hours.
The only time really they are shut down is during times of significant down time (eg 12 hours +) or where local instructions dictate.
When started from cold you will often have to wait for the pre-lube cycle to finish before the engine will start which takes about 15 minutes, and even then the engine may be restricted to notch 3. Pretty useless for anything other than LE moves or a very light train...also a fair bit less then 85% power as previously stated.
455driver
10 May 2010
In my defence I did say "I believe", didnt realise the restriction was that severe :shock:
455driver
10 May 2010
Hey no problem boss, you didn't come across that way at all.
So basically when you start a 66 from cold, you wait 15 minutes for the pre-lube then when it starts you only get notch 3, so they are useless for about an hour then, modern technology don't you just love it <D
Dennis
8 Aug 2005
Trowbridge
:idea: Could always construct a lovely 15 foot high concrete wall to act as a sound barrier; this would have the added advantage of ensuring residents overlooking the sidings are not having to put up with trains spoiling their views.
I hear power stations are on all night too? Why don't they shut them down? The sun also continues to burn throughout the night, that should be stopped too ;)
Seriously though, on continent that line would have been electrified decades ago. Crossrail should go to Reading and the lines from Reading to Bristol and Oxford, at a minimum, should be wired. Back in the days of less waste, the amount spent on allowing trains to tilt at 125 on the WCML could have electrified almost all major routes.... :|
Metroland
20 Jul 2005
Midlands
Not long ago, none of those flats and houses around the sidings were there. The railway made a quick buck selling off the land, and developers made a fortune selling tiny flats in one of the most expensive places to live in the country.
If you move into those flats, expect the noise. Those sidings are in use 24 hours per day, and freight and passengers trains belt through every few minutes even at 3am. There's around 600 trains per 24 hours at Oxford. This is nothing new, its been a busy 24hour line for well over 100 years.
Trains are normally left on if they are being shunted around, this tends to go on till 3am ready for the morning as they tend to be reformed and sent backwards and forwards to other depots for fuel and maintenance.
Rail is a tiny contributor to Co2 in the UK, around 0.7%, about the same as the 21 million domestic flight passengers, less than buses, and a fraction of that of cars and trucks.
Perhaps planning permission should never have been granted to build the flats, but the railway was there long before any of them, or the people who live in them were there. I'd suggest they live with it or move.
142094
7 Nov 2009
Newcastle
IIRC going back to geography at school, we had a case study about industry and building houses nearby. At one time the law took the side of whoever was there first - so in most cases the railway wouldn't have to answer to complaints by people living in the new builds. However I'm not sure this applies anymore, I've heard stories where people have complained about the noise from industry etc and the local council have put in an enforcement notice.
As for the planning permission, there are a whole load of regulations about sizes of windows, number of windows, type of windows and other stuff where a development is next to something like a railway. But people will still complain.
90019
29 May 2008
Featherstone, West Yorkshire
Yes, but if you electrify it, you get those nasty pylons ruining the views! :lol:
NIMBYism strikes again.
Maybe the people didn't realise the railway makes noise? :lol:
142094
7 Nov 2009
Newcastle
Just imaging what the Victorians thought, all that noise from these new fangled machines! Got a radical idea - give everyone who complains a set of ear plugs. If they're not satisfied with that, put some sellotape around their gobs. Problem solved.
Aictos
28 Apr 2009
Take Hertford for example, railway arrived in 1924 and local resident arrived in 2006 - guess who wins the battle of noise polluation?
Yep, the local nimby so trains stabled in the bay have to have their pans dropped, only thing is though it takes twice as long for the trains to be prepared then if they were left alone!!!
Local health and safety officials say the railway is in the wrong as being noisy, we are preventing him from enjoying a good night's sleep never mind the fact that the railway was there much longer then him.
Isisbridge
11 May 2010
According to the person who compiled the report on this matter (not me) there are at least 35 land-based power packs on this site, to enable functions whilst the train is not in use, but apparently the drivers don't bother to use them, preferring simply to leave the engines running.:cry:
(uploader of Oxford railway sidings video)
Many of the local residences were here before this noise pollution started. I accept that some amount of noise is to be expected, but it is wrong to be subjected to unnecessary amounts of noise simply because of bad practice. Have you actually thought about what it is like to be sleep deprived night after night? There needs to be a reasonable compromise.
Just imaging what the Victorians thought, all that noise from these new fangled machines! Got a radical idea - give everyone who complains a set of ear plugs. If they're not satisfied with that, put some sellotape around their gobs. Problem solved.[/QUOTE
Not a well thought response. Ear plugs do not block the throbbing vibration sound emitted by these idling engines. Nor do they block the fumes.
Some of your information is not quite correct here. Firstly many of the houses and flats (including mine) were already here before this noise problem started, although it is true that a lot more have been built since then.
It's not true that freight trains belt through every few minutes. The line is relatively quiet, and in any case that is not what is being complained about.
Trains are not being shunted around till 3am. There is in fact no movement on the sidings during the middle of the night. The noise comes from stationary engines left idling in the same spot.
People should not have to live with unnecessary noise or be forced out of their homes because of bad practice on the part of the employees.
Anyone else notice the guards whistle at 01:48? *rolls eyes...*
I'm finding it really hilarious, the number of railway experts that can't tell the difference between a guard's whistle and a duck! Well actually it's probably a MOORHEN. Trying googling for the sound of the common moorhen and you'll see what I mean. This video was recorded beside a canal. (It does say canalside right near the beginning of the clip.) There is a canal and a small river in the foreground of this video, and you do get a lot of wildlife sounds as well as noisy engines. :lol:
http://www.youtube.com/watch?v=DPmSnYjBEHg
Just found this video. Some of the statements seem a bit extreme. Thoughts anyone?
And yes, you can't see the train that well.
Can you specify what you find "extreme" about these statements and then maybe I can explain things?
There is no overdubbing on my video. It is exactly as it came off the camera, apart from the addition of titles. The sound has not been altered in any way. The "whistle" that you think you hear is actually the sound of a waterside bird, probably a MOORHEN. I'm amazed at you people that can't tell the difference. :lol:
My video was recorded outside my lounge door, which is opposite the railway sidings, with a canal and a river in between. I certainly wouldn't go to the bother of making a recording on a station when I can hear enough engine noise in my own home. The "whistle" that you think you can hear is probably a MOORHEN but certainly not a guard's whistle. I don't know what the bleep is (as I'm not a railway expert) but that came from the sidings.
Are trains left on overnight?
:s
Yes, trains at Jericho (Oxford) railway sidings are certainly left running ALL NIGHT. This has been occurring virtually every night (except Sat/Sun) for months on end during the last two winters. Although there has been an improvement during the last couple of weeks, with engines switching off at maybe around 1.15am.
Ah, so I am having delusions am I when I imagine I can hear all this noise from the sidings during the night? And all the other people who complain about it are having delusions too? A case of mass delusion perhaps? Or perhaps it is YOU who is deluded in thinking that I am just a poor fool? :roll:
Would appear so. I used to live near these sidings and remember them being on all night. I didn't suffer from asthma as a result though!
Not everyone suffers from asthma, and I don't myself. But I know of some people living near these sidings having to move because of it. There are certainly noxious fumes in the air, and I have on many occasions had to shut my back windows because my lounge has been flooded with the smell of diesel. Fortunately my bedroom is on the opposite side of the building, so I am able to have a window open on the other side. But when I've left my back windows open on a hot summer night, I've often been woken to the diesel stink at around 5am and had to dive under the duvet to get away from it.
Some Oxford City Councillors are aware of this problem and have had meetings with First Great Western, but to little effect. :cry:
If the trains are cold, let the passengers wear jumpers. This was a residential area long before FGW started causing this problem, and I feel cold when I haven't had a proper amount of sleep.
I did hear it,
I still can't see the train though..
More guard's whistle delusions! It is some kind of waterside bird, probably a MOORHEN. The reason that you can't see the train very well is because it is quite a long way off, where that bright light is shining. There is a canal and a river in the foreground, and a load of trees.
Apparently it's a duck. However I'm not totally convinced, this is what whistling ducks sound like...
"Ducks" is what I call them, but probably a MOORHEN. Try googling for the sound of the common moorhen. There's a lot of them down here by the river and the canal. :lol:
Pumbaa
19 Feb 2008
Oh dear...
Pure NIMBYism. Unfortunately the railway was there before the residential developments; I can see no case for residents complaining if fGW decide, and are at liberty to decide, that it is to their maintenance and passenger benefit to leave their engines idling.
It is still a service, after all the privatisation. To suggest "they wear jumpers" you've turned into Marie Antoinette.
