FGW Sleepers
turbo mick
17 Aug 2005
reading
Did the Up sleepers Fail last night i saw the stock going through Reading Empty about 0730 with EWS 67 on the front
cheers
mick
adc82140
10 May 2008
I saw it skulk through Twyford platform 4 at about 7:40- 57604 was dead in tow- must have disgraced itself. No sign of the stock at Paddington at 8:20 though- where did it go??
devon_metro
11 Oct 2005
Failed Bridgewater. Dragged to BRI by 66/6 and passengers dumped onto 0600 Bristol Paddington
turbo mick
17 Aug 2005
reading
probably was going ecs to Old oak the 57s have been strugling of late seen virgin 57s around at Old oak recently.
compension for pasangers i guess
cheers
mick
fgwrich
15 Apr 2009
Hampshire
57603 is at Brush, which means 100% Availability needed, failures and hire-ins will occur :)
Well, This is the reason why Brains is on short term hire...Same will happen when 604 goes for refurb and re-livery...
As for where did the stock go? straight into OOC... no need to run it into paddington if its failed...
rich
adc82140
10 May 2008
Didn't know OOC had access directly from the west- you learn someting new every day :)
I've often wondered though why FGW don't acquire some of those spare DVTs and stick them on the end of the sleepers- OK I guess a bit of modification would be needed for them to work with the 57s, but it would halve the amount of locos needed.
jopsuk
13 May 2008
Or stick DVTs on and lease 67s- go for the full WSMR-style modification to stock and locos
CCF23
12 Dec 2008
I saw Virgin 57309 at Paddington on the morning of 5th September. What i never understand is that the 47's are still reliable whereas the converted 57/6's are failing.
43034 The Black Horse
2 Dec 2007
Needing 100% availability will make failures more known. Because there was a lot of duffs about, if one failed, another came out and no one, except a few, are none the wiser!
But when a 57/6 fails you know about it as there is a higher-in etc etc.
2030720310
20 Jan 2009
I think it's stupid that FGW have to have 100% availability, trains are inevitably going to fail sometimes!! I don't think they've thought this through....
MCR247
7 Nov 2008
If you read the thread completely, it said Its only for the moment while 57603 is at Brush
turbo mick
17 Aug 2005
reading
the reliability of the locos are some what up and down i saw 3 loco,s in old oak this morn.
getting into old oak requires a run round in kensal green unless loco each end.There is a emergency arrival which involves going through the Heathrow express sidings which is not used very often.Everything arrives from the east of old oak (paddington end)
mick
Drsatan
24 Aug 2009
Land of the Sprinters
Today when walking back from a nightclub in Exeter at about 01:30 I saw the up sleeper pass from the opposite side of the road. I couldn't see the number but it was definitely one of the Virgin 57s.
devon_metro
11 Oct 2005
57308 Tin Tin
1C99 Down Midnight involved in fatality near Totnes. Monday morning services to London thus up the creek.
fgwrich
15 Apr 2009
Hampshire
Parlty becasue the 47's are the best part of nearly 50 years old...Which if you think about it, when they were built between 1963–1968 they had 2,750 bhp...later derated to 2,580 bhp...and still losing power ever since...
My point being the older the loco is, the less powerfull it becomes, and the less reliable it becomes...Hence the reason why Virgin wanted to replace there 47 hauled sets with the Voyagers, EWS with 67s, Frightliner with there 57s and FGW...
Afterall, look at all the main line 47 left now, how many of them are 100% totally reliable...
The main fauilts with the 57s are coming from the turbochargers amongst others things...
Then of course 604 is due for overhaul next...
mick
Kensal Green Reversal Sidings from the west, Old Oak Common Flyover from the East...
57308 Tin Tin
Feelings for the Driver and crew and passengers on board...
turbo mick
17 Aug 2005
reading
hi there i noticed FGW 57 running round on the down goods at Reading with the sleepers stock about 1500 yesterday
cheers
mick
