FGW diversion aug 2-3 - where does it go?
Kristofferson
23 Nov 2012
I'm currently on a FGW HST (1B25 PAD - Swansea) which is one of many being diverted due to engineering works around Didcot Parkway.
I'm curious to know which lines it visits on its diversion from the GWML?
bolli
26 Sep 2011
Melksham.
louis97
14 May 2008
Derby
After Reading you'll diverge to the Westbury lines and you'll travel through Newbury then up to Heywood Road Junction near Westbury then around the curve to avoid Westbury (only used once a day on weekdays) to Hawkridge junction then through Trowbridge up to Bradford Junction then off via Melksham to Thingley junction then through Chippenham to Swindon. Then after a reversal back to normal route. All of the route has regular HSTs all day apart from Heywood Road Junction to Thingley Junction.
cambsy
6 Oct 2011
There is no reversal if doing Taunton-Westbury-Trowbridge-Melksham-Swindon-Reading, did this route non stop when the Dawlish route was shut.
Kristofferson
23 Nov 2012
Thanks for the in depth answer :) wasn't sure whether to change seats when we started going backwards! Still not sure now to be honest!
fgwrich
15 Apr 2009
Hampshire
Ah, thanks for this. That would explain why Colas Rails 56113 & 094 came hammering through Theale earlier with a set of steel wagons earlier.
