FCC Evening Peak
sliver
3 Sep 2012
As always, I'll begin by making excuses for my fare naivety.
Now that is out of the way, I need to travel from Luton - London (assume St Pancras) on Thursday 11th Aug leaving Luton around 11 and returning around 17:15. I have a network railcard.
The FCC evening "peak" has always confused me; TOC marketing made me believe you couldn't use an off peak ticket between 16:30 and 19:00 (I now, thanks to you all, know better, well a little better).
If I get it:
I can't use an off peak day return or off peak travelcard between 16:30 and 19:00.
I can use an off peak single from St Pancras to Luton anytime in the evening peak
I can use an off peak return (but not between 17:30 and 18:30 if I have read and understood this from FCC "Travelling on an Off-Peak (formerly Saver) ticket
Both outward and return portions of this ticket are not valid for journeys which depart Moorgate, Kings Cross or St Pancras International (including pass throughs) between 1730 and 1830 Monday to Friday.
So looking at the above, I can get an Off Peak Return for £16.05 with network railcard discount, I can use this to return from St Pancras to LUT anytime in the evening peak except between 17:30 and 18:30.
Is this the best value ticket for my journey as stated, or does anyone have any better tips/ ideas please
Thanks
bb21
Emeritus Moderator
4 Feb 2010
If I get it:
Assuming you are referring to the Luton - London Thameslink Off-Peak Day Return or Luton - London Zones 1-6 Off-Peak Day Travelcard, both use restriction code LS.
Your understanding is correct.
There is no Off-Peak Single. If you mean the £14.30 Off-Peak Day Single, the restriction code is TN. The restriction text is missing on National Rail Enquiries but the full text is as below:
Restriction TN said:
Restriction : TN
Valid as listed below MONDAYS-FRIDAYS (Valid any train on other days)
Outward Travel
Valid on any train EXCEPT those timed to Depart between 04.30 and as listed below
Brighton__________________0900
Preston Park______________0911
Hassocks____________ 0909
Burgess Hill 0912
Wivelsfield 0923
Haywards Heath 0918
Balcombe 0937
Three Bridges 0927
Gatwick Airport 0932
East Croydon 0932
Elephant & Castle 0902
London Bridge ____0909
London Blackfriars ____0902
City Thameslink ____0900
Farringdon _______0900
London St Pancras Int. 0900
Kentish Town _________0900
West Hampstead Thameslink 0904
Cricklewood _0907
Hendon _______0900
Mill Hill Broadway________0904
Elstree & Borehamwood _ 0901
Radlett _0906
St Albans _________0909
Harpenden _____0904
Luton Airport Parkway____ 0902
Luton _0905
Leagrave _____________0917
Harlington 0859
Flitwick 0903
Return Travel
Valid on any train EXCEPT those timed to Depart between 04.30 and 09.30
So your understanding is correct in that case.
Restriction 5J whichever way round the ticket is.
Correct.
Tetchytyke
12 Sep 2013
Isle of Man
You cannot use the return portion of a ticket before the outward portion of the ticket. You cannot buy a STP-LUT off peak return and use it to travel LUT-STP before you travel STP-LUT.
sliver
3 Sep 2012
Thanks, badly written on my part perhaps. Travel from Luton to London first, it was the evening peak return journey I wanted clarity on (which I think I now have) :idea:
stephy
25 Mar 2011
so you're telling me I can use a c.£14 off peak day single farringdon/st pancras to bedford between 4.30-7pm? when all this time i've been buying the £16 peak single?? (with YP railcard discount)
bb21
Emeritus Moderator
4 Feb 2010
Yes, same for the Bedford tickets with this one.
stephy
25 Mar 2011
you are kidding me. so for weeks now i've been paying £2 extra...
and is this valid on EMT too? how does the evening peak ACTUALLY work? i did a search but ended up on silver's old/confusing thread..
and re: excessing fares other than penalty faring them, EMT always say 'if your ticket isnt for this service you will be charged a whole new one at maximum fare' so thats not actually allowed ?? they should just excess it?
bb21
Emeritus Moderator
4 Feb 2010
A London Thameslink/Terminals - Bedford Stations Off-Peak Day Single (£21.50 / £14.20 with R/C) takes restriction code TN.
As you can see from the restriction text I quoted above, there is no evening restriction.
I have a sneaky suspicion though that it may be a mistake in the restriction code, but as things stand, it is valid on trains in the afternoon peak as there is no afternoon restriction.
Peak restrictions are defined by the restriction text each ticket is associated with (through a restriction code). There is no uniform definition what "peak" is. Each ticket is different.
You cannot be charged a Penalty Fare if your ticket is only invalid due to a published time restriction, eg. using an Off-Peak ticket at a restricted time. The correct course of action in these situations is to issue an excess fare for the difference between the ticket held and the cheapest walk-on ticket that would be valid for the journey made. The ticket mentioned above is routed Any Permitted so there is no operator restriction. Any Penalty Fare issued under these circumstances are invalid, and shall be declared so upon the appeal being lodged.
I believe the announcements you mentioned on EMT actually relate to not travelling on the correct service reserved for an Advance ticket, rather than tickets with time restrictions, in which case the maximum fare cannot be charged, but the cheapest walk-on fare if the passenger is on an incorrect service but the correct route / date / operator.
You have to look at the wording of the restriction text for the specific ticket(s) you hold.
The easiest website to use is BRfares.com, which is an unofficial site.
stephy
25 Mar 2011
so what do i say to the EMT staff tonight who try to say my 'off peak' £14.20 ticket is invalid? they've done this before - genuinely thought i'd done something wrong so have been being honest and paying the peak single all along
what is the point in the peak single then?! can't believe this
bb21
Emeritus Moderator
4 Feb 2010
As I said, I suspect that the restriction code may be an error.
If this happens again, politely request that the guard looks up the restriction text for your ticket. If he refuses and insists on charging you an excess, I would say pay it and claim it back afterwards.
It may also be helpful if you can print out the restriction text for your ticket and carry it with you.
stephy
25 Mar 2011
I think I should print it from an official source and not this forum? I couldnt find it on the BR fares site
Or just the wording above will suffice?
bb21
Emeritus Moderator
4 Feb 2010
The relevant page appears missing on NRE.
This is from BRFares. You can also just print out this page.
The guard should have access to the fare details on his machine.
stephy
25 Mar 2011
Thank you very much.
Not looking forward to when this railcard runs out.. 2 months before i'm 27 mind. done well!!
what does the bit about when the restrictions do NOT apply mean?
stephy
25 Mar 2011
near the end, says restriction code R1 this restriction card does NOT apply on the following days
and lists some dates
bb21
Emeritus Moderator
4 Feb 2010
That's to do with journey planner internal workings. Not really of concern to the passenger (and anything else after the title "Unpublished Restrictions"). I believe the part you referred to relates to Railcard minimum fare, which do not apply on Bank Holidays and at weekends.
maniacmartin
Fares Advisor
15 May 2012
Croydon
The bit where it says when the restrictions don't apply under the red heading lists weekends and bank holiday Mondays.
The more interesting bit is the left column near the top under the green RESTRICTIONS bar, which is the actual restrictions text
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
I don't see why the lack of afternoon peak restriction heading out of London on the Off-Peak Day Single & Return (restriction TN) should be a mistake. The biggest market for Off-Peak Day Returns is most likely people leaving London in the late morning / early afternoon, and heading back against the evening peak flow (which is out of London).
bb21
Emeritus Moderator
4 Feb 2010
Do they really want to offer Off-Peak Day fares to people travelling with the afternoon peak flow? With an afternoon restriction heading out of London they could still be useful to those people you described.
The number of passengers using this ticket in the afternoon peak may well be small enough not to bother FCC.
I don't know for sure it is a mistake, just a hunch, especially with the restriction text missing.
Paul Kelly
16 Apr 2010
Reading
I suppose if FCC thought the market for Off-Peak Day Singles was much more likely to include people travelling out of London in the evening peak they could change the restriction code, but since there's only 10p difference (5p with a railcard difference), affected passengers could just buy the return instead!
bb21
Emeritus Moderator
4 Feb 2010
To be honest, it is not even FCC I'm concerned about. The OP mentioned getting in trouble on an EMT service, and the cynic inside me can picture them dropping FCC some "hints" if they don't like it.
Of course collusion is not officially permitted, but it's not as if the railway industry are squeaky clean on that front.
Paul Kelly
16 Apr 2010
Reading
Yes, I think I maybe see what you mean now, though - it's not really a "mistake" the way it is, but rather a missed opportunity to be more draconian!
talldave
24 Jan 2013
FWIW the TN restrictions listed in post 2 are wrong, you need to subtract a minute from all those times. For example, a TN ticket IS valid on the 09.32 from Gatwick.
I started a thread on this but am on a phone at the moment so not easy to cross reference.
RJ
25 Jun 2005
Back office
Tell them I said it's valid. That should be good enough to see you through!
bb21
Emeritus Moderator
4 Feb 2010
You may want to provide the OP with a reference to help him.
That is all I can find from NFM18.
:lol:
Stats
27 Sep 2009
You are correct according to the ticket restriction text on NRE
http://www.nationalrail.co.uk/ticket_types/restrictions/TN
Outward Travel
Not valid for travel on trains timed to depart after 04:29 and before the times shown from the following stations:
•09:00 from Brighton
•09:11 from Preston Park
•09:09 from Hassocks
•09:12 from Burgess Hill
•09:23 from Wivelsfield
•09:18 from Haywards Heath
•09:37 from Balcombe
•09:27 from Three Bridges
•09:32 from Gatwick Airport
bb21
Emeritus Moderator
4 Feb 2010
Hmm, so NFM18 is wrong. How interesting!
Seems like the NRE restrictions page is also all over the place too.
