TheSlash
Does anybody else have a favourite bit of road?
Mine used to be the A2 from it's junction of the M2, to the cross roads near Shepherds Well, but i've replaced it with a monster of a road
A265 Etchingham to Hurst Green, in that direction.
From the left hander out on Etchingham high street, you are looking for Etchingham barriers. If they are up and the road is clear, then boot it.
From there, it's a brilliant climb to the summit, down through the gears for each corner, then accelerating away towards the next one.
Definitely one of the things to do before you die :grin:
The road is a like a skill level due to it's width. The first few corners are Amateur, then it tightens up for Semi Pro before a last few white knuckle tight corners and away to Hurst Green
