XC services from Croydon stopped later than King's Cross Thameslink closed (Dec 2008 versus Dec 2007). The board clearly predates both of them. Does it have any WCML stations north of Watford?
Surely Milton Keynes should be on there?
East Croydon's only had direct services to MK since 2008 (and also before about 2000 in the days of Connex).
I find the same thing with Piccadilly.Good idea in principle but (like most CIS sytems) let down by the implementation. You can see on the OP photo that only stations Liverpool-Z are visible and every 10s or so it swaps to show the first half of the alphabet, with a seconds or so of blank before it refreshes. I usually find I'm just about to locate the station I want when it disappears, so I just refer to the small orange LED screen facing the entrance that shows the next few departures (I know which train I'm aiming to catch in any case).
I have the same problem with the screens that swap between pages 1 and 2 of 2, though as there is less information on the screen I find I get more chance to find what I want.
Does Marylebone still have red departure indicators? I think it did last time I visited, circa 2001!
I'm not sure I'd trust the departure boards at Manchester Piccadilly - well not when you've seen the arrivals board displaying this 'special notice'...![]()
Actually one downside is that they only show direct services and can't advise you when it would be quicker to change somewhere. Such as the one at Salisbury; I could see confused passengers waiting two and a half hours for the next advertised direct train to Cheltenham, when in reality they should have got the next train to Bristol and change there.
Looks like this good weather got to their head a little bit...still, a good way to confuse the tourists :P
With the rise of inexpensive e-paper surely you could go for greater and greater display areas?
With a corresponding increase in computing power required as the pixel count goes through the roof :P
Although seriously, that is a good idea (and if you make the pixels suitably sized not one that a single desktop PC couldn't handle);
the only problem is that e-ink needs some form of illumination, either by backlighting it like an LCD monitor, which could be expensive electricity-wise, or using the existing station lights to spotlight it, which would not give a very reliable or consistent luminosity.
