Fares article (from Railtalk magazine)
Here's my latest fares article that appeared in the October edition of Railtalk magazine (which is available as a free download)...
London Bridge fares rip-off
A couple was heading from Headcorn to London on a weekday morning, wishing to arrive for around 10am – the arrival time that most out-boundary off peak day travelcards become valid. However, on close inspection, the 10am rule applies to the time that the train is scheduled to arrive at “London Terminals” – normally this is very straightforward. But in the case of through trains calling at London Bridge, these call at two or three London terminals – so which one does the 10am rule apply to? We put this to the test and according to Thetrainline, the 0859 from Headcorn to London Bridge (arr 0957) gave a price for a peak travelcard of £32.30, while specifying London Charing Cross (arr 1007) gave a price of an off-peak travelcard at only £18.50!
As the couple were heading to a suburb of London, they had been advised to change at London Bridge, therefore quoted the higher fare. When they asked at stations and by telephone, they were given differing answers, and even told they would “have to check when they got there”! This is unacceptable and confusing for passengers, as one of them remarked, "I thought they said on the news they were making tickets simpler? No one seems to understand them, including the railway!" In reality they purchased the cheaper fare and encountered no problems. I wonder if RPIs ask passengers if they are alighting at London Bridge in order to determine validity? If passengers say they are continuing to Charing Cross, then RPIs will have to accept the tickets. I wonder how many unsuspecting people are caught out by over-zealous RPIs on trains through London Bridge?
Train companies make a simple journey very complicated
A resident of Royston contacted us recently about a journey to have a weekend in Manchester, out on Friday and returning on Sunday. He searched for a through ticket – as surely, this should be the simplest option – from Royston to Manchester, however the return journey on Sunday gave him this ridiculous itinerary:
Code:
Station         Arr   Dep Service Provider
MANCHESTER PICC       16:07 Train NORTHERN RAIL
SHEFFIELD       17:32 18:02 Train NORTHERN RAIL
RETFORD         18:43 19:37 Train HULL TRAINS
GRANTHAM        19:56 20:58 Train NATIONAL EXPRESS EAST COAST
PETERBOROUGH    21:19 21:45 Train FIRST CAPITAL CONNECT
HITCHIN         22:28 22:47 Train FIRST CAPITAL CONNECT
ROYSTON         23:04
Previously, he has been able to take the quickest, and simplest, route changing trains at Stevenage and Doncaster. However, this option is no longer being offered. On further investigation we discovered that the reason for this is that this route is no longer a permitted route according to ATOC’s routeing guide. The reason is that NXEC have re-named their expensive 'Business Saver' tickets as 'Off Peak' tickets, while former 'Saver' tickets are now 'Super Off Peak'. Other TOCs operating along similar routes price their tickets rather differently, and therefore their 'Saver' tickets became 'Off Peak'. Other TOCs operating along similar routes price their tickets rather differently, and therefore their Saver tickets became Off Peak. So, the ‘fares check’ rule that determines valid routes no longer allows travel via Stevenage as the fare from Stevenage is no longer a like-for-like comparison with the fare from Royston and is therefore artificially higher than it should be.
The reasons for this ticket becoming more restrictive than previously are complex, and well beyond the comprehension of a regular passenger, but the end result is simply unacceptable and ATOC are, ultimately, to blame for allowing each TOC to do it’s own thing with no regard for passengers using services using their trains but on tickets priced by other operators.
Ultimately, our friend from Royston was able to get a far better deal by splitting tickets at Doncaster. This gave him an excellent TPE advance fare between Manchester and Doncaster, and NXEC advance fares from Doncaster to Royston, via Stevenage. Departing Manchester over an hour later, at 17:15, he actually passes Retford non-stop at around 19:25 – certainly beating waiting at Retford from 1843 to 1937 seeing this train fly past – and finally arrives at Royston at 2042, a mere 2 hours 22 minutes earlier than Thetrainline wanted him to arrive.
So the lesson here is that the TOCs do not care about you if you are using a route that it not directly served by them, and it can be cheaper and quicker to split tickets at one or more stations en-route.
NXEC guard wrong, says ATOC
On Saturday, I was travelling on the 16:10 National Express HST service out of Edinburgh. The Dundee to London Kings Cross service was, for this weekend, diverted via Carlisle due to engineering works between Edinburgh and Newcastle. Eventually, I noticed that the guard was taking an extremely long time checking tickets, and only got to us (in Coach E) approaching Gretna. I was about to find out why his checks take so long….
On showing him the tickets, routed 'Carlisle', he astonished me by stating that “We do not accept tickets routed via Carlisle”, the fact that the train went via Carlisle was ignored. He further shocked me by stating “This is a Cross-Country ticket”, I showed him a reservation for the 17:55 NXEC service. “We don’t have a 17:55, that must be a CrossCountry service. You should really be on that train. But, as you are on an Off Peak ticket, you can use an earlier train, but it must be operated by CrossCountry” I could hardly believe what I was hearing! He finally agreed to “let [us] off”, with a warning not to do it again. I most certainly will be doing it again.
For the record, the 'Route Carlisle' tickets, are most certainly not TOC-specific, and indeed cannot be used on CrossCountry between Carlisle and Edinburgh as CrossCountry have not operated via Carlisle for many months now!
ATOC were contacted about this issue, and confirmed that these tickets are valid on NXEC. Not only that, but they also confirmed that Preston to Edinburgh 'Route Carlisle' tickets are valid via York, Newcastle and Carlisle – although only on direct services between Newcastle and Edinburgh that run via Carlisle. The reason is that Preston to York is permitted via Newcastle. A 'Route Carlisle' is valid for permitted routes that travel through Carlisle, which these trains do during engineering works.
I should point out that the vast majority of NXEC guards are sound, and accept Carlisle tickets as they should, without question. It is only a small minority who treat their customers like dirt.
voyagerdude220
13 Oct 2005
Many thanks for your article, Yorkie! :D
I'm glad that i've never actually been on a walk-up kind of ticket before, when i've used NXEC, or previously GNER, as they could have fooled me into thinking that it was invalid, when it actually was.
Noting your Preston-Edinburgh CDR routing... How long are the diversions running for via Carlisle, for NXEC?
I'd like to use that CDR sometime myself via the ECML, if i can work out a journey which includes Preston-York-Edinburgh via Carlisle, as i've not covered the Newcastle-Carlisle line yet..
I wonder if Northern Guards are aware that the ticket is valid? I don't want to be kicked off the Northern train before I even get into York!
You're welcome!
2 more weekends.
It takes all day.;) I got reservations on the 1030ish ex-YRK as this was the first with a connecting train from Preston, and on the 1755 ex-EDB which had an overnight fester at Leeds. The guard only came round between EDB and CAR and said the ticket was invalid for that section, let alone beyond CAR. I did not argue the case that the ticket was valid via Newcastle as he was getting off at Carlisle anyway so it was irrelevant and pointless to have that discussion. All other guards rightly accepted the ticket, York to Newcastle, and on the Tyne Valley, when it could have been questioned.
I've also realised I made a mistake about that Royston ticket. I said that "..no longer allows travel via Stevenage as the fare from Stevenage is no longer a like-for-like comparison with the fare from Royston .." I was trying to keep it simple and not include any Routeing Guide jargon, but the actual situation is that Stevenage is no longer a valid 'routeing point' for that journey, meaning that the 'mapped route' via Stevenage and Doncaster is no longer available. But you can still go via Stevenage as changing at Hitchin is on the shortest route (and you can double back between Hitchin and Stevenage), HOWEVER the shortest route is then via Retford to Sheffield direct and not via Doncaster, hence the ridiculous timings given. (In reality, you could get away with going via Stevenage and Doncaster but the ticket issuing systems won't offer it.)
voyagerdude220
13 Oct 2005
I don't mind a day out ;)
After all, i am booked on the 05:17 ex Preston southbound very soon, and have done the 06:04 to Glasgow twice before :lol:
(Both plans involve waking up at between 03:00 and 04:00, to make sure i don't leave anything at home)
If i don't do the Newcastle-Carlisle diversion next weekend, i'll definately do it the weekend after, although i'm aware that the probability of me getting anything other than an MTU'd powercar is very low..
It'll still be an HST though, and i rather like the refurbished NXEC HST which i got on this year's very first Manchester-Newquay run earlier in the year! :D
(Although i admit that having a Valenta on my end of the train did help!) :D
