Fare advice - PRIV to Heathrow
30 Aug 2011
Manchester
Hello fare gurus.
Looking for the cheapest way to get from Kings Cross (using free travel pass) to Heathrow using a PRIV card (no boxes available).
Happy to use any route but using Heathrow Express would be preferable using the underground to transfer from Kings cross.
I know nothing about London/cross London ticketing so over to you guys.
Thanks
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
I believe that unless you are safeguarded staff, you can't get a PRIV fare on London Underground - but Underground travel as part of a cross-London PRIV fare is OK. So something like Harringay to Heathrow (starting short at King's Cross) should probably do the job: £6.75 single, £11.75 return, and valid on Heathrow Express.
route:oxford
1 Nov 2008
Hello fare gurus.
Thanks
Use the Heathrow Connect service instead. A little bit slower, but significantly cheaper.
davetheguard
10 Apr 2013
I think you'll find that you cannot get priv or free travel on the Hayes & Harlington to Heathrow section of the "Heathrow Connect" route.
You can use it between Paddington & Hayes & Harlington (and of course you could also use a FGW Turbo service between these points).
I believe you can also get a priv on the Heathrow Express all the way (although there used to be restictions at certain times of day - don't know if that still applies).
A good alternative, but slower, is to use the train from Paddington as far as Hayes & Harlington, and then the frequent red London bus from the stop outside the railway station, which runs to a terminus at Heathrow bus station (very close to what used to be Terminals 1, 2, & 3). Terminals 4 or 5 would require a further red London bus or a one stop train ride - all of which I believe are free within the airport's perimeter.
There is also a red London bus to Terminal 5 from, (I think, but you'd need to check) West Drayton station on the main line out of Paddington: again from the station forecourt. Transport for London's website will have the full details.
cjohnson
3 Sep 2009
I can get NRE to show an itinerary valid to start short at King's Cross and stop short at Heathrow using HEX for under £2 with PRIV... thetrainline-powered booking sites will even sell it (without the PRIV discount obviously). Can't see HEX staff being too pleased with that though :lol:
davetheguard
10 Apr 2013
Red London bus route 140 every 8 minutes from Hayes & Harlington railway station to Heathrow central bus station.
Red London bus route 350 every 12 minutes from West Drayton railway station to Heathrow Terminal 5.
Combined with a priv from Paddington to Hayes or West Drayton, these buses should work out much cheaper than Heathrow Express; particularly if you have an Oyster for the bus.
Muzer
3 Feb 2012
Whoa, stop short at Heathrow? What, is it a journey to Woking via the railair coach service or something? ;)
