Fare advice for Helsby to Alfreton
ATW Alex 101
28 Dec 2010
Ellesmere port
Hi all,
I'm needed in Alfreton tomorrow and am looking for some fare advice and see if I can beat £20.60 for an off-peak return from Helsby to Manchester then an off-peak return from Manchester to Alfreton. I am going at around 7 in the morning from Helsby and leaving on Sunday the 9th at around 6 in the evening.
It will be just 1 child going.
Thats the cheapest I could get, I don't want advances as I want some flexibility but I am looking for the cheapest combination of anytime or off-peak returns. I have tried trainscanbecheaper but that is useless.
Thanks for all the help :)
13 Apr 2011
Helsby
Hi all,
I think it is rail replacement buses between Manchester and Helsby on Sunday.
sonic2009
19 Jan 2010
Crewe
Off Peak return Helsby - Alfreton ANY PERMITTED £19.75 for a child is cheaper than splitting at Manchester.
ATW Alex 101
28 Dec 2010
Ellesmere port
Hi, I have set on a £19.75 off-peak return from Capenhurst to Alfreton. Am I able to use it to travel via Liverpool both ways changing at Central and walking to Lime Street?
Thanks for all the help :D
bb21
Emeritus Moderator
4 Feb 2010
I don't actually think it is permitted, as Hooton fails fares check for Capenhurst on this occasion. That said, I think via Liverpool is an entirely reasonable thing to do and requires only one change so I doubt you will be questioned.
kieron
22 Mar 2012
Connah's Quay
No, but if you had a £18.85 Neston-Alfreton return instead, you would be able to. You may start short at Capenhurst if you wish.
ATW Alex 101
28 Dec 2010
Ellesmere port
Ah thanks. I have used a Capenhurst-Alfreton via Liverpool before after I was given that itinerary by NRE, but I'm asking about exiting at Liverpool Central and walking to Lime street.
Anyway, got the ticket and worked my way to Alfreton by using guards itineries and memory of timetables. Went via Crewe and Stockport. A northern RPI didnt seem to have any knowledge of either Capenhurst or Alfreton!
Cheers for the help!
