Mcr Warrior
- Joined
- 8 Jan 2009
- Messages
- 17,319
Major Infrastructure with Zero Chance of being Built? New twin bore tunnel between Whitehaven and Corkickle, with the various other single track sections in the area also being doubled.
This has long been a thought of mine, because there is land to add platforms 0, -1, -2 etc at Piccadilly.
However, the last time this came up someone posted a plan of the old junction. The lines did not join the two tracks nearest to the viaduct, instead they crossed by diamonds and joined the next pair. The result would be a lot of crossing moves.
Now, you could create a new curve that went to the East of the previous one to allow for the shallower junction. So it is still a plausible line. It is just the current derelict viaduct is in the wrong place.
Whenever I thought about it, I thought in terms of the subsurface lines in London. All trains stopping at all stops (except on the Bolton line since there should be paths to allow trians to skip the stops between Salford Crescent and Bolton. Likewise for Rochdale where there should be capacity for some to be fast Victoria to Rochdale).With my idea of a circle line, how many lines would to have to cross between Ardwick and Picc 14? Eight? More?? Even if the line were plausible it would never happen because of that! But while the curve northbound going directly to Picc 1/2 could be redeveloped (if space at Piccadilly permitted) is there any chance of a south-bound curve so some trains from the north (eg Barrow to the airport) are diverted around Manchester via Victoria to avoid the corridor?
There would be (trains through Piccadilly only, services passing through Victoria, such as Chester to Leeds, or Southport to Stalybridge, remain unaltered):
1. Circle - Airport - Piccadilly (13/14) - Oxford Road - Salford Central* (new platforms needed) - Victoria - Piccadilly (East)
2. North East - Airport - Piccadilly (13/14) - Oxford Road - Salford Central - Victoria - Rochdale ->
3. North West 1 - Airport - Picadilly (13/14) - Oxford Road - Salford Crescent - Bolton ->
4. Warrington Central Line - Airport - Piccadilly (13/14) - Oxford Road ->
5. North West 2 - Piccadilly (East) - Victoria - Salford Central - Bolton ->
6. Chat Moss - Piccadilly (East|) - Victoria - Salford Central ->
Lines 2 to 6 behave like the District, Hammersmith and City and Metropolitan lines in London, sharing core sections and branching off.
Like the Circle line now, there would be no circle. The regular interchange opportunities at Piccadilly would provide the necessary connections. A better bridge would be needed from Piccadilly (East) to Piccadilly (13/14), together with a better waiting area above 13/14.
This all works better with fast trains from the North West coming in via the new Liverpool to Manchester line, but otherwise provision within North West 1 is needed for the Scotland train. Blackpool North and the Lake District trains come under either North West 1 or North West 2.
The Atherton line is assumed to go to Tram Train, whilst Southport is another Bolton -> provided for in North West 1 or North West 2.
I left Deansgate out, but that would either be an all trains stop, or a closure depending on what gets done about a West entrance at Oxford Road.
Whilst a line that allowed a true circle would be nice, getting trains up and over the throat of Piccadilly is a major engineering challenge.
An option for a bridge that brings trains from the airport side over to Piccadilly East is plausible, but that would make it more like a giant speech bubble rather than a circle. Trains would be as per Circle, but with an extra Piccadilly (East) - Airport on the end. Of course that would please people who like direct airport trains, but would make the airport line very high frequency.
I assume too that no other services go to the airport. Crewe to the Airport approaches from the South so does not impact on the capacity of the line between Airport and Piccadilly. All that would change there is that the Crewe trains currently continue to Piccadilly main shed, but would no longer do so. The TfW from North Wales would need to terminate somewhere, so could be pathed behind one of the many Airport - Piccadilly 13/14 trains but would be slower due to the metro trains stopping.
And all the money spent on the Ordsal Chord which sees I think 1tphIf anything shows just what a mess Manchester is
Backs up my plan to take trains round the eastern side out of the way! Don't think it's "zero" it has to be done, although I can't imagine what will emerge; might not even be around to see it (but may have to put up with the disruption in the years before!!!)And all the money spent on the Ordsal Chord which sees I think 1tph
The recent history is quite interesting, going back to early 80s Victoria was more important, with Transpennine trains using it, and anything North using it because the Windsor Chord wasnt opened until I think 1988. At this time an effort was then made to concentate everything beyond local services at Piccadilly, and this worked fine at first. TPE north switched to the Guide bridge route, the Staylbridge - Stockport was reduced to a parlimentary. This worked fairly well for some years but I think the undoing was increasing capacity by increasing service frequency rather than train length and an overall increase in rail travel. There were and still are too many 2 and 3 coach units running about in the Manchester area.
So you now have a situation where Castlefield is at capacity, and something big is needed to sort it out. Which definitely falls into the 'Major infrastructure with zero chance of being built' category.
Things on the north side are improving - paired by 'turnbacks' at Stalybridge and Rochdale, the additional ones at Victoria and Salford Central - the wires to Wigan (Rochdale needed next) - all of these are pairing services to minimize conflicts. Hopefully the next steps will be to be able to increase to 3tph or 4tph during peaks... and increase commuting ridership.And all the money spent on the Ordsal Chord which sees I think 1tph
Historically, portions of London trains were detached at:Interesting and thoughtful, but don't ask me questions later!!
If anything shows just what a mess Manchester is, all started I presume in Victorian times when everything North went to Exchange/Victoria and everything South to central/London rd etc, and never the twain!!!
I think the problem is we have lost the ability to have a vision of what we want. The likely outcome of the Ordsal chord (White elephant unless you do other upgrades) were widely predicted on here and no doubt in other places. To be honest its common sense. The bean counters pare everything down to cheapest 'will just do' solutions, which later end up not 'just doing' instead causing ongoing problem in years to come (4 car 185s anyone).Backs up my plan to take trains round the eastern side out of the way! Don't think it's "zero" it has to be done, although I can't imagine what will emerge; might not even be around to see it (but may have to put up with the disruption in the years before!!!)![]()
Mayfield was not a lot of use. It is on the Airport side of the formation and could have been used for an airport shuttle. More trains could have been diverted via Styal and then approached Mayfield platforms but that means missing Stockport. Trains coming in through Styal would also eat up capacity on the line to the airport and negate opportunities for local services on the line. However, it was limited use for much else.I think the problem is we have lost the ability to have a vision of what we want. The likely outcome of the Ordsal chord (White elephant unless you do other upgrades) were widely predicted on here and no doubt in other places. To be honest its common sense. The bean counters pare everything down to cheapest 'will just do' solutions, which later end up not 'just doing' instead causing ongoing problem in years to come (4 car 185s anyone).
Couple that with all the talk of HS2 reaching Manchester and NPR which is now also firmly in the zero chance in the foreseeable future category and you end up with a situation where nothing is done. I think the practice of breaking each scheme down into small chunks and looking at BCR of each bit, then plenty of hand ringing and binning the whole lot, as well money wasted on endless 'studies', its all part of the state that we are currently in. Railways are a national infrastructure and a national asset and the current way of doing things doesn't seem to reflect that. Different country, different politics, but China have a plan, the grid of high speed lines being one them, and they get on and build them.
Then to take the case of the route we were discussing, I don't know if its protected in anyway, but you can imagine a developer getting hold of it, building over it and it moves from the 'cant afford it today' pile to the 'never' pile.
In an ideal world we would have plans for a Manchester 'ring' railway, with plans to grade separate junctions including approaches to Piccadilly, and expansion at Piccadilly, with Victoria just being a stop on the ring. We also had the old Mayfield station, but I believe that site has now been sold. You decide what you want the end result to look like, and then fund it for long enough that the work can proceed stage by stage. But this is getting off topic...
Could the triangle of space between 13 and 11, where the cab rank is, be built over to provide a couple (or more) west facing bays? at least one or two long enough to take a 5 car 800/397 or 6 car 185could have been used for an airport shuttle.
That does not apply to the debt interest, much of which is paid to overseas investors
www.economicshelp.org
Overseas investors own about 28% of UK gilts (2022).
The Asset Purchase Facility is purchases by the Bank of England as part of quantitive easing. This accounts for 26% of gilt holdings.
That's right in terms of where the interest payments go, but it is the active traders who are buying and selling that set the long term interest rates. The Bank of England holding has to be disregarded here because they are not buying and selling. They don't want to increase their holding any further, that would be more quantitative easing, and can't sell for two reasons. The first is that selling would be "quantitative tightening", the second is that, from the active market participants' perspective, Bank of England sales increase bond supply, like new issues. Bank of England sales would drive prices down and yields up.About 25% of government debt is held by overseas investors, which about the same amount that the Bank of England holds.
As for UK pension funds, the impact on them of falling gilt prices resulting from market fear of large amounts of new issues was well demonstrated in autumn 2022. They can get into a position where they need to sell into a falling market, which only makes matters worse.Quite a lot of government debt is held by British organisations (banks, pension companies and the like)
Thanks, you are listening very carefully! I need to pay more attention to the Monetary Policy Committee.Quietly!
But there is still a long way to go, and it is going to be slow progress. While it is happening, and other things being equal, what the Bank are doing does make it more difficult for the government to issue new debt, especially anything beyond what is in the Chancellor's fiscal rules.So far they have sold down well over £200bn of the £875bn UK sovereign debt bought during the financial crisis (Quantitative Easing), so yes they are deploying Quantiatiev Tightening.
Although, the issue is the lack of capacity beyond the LTC (for example through Kent) and so either you've got to build more roads (as there's already issues - see operation stack, which would have to happen more often if more traffic can get into Kent).
Toby Howe, highways and transportation strategic manager for Kent County Council and part of the Kent and Medway Resilience Forum, said issues were caused by tourist traffic pouring into an already full Port of Dover, causing backlogs.
He told BBC Radio Kent: "Tourist traffic is causing huge chaos in the town. It's like herding cats.
"Until the government finds a solution to hold and manage the traffic, we in Kent and Dover are going to suffer."
Responding to suggestions that a lorry park should be created on the site of the Sevington Inland Border Facility, Mr Howe said the plan would "create a huge bottleneck" and would not stop tourist traffic issues.
A Department for Transport spokesperson said: "We recognise the impact Operation Brock has on residents, which is why we're working closely with partners to improve safety, reduce local impacts and develop longer-term traffic management solutions.
Agreed, the channel crossings are always going to be a bottleneck due to borders and customs unless we build a motorway tunnel (good luck with that!) and join at least EFTA. But that doesn't mean the LTC won't help relieve pressure on the only crossing east of the Woolwich ferry for outer London and both sides of the Thames Estuary.Here's a story about the issues within Dover, the LTC is only going to mean more traffic is able to get there:
Dover 'chaos' is 'like herding cats', Kent council boss says
Politicians have called for those in charge of calming Dover traffic to "get their act together".www.bbc.co.uk
Part 1 of this is that there's lots of constraints and they can't all be solved simultaneously. Part 2 of that is there's spare capacity at the Channel Tunnel to increase shuttles if the vehicle processing times can be kept low, either through technological help or getting a customs agreement with the EU (e.g. EEA or EFTA).However there's other capacity issues within Kent too.
Also, one of the trains for the LTC is often said to be because of the amount of goods passing through Dover, as the story proves how is the LTC going to help with that if the capacity constraint is the channel crossings?
That submersible was pushing the limits of what tech can do. Yours is far too sensible and could even be built! Think of the value of submarine-proof internet cabling - assuming the bad actors wouldn't dare to breach it with a dozen passenger trains in it...Think the responses here are insufficiently ambitious, given the wording of the thread. I’d cite instead the idea of a transatlantic high-speed rail tunnel, to get rid of all those pesky flights.
Could be built as a moored, submerged tube at just sufficient depth to avoid wave action. And extruded from a giant 3D printer on the shoreline, using carbon composites (surely the little hiccup with OceanGate's Titan submersible was just a teething problem, as with all emerging tech?).
Musk could probably fund it himself!And no doubt there would be enough entrepreneurial billionaires willing to fund the thing by buying tickets on the first test trains!
Definitely zero chance of that. The Werrington diveunder makes it superfluous, and there is the small matter of Whitemoor prison being in the way.
Put a tunnel underneath the prison. What could possibly go wrong?HMP Whitemoor is a category A high security prison housing around 500 of the UK's most dangerous members of the prison population. It is a big site, part of which is on the alignment of the March-Spalding line. Whether it is physically possible is irrelevant, there is zero chance of the line being reinstated because of the location and status of the prison.
Being in the middle of the Fens, it would probably fill-up with water pretty quickly!Put a tunnel underneath the prison. What could possibly go wrong?![]()
Construction would take too long - it'd not be one tunnel. You'd have to dig three tunnels, Tom, Dick and Harry, and lose the soil in the exercise yard, or someone would need to smuggle a TBM in inside a cake.Put a tunnel underneath the prison. What could possibly go wrong?![]()
Like!Construction would take too long - it'd not be one tunnel. You'd have to dig three tunnels, Tom, Dick and Harry, and lose the soil in the exercise yard, or someone would need to smuggle a TBM in inside a cake.
