Fantasy Crossrail: Farringdon to King's Cross St Pancras
The entire corridor is about 12 or 13 metres wide. I'd be surprised if there weren't room for a pair of travolators
So cross those two roads on foot.
two things then:
1) how do you build a pair* of travelators below ground, in particular access to them?
2) how attractive will it be to walk out of the station, then a few hundred metres north, then cross the road on the level, then another 30 or so metres along another road, then down to subway level, then eventually getting on a travelator? Before coming up the other end and having to cross another busy road and walking another 30 metres or so at street level…. Compared to walking a shorter route?
greyman42
14 Aug 2017
WCML to ECML/Eurostar will be easier to walk between Euston and St Pancras or King's Cross than any transfer, especially if they do improve Phoenix Road.
What do you mean by improve Phoenix Road?
Northampton
Phoenix Road and Brill Place connect Euston to St Pancras in a straight line, about 100m north of Euston Road. As part of HS2 there is a report (There's a thread on here about it somewhere) that outlined a number of options to landscape the road to give priority to the walking route.
Here's one thread: https://www.railforums.co.uk/threads/connecting-euston-and-kings-cross-after-hs2-completion.200339/
Here's another: https://www.railforums.co.uk/threads/hs2-hs1-on-foot.226671/
And here's the 2015 report: https://content.tfl.gov.uk/hs2-phoenix-road-urban-study-tfl-2015.pdf
Western Sunset
23 Dec 2014
Wimborne, Dorset
All you need to do is dismantle the (now unsponsored) cable car across the Thames and re-erect it between Euston and KX. No need for any expensive underground work. Simple!
Basil Jet
23 Apr 2022
That's overkill, mate, the catapult and cushion have been invented.
CBlue
30 Mar 2020
East Angular
They'll need extra stock for this Kings Cross spur of course - shouldn't have scrapped the 332s and 365s should they?
:rolleyes:
BayPaul
11 Jul 2019
There's a cheaper, easier and more practical solution for the OP... Simply extend the ECML and MML to Farringdon. I'm sure you'd need to demolish only around 5% of London....
D365
29 Jun 2012
Building a short extension would be harder than an entirely new line? How?
Thameslink already has a path between the two. In fact, maybe connect the two lines if it's too much work to build a new line.
Building in a flying junction between two running lines IS more difficult. And then explain to me how you’re going to serve Paddington to Tottenham Court Road with only 12tph.
thank goodness that your thread title states ”fantasy”!
