(Fantasy) A through-running commuter rail tunnel for Birmingham
squingo44
5 Jan 2026
I tried coming up with the most reasonable way of getting all local services out of Birmingham New Street, freeing it up to run regional and intercity services more reliably. I came up with the following network, aiming to minimise the amount of tunnelling and the number of underground stations:
- Quadruple the track from Wolverhampton to Soho South Junction, from Bescot Stadium to Perry Barr North Junction, from Landor Street Junction to Water Orton East Junction, from University to King's Norton, and from Adderley Park to Rugby
- Build two tunnelled railways under Birmingham City Centre, from Soho South Junction to Adderley Park and from Church Road Junction to Duddeston
- Build three new underground stations: a Birmingham Central underground station with cross-platform interchange between the two underground lines and direct interchange with New Street, Moor Street, and Curzon Street, a Five Ways replacement station and a Ladywood station
- Expand the following stations with additional platforms and turnbacks to support terminating more services: Wolverhampton, Rugeley Trent Valley, Lichfield Trent Valley, Tamworth, Nuneaton, Coventry East (proposed), King's Norton, and Bromsgrove.
This builds on the Midland Rail Hub proposals to expand Moor Street station. It ought to leave most of the capacity on the existing lines free for new services, especially Birmingham New Street. In particular, it could support more Thameslink-style outer commuter services, such as Stafford-Rugby, Shrewsbury-Leicester, and Worcester-Derby.
Junctions such as Aston North, Water Orton East, Barnt Green and Soho South can be grade separated as necessary to increase service capacity.
Why would it make it more reliable, the nature of long distance services suggests that they get delayed getting to New St, not by it as a location.
Landor St to Water Orton is nigh on 4 tracked anyway and as for the others, taking the cross city out of the station isn't actually going to free a lot up. Adderley Park to Rugby is being 4 tracked, its called HS2. Bescot to Perry Barr is far from full. All of this would cost billions which would be better spent on finishing HS2.
Sprinter107
26 Mar 2019
Between Five Ways and Bournville, the line is on the edge of the Birmingham and Worcester canal. Where are the extra pair of lines going to go ?
Zomboid
2 Apr 2025
Oxford
A chord at Smethwick Galton Bridge or Soho to allow Shrewsbury services to divert to Snow Hill lines
How full are they? And would it actually help if Soho to Wolverhampton is still taking the same amount of trains as today?
Topological
20 Feb 2023
Swansea
I always liked the idea of a suburban tunnel for Birmingham. It feels like there are crossing moves. However, when you look at the junctions the actual moves are not so bad. The CrossCity trains coming in from Five Ways use the higher number platforms and then go out over the top of the lines from the lower number platforms, they do not cross on the level.
The issue is more the two tracks down to Kings Norton, the two tracks to Wolverhampton and the two tracks on the corresponding North East and London routes. Those two track sections mean you have longer distance trains being held by locals. HS2 will help with Wolverhampton since Birmingham to Manchester should be quicker via HS2, but that is possibly only one train. Birmingham to Coventry will be eased slightly, but the likely replacements for the Avanti will not be stopping that often between Birmingham and Coventry.
I am not 100% sure what the answer is. More dynamic loops probably. Expensive to add on what is often actually built as a two-track line, but still cheaper than a tunnel.
Zomboid
2 Apr 2025
Oxford
The Camp Hill lines mean there are 4 tracks (of a sort) to Kings Norton, though it's a flat junction and both routes have stopping trains now, so not necessarily that easy to path that many fasts (how many does the route need?)
HS2 should make the Coventry line simpler as the remaining London trains won't need to be in a hurry on the busiest section.
The Wolverhampton line is probably the trickiest one now?
squingo44
5 Jan 2026
Some residential land take would be necessary, but this could be accommodated by taking larger blocks, redeveloping them into higher density residential land, and building more stations along the line.
All four main line railways into Birmingham New Street have space to be quad-tracked quite some way into the city centre, the point at which you need to enter a tunnel being determined by your appetite for taking over residential land.
But every single one of those lines is busy enough to justify complete segregation, on top of HS2.
Any railway line near the centre of Birmingham should have extremely high frequencies - both lines via Kings Norton should be quadrupled.
HS2 doesn’t help with Coventry to Birmingham particularly much, the line could still support demand for a full set of local services and a full set of express services. HS2 will, if anything, only further induce demand on the line for both kinds of service.
6Gman
1 May 2012
Confiscation of land and property tends to be unpopular, for obvious reasons.
The question you have to answer is "why". What is it you are trying to provide and why? I don't see where the land is to 4 track the Cov corridor, nor out to Kings Norton, nor on the Camp Hill. Cross City will eventually go back to 6tph, how many more does it need to be, why does it need to be more? Same goes for all the other routes, how many trains need to serve those stations? Are all the current trains full, all day? Can you provide the capacity by making them longer, or is the case you need 6tph (pretty much turn up and go) on all lines? The only stations between New St and Wolves that have a relatively poor service are Rolfe St, Dudley Port and Tipton at 2tph. The rest are at 4tph minimum.
Massive compulsory purchase for surface trackwork is unlikely to work out cheaper than simply tunneling once the massive fights with the local population are accounted for.
squingo44
5 Jan 2026
Like the rest of the country, the West Midlands needs to decarbonise its transport network and densify development around the city centre. The only way to achieve this is a massive expansion of their commuter rail network far beyond current capacity. More than anywhere else, the West Midlands has seen explosive growth in usage of its passenger rail network, and incremental improvements aren't going to be enough after merely a few years. For all stations within half an hour of central Birmingham, 6 TPH should be the floor, not the ceiling.
I think that there are many ways to sell the proposals for widening the existing corridors. Everywhere that a meaningful number of single-family residential homes must be demolished in order to widen the corridor, a new station should be proposed and the project widened further into a full-fledged neighbourhood regeneration. For instance, between Wolverhampton and Birmingham New Street, there would be room for several infill stations and capacity for a full >20 TPH stopping service. Likewise between New Street and Coventry, there would be room for several infill stations to sell the benefit of the expansion.
Purchasing land for expansion of the railways at the surface is only more expensive than tunnelling when the land is high-value and densely developed. You don't need to get that far away from Birmingham City centre for the price to go in favour of surface expansion over tunnelling.
Finally, the most realistic way to deliver this transformational improvement to the network would be to do so in stages. You could build just the central tunnels first, in effect quadrupling the lines into Birmingham New Street, and expand the quad-tracking gradually outwards section by section to simplify delivery and apply the proper focus to each local community affected. Everyone benefits from a better-functioning railway network, not least because New Street is so connected to so much of the national network.
The cross city trains cross the western station throat actually, because the junction between the cross city lines and the derby line east of New Street is not grade separated. Grade separating Proof House junction is just yet another improvement the west mdlands network needs.
Yup, they need to be fixed. Quad-track on the surface as far into the city centre as you can get from King's Norton, then enter a tunnel.
Partial quadrupling of the two track railway is a good start, and builds towards the eventual goal of complete quad-tracking, but ultimately I think complete quad-tracking is necessary.
Topological
20 Feb 2023
Swansea
I would have thought you would get all the benefits you need from a few dynamic loops.
New Street has 6 platforms per pair that go in and out, so you are not too constrained there. Even allowing for the Manchester to Camp Hill crossing between pairs of lines, most can be handled through the availability of platforms.
More concerning is where the CrossCountry that goes via Five Ways (and the Hereford/Cardiff to an extent) can pass the increased CrossCity line trains. When I am looking what is happening with CrossCountry for Bristol Parkway to the South West, there are always delays added between Birmingham and Kings Norton.
6 trains per hour should be plenty for all stations and efforts should be made to ensure they are all 6-car 730s or longer.
Towards Wolverhampton there are more options for dynamic loops and many have been explored as workable on threads in this section.
I just split this part out.
CrossCity head for Lichfield and that is grade-separated.
Proof House towards Derby also uses the south side of the formation and then goes under the London line. That is grade-separated. Crucially, it is not electrified and so it is not the primary through route for birmingham suburban trains.
I am wondering if you are confusing the services here?
The area around the line line between Wolverhampton and Birmingham, at least, does look heavily developed.
This is a world where compulsory purchase of a house is on the order of half a million pounds at least (it will be substantially higher than the open market cost once legal fees and inducements etc are included).
Replacing road bridges with ones suitable for a four track railway will cost tens of millions each, and even stations will require access arrangements and structures likely to require demolitions even beyond their upfront cost.
It might sound expensive up front, but I would not be surprised if a metro tunnel with stations bored from Wolverhampton to Coventry worked out cheaper than attempting to do the same on surface, especially including costs of the legal battles. Engineering problems are way easier to solve than political ones.
Ofcourse a new tunnel solution also allows you to embrace all the features of a modern metro which would bear fruit in the long run.
Sprinter107
26 Mar 2019
So four tracks out to Kings Norton, it would mean both Church Road and Pershore Road tunnels being doubled in width, some of Hallfields school being demolished. Residential properties in Farquhar Road Edgbaston being flattened, other buildings in Vincent Drive coming down, houses in Raddlebarn Road Selly Oak coming down, part of Cadburys being demolished, then either residential properties in York Close, the site of what was Bournville shed being flattened, or industrial units off Charlotte Road on the other side of the line being demolished. There would be an absolute uproar. Thats besides major reconstruction of University, Selly Oak, and Bournville stations. All for the sake of increasing what is already a frequent local service. And as for additional stations, the ones we already have are very close together as it is.
Topological
20 Feb 2023
Swansea
Selly Oak to Bourneville looks possible, but may need some new retaining walls to replace slopes a la the Trent Valley 4-tracking in Tamworth.
Going the other way, Selly Oak to University looks doable, but there you have the issue that University was just modernised as a two-platform.
Zomboid
2 Apr 2025
Oxford
If a tunnel is essential, then how about using it for the fast lines. Dig a tunnel Kings Norton to Washwood Heath. Build a 4x 300m platform station under the bullring with exits at either end to New St and Moor/ Curzon St.
The XC Cardiff - Nottingham and Plymouth to Edinburgh trains can go that way. Worcester/ Hereford line trains and the Stansted service can turn around in the platforms.
Of course, a bunch of that replicates what the Moor St expansion does, so pretty pointless really.
squingo44
5 Jan 2026
On the basis that the highest avoidable cost of building in this country is underground stations, how about a crossrail solution that takes the regional and intercity services out of Birmingham New Street instead?
Here's a new design that takes into account the feedback that I've tried to quad-track too many sections of track that are tightly surrounded by residential development. In the case of the cross-city/crosscountry line, there are sections that are already quad-tracked, making it easy to extend the tunnel all the way to those sections and avoiding the hassle of widening the existing corridors.
King's Norton station may require being moved west a little to make room for a tunnel portal east of the station (and it would be easier to align the tunnel portal with the camp hill line, which is adjacent to some commercial land up for grabs). King's Norton would probably require at least 6 platforms, and grade separation of the junction. There's plenty of space between Duddeston Junction and Washwood Heath for a tunnel portal, and the tunnel could potentially be extended on a spur to fit a depot north of the HS2 depot on the other side of the M6.
For the WCML towards Wolverhampton, I extended the tunnelled section to just short of Sandwell & Dudley, which is just beyond the stretch of railway most confined by residential land one side and the Birmingham Canal on the other. Some residential land take may be necessary between Dudley and Wolverhampton, but I expect that to be cheaper than tunnelling further beyond. Especially because this plan would require an expansion of Sandwell & Dudley station to have more platforms and turnback capacity for some services.
For the WCML towards Coventry, surfacing the tunnel beyond Lea Hall means that the only sections of track requiring residential land take would be Marston Green and Earsldon and Binley in Coventry. I think this strikes the right balance between avoiding the cost of residential land take close to Birmingham city centre while avoiding growing the cost of tunnelling too much.
In order to minimise the complexity and cost of the central Birmingham station, there would only be 4 platforms - more like a central-London Elizabeth line station than a big box station like Old Oak Common. Since it would be for regional and intercity services, it would be necessary to expand the capacity of every surrounding shoulder station to maintain the reliability of the timetable. But it's a lot cheaper to expand stations like Nuneaton, Bromsgrove, Birmingham International, and Lichfield Trent Valley than it is to build a larger underground station in central Birmingham.
I would avoid turning around services in central Birmingham like the plague - a huge unnecessary capacity sink. Build a big shoulder station on the cross country line at Nuneaton or Tamworth and turn around services there.
What makes you think that this additional capacity would replicate, rather than complement, the moor street expansion?
Zomboid
2 Apr 2025
Oxford
Birmingham doesn't need jubilee line frequency, e population just isn't dense enough. Most suburban stations would be well enough served with an evenly spaced 4tph.
Decarbonising doesn't need what you are proposing, OLE does that. You haven't answered where the need is, what is lacking, where does the increase in capacity need to be and what is it for? Why does everywhere within 30 minutes need 6tph? A lot of London only just achieves that, Liverpool, Manchester and Leeds come nowhere near.
That's genuinely bonkers, what you are suggesting is a tram network as that many stations on a heavy rail network would actually put people off as the journey time would increase monumentally. For example if you look at Wolverhampton to New St now, that is a 27 minute journey stopping at 6 stations. Add in 4 or 5 more and that journey is likely increasing towards the 40 minute mark. How are you fitting 20tph at New St, even with your underground plan on just a single corridor? Now add on the Coventry side, Cross City, Walsall, Camp Hill etc.
How are you doing that without building more tunnels into New St and more platforms?
Why?
It varies by pair, Coventry corridor can do 1-12, Derby 1-12, Wolves 1-12, Five Ways 5-12. Aston 1-12
The Pelican
3 Oct 2025
Birmingham (Snow Hill) and Wolverhampton have had a tram connection between them since 1999, improved since 2016 with direct access to Birmingham New Street and more recently to Wolverhampton station, and a new route to Edgbaston Village. Later this year, a new line to Dudley will open from a triangular junction with the existing route. A planned line will run past the HS2 station eastwards, potentially to the NEC and HS2 Birmingham Interchange station.
It's interesting to speculate what this tram line would have looked like as a grade seperated metro line, which was an option considered at various stages, perhaps looking like the Tyne and Wear metro or the DLR. It would probably have run into the old Low Level station at the Wolverhampton end, and had a single tunnel from Snow Hill to New Street at the Birmingham end. The Dudley extension (which uses an existing railway line) might have gone ahead, although with stations futher out from the town centre, but it seems unlikely the Edgbaston branch would have been affordable to tunnel.
squingo44
5 Jan 2026
To support growth and new housing developments, it's as simple as that. The rest of the country can recreate London's success only if they recreate the size, scale, and capacity of London's public transport network. That's why every local service in the Birmingham network should have London Underground level frequencies. There isn't demand for that level of transport capacity yet, but it would very quickly materialise as new housing developments spring up around the upgraded transport corridors.
People from Wolverhampton would take one of the very frequent express services on the new line, rather than taking the stopping service.
Birmingham New Street has two pairs of tracks in its station approach on both sides and 12 platforms. My proposed Birmingham Central underground station would have two pairs of tracks and 4 platforms. The ~20TPH stopping services can fit just fine into the existing station, and the intercity & regional services would all fit into the new Birmingham Central station - if no services were terminated in the city centre and the shoulder stations at King's Norton, Bromsgrove, Wolverhampton, Birmingham International, Coventry, Tamworth, and Nuneaton were expanded with additional platform capacity and turnbacks.
According to measures of the existing network, this is true. I'm not looking at designing based on what the network is, but rather what it could be.
I'm proposing a new Birmingham Central underground station, which would connect to Birmingham New Street, Moor Street, and Curzon Street.
I like the sound of that. You can also have a tunnel connecting to a pair of fast lines on the WCML, with cross-platform interchange, if you didn't use the station for turnbacks and instead turned back services at the surrounding shoulder stations. i.e turn back Stansted services at King's Norton or Bromsgrove and turn back Hereford line trains at Nuneaton/Tamworth. Extra platforms would be a lot cheaper at those stations rather than in central Birmingham.
That's why the tunnel from King's Norton to Washwood Heath is so important. It's provides the biggest uplift in capacity, but I think it's just as important to get a tunnel for the WCML as well. After you build the tunnel and the new central station, it would be easy to incrementally unlock additional capacity through strategic quad-tracking and grade separation of junctions across the network. But you gotta have those additional tracks through the centre of Birmingham otherwise the bottleneck at the centre remains.
NCT
18 Apr 2025
I am all for raising regional cities' productivity and prosperity, but there is neither the economic need nor the democratic appetite for anything beyond evolution from today's built environment and population size.
A metropolitan population of 2.5-3.5 million, and focusing high-density mixed-use developments on existing ex-industrial and big-box retail sites will put West Midlands on par with successful European cities like Hamburg.
Transport-wise, full delivery of Midland Metro, electrification of the Snow Hill line and restoring frequency to the pre-Covid 6tph, released capacity from HS2, and full delivery of Midlands Rail Hub will collectively provide a lot of transport capacity allowing a high degree of agglomeration for the whole city region.
squingo44
5 Jan 2026
That's all true, and I am all for the delivery of all the projects you've described before anything I've suggested. But as soon as they're delivered, we should be thinking about the next improvement the network needs, and I think it's clear that it's relieving the bottleneck on the local commuter network through a new tunnel across the city centre.
Zomboid
2 Apr 2025
Oxford
Once all those things are done, the next improvement the network needs won't be in Birmingham
Shaw S Hunter
21 Apr 2016
Over The Hill
And even if it was there is still the question of how to pay for it all. The national economy is struggling, with no obvious signs of improvement happening any time soon, so the pressures on the public purse will continue for many years yet. Within the national political conversation spending on public transport projects, especially big and expensive ones, is not seen as any sort of priority. Yes this is a fantasy thread but in the current climate it can only be described crayonisting.
Sprinter107
26 Mar 2019
We dont need London Underground frequencies. Most stations are served quite adequately with the frequencies they already have. Some areas will never have high density housing. Are you familiar with these routes ?
Topological
20 Feb 2023
Swansea
I am still not convinced that this needs anything more than a dynamic loop somewhere between Five Ways and Kings Norton, another between Smethwick and Dudley (there is definitely space for that), ideally one between Birmingham New Street and Birmingham International (but I have not checked where) and possibly somewhere that allows a local service to Tamworth/Burton (which currently is not part of the network)
Even those loops would be expensive looking at what is involved to dig out a wide enough cutting with retaining walls.
andrewgs
27 Feb 2018
A connection from Coventry to HS2 Interchange to send the WCML fasts into Curzon Street is an alternative to four tracking.
