Extended, or Deltic-style, cab fronts
26 Sep 2017
Hi all
To this day I'm unsure of the correct name for it when a loco's got that 'nose' bit on the cab, like a 37, 40, Peak, Deltic etc etc... is it 'American style'? What's the standard way of describing these please?
D365
29 Jun 2012
I just refer to them as "Cab 1 nose" and "Cab 2 nose".
xotGD
4 Feb 2017
From Wikipedia:
In Britain, almost all locomotives have two cabs, however some older English Electric or British Railways designs have extended cabs with a strong resemblance to a "short hood" at both ends (usually referred to as the "nose" or "bucket"). Examples include the Class 37, Class 40, Class 45 and Class 55. Some single cab designs did have American-style short and long hoods (known as "bonnets" in Britain). Examples include the Class 15 and Class 16.
I've never heard the bucket used in this context. Perhaps some mix up with bucket being a nickname for Class 40s?
Nose or bonnet would be my two options.
Ken H
11 Nov 2018
N Yorks
Weren't the extended nose on early diesel locos to stop the effects of 'sleeper flicker' on drivers?
Why they changed their mind and ordered cl47 without them I don't know
But the nose was a handy place to put toilets, air compressors etc.
How the 1Co-Co1 would work without a nose I dont know.
hexagon789
2 Sep 2016
The three Bulleid designed Class 16/2s, No.s 10201-10203?
1-Co Co-1 and essentially the prototypes for the Class 40. No nose, more of a box cab really.
norbitonflyer
24 Mar 2020
SW London
Clkass 47 was by no means the first BR design without nose ends.
See
- all electric locomotives from the Bulleid trio and the LNER EM1s onwards
- all pilot scheme Type 2s (Classes 21-31), except the Baby Deltics (Class 23)
- the Class 33s
- all diesel hydraulic types (Classes 22, 35, 42, 43 and 52) except the centre cab "Teddy Bear" Class 14s and the original Class 41 A1A-A1As
- the Lion and Falcon prototypes.
All of these were introduced in 1961 or earlier, before the Class 47 which appeared in 1962
In fact, the only locos with nose ends were
- English Electric classes 23,37,40 and 55 and the Deltic and DP2 prototypes (but not the class 50s based on the DP2)
- Warship (Class 41 only)
- Peaks (Classes 44, 45, 46)
Bonnet or "hood" types with engine covers rather than an engine room within a monocoque body.
Shunting Classes 01-13
Type 1 Classes 14, 15, 16, 17, 20 (all single cab),
Type 5 Class 58 (double cab)
Irascible
21 Apr 2020
Dyfneint
Just put everything behind th cab instead? more headroom there too. If you want to block the driver's eyeline of the very near track you just have to extend the desk upwards, no need for a nose.
Ken H
11 Nov 2018
N Yorks
So why the noses then?
Cowley
15 Apr 2016
Devon
Also the English Electric LMS twins - 10000 and 10001 which set out that triple windscreen nose end look.
There’s a thread here from a couple of years ago that discussed some of this, including sleeper flicker:
