Explore Cardiff and Valleys ticket
Halsebee
8 Mar 2009
Is the Explore Cardiff and Valleys day ticket valid from Newport or Severn Tunnel Junction? Its not clear. And would it count as a zonal ticket for split tickerting purposes?
No, it is not valid from either of those stations. It is valid on the Ebbw Vale Town branch, but only on trains that come from Cardiff and avoid Newport.
As with most rangers and rovers, you can undertake non-stop splits, although I'm not sure where you would want to do so at the moment. Of course, if Cardiff Parkway gets built, I could see the case for it if using XC (noting that it's not valid on GWR services).
185143
3 Mar 2013
I'm certain it has been in the past.
Any idea when that changed?
The exile
31 Mar 2010
Somerset
Not in the 40 years since I first used it (or more pedantically its predecessor). Unless it’s had a brief period of validity which was then removed and I missed it. There have been debates in the past about what happens when Ebbw Vake trains are diverted via Newport….
Kite159
27 Jan 2014
West of Andover
It's one restriction which got mentioned to me when I purchased one a couple of months ago from the ticket office at Bridgend.
As for Newport when Ebbw Vale trains go that way (especially on Sundays) it's a very grey area, I suspect most guards will say it's valid only if you remain on board at Newport
