Expected changes to Northern & TPE with stock changes
Class377/5
19 Jun 2010
A helpful map of 319 introduction produced by user class377/5 hope you don't mind me sharing it on here:
319 Introduction by Sparkyscrum, on Flickr
Not at all. Forgot I'd uploaded that actually. Note sure its all correct but open to corrections folks.
The full sign map is A4 size (designed with printing in mind), hence why when its linked on here at a reasonable size its got small text.
Manchester77
4 Jun 2012
Manchester
I think it is correct it certainly shows how the 319s will slowly be introduced onto services out of Piccadilly. I don't know if they will go onto the express service first or onto the stopping service though. Have to say it is a great map which conveys the information very clearly :D
Emyr
8 Apr 2014
How densely packed will Piccadilly - Lime St be?
Are Northern likely to send any 90mph 323s west so the 100mph 319s can be used on selected Airport, Alderley-Edge or Crewe (stopper) runs?
Manchester77
4 Jun 2012
Manchester
I'm not sure what you mean there, do you mean what frequency will there be or..?
I wouldn't think so since the 319s will be based at west allerton and the 323s are based at Longsight
Nice map. But...
Some of the dates aren't right.
Wigan-Golborne-Manchester should now be yellow.
Liverpool-Wigan is Dec 2014 - same as Liverpool-Piccadilly (and Victoria).
Preston-Blackpool is now Dec 2016, as is Victoria-Stalybridge (same as Victoria-Bolton-Preston).
Bolton-Wigan is Dec 2017 I think.
And I think you need to put in Salford Crescent-Hindley as a diesel route for completeness.
Warrington-Earlestown is already electrified (but carries no regular electric services).
Otherwise it's fine. ;)
Geeves
6 Jan 2009
Rochdale
Victoria, Piccadilly and Lime Street should all eventually sign 323 and 319 so the fleet can become common user on all electric routes. Theres not many sections of 100MPH that Northern could use anyway, seeing as the line down to Crewe is a stopping service its not to likely a 319 could hit 100.
Manchester77
4 Jun 2012
Manchester
Ask said though the 319s will be based at West Allerton whereas the 323s are based at Longsight so it's not likely that a 319 would turn up on a Piccadilly - Glossop service for example because it would require a long ECS move rather than the current Longsight - MAN - service which is shorter and so costs less too.
Geeves
6 Jan 2009
Rochdale
Yeah thats true but there is no reason why a 323 could not be stabled at Allerton or vice versa. I mean just for examples sake a few 158s often stable at Newton Heath over night but none are based there.
Who knows, personally I just want to see a 323 at Vic!
Domh245
6 Apr 2013
nowhere
I seem to remember that all of the south Manchester Lines (where 323s currently operate) are timed for the superior acceleration of the 323s. As the 319s are considerably more sluggish, there will be almost no interchangeable fleet, perhaps as a last gasp measure. There may will be additional diagrams that use 319s but as a replacement for 323s, the only way you would get that is with a significant change to the timetable, which I doubt many would be happy with.
Geeves
6 Jan 2009
Rochdale
Yeah I heard that timings are very tight, those 2X142s they sometimes use on the early morning Crewe trains really struggle to keep up generally arriving 10 mins down or more.
Saying that in the future I guess you could expect to see what ever is available on the Hazel Grove - Preston or Stockport - Wigan NW on Sundays might throw up a 323 maybe?
Who knows
tbtc
16 Dec 2008
Reston City Centre
No surprise that a 75mph DMU can't keep up with timings scheduled for a 90mph EMU - but the 100mph 319s cope with regular stops over short distances in central London - whilst 323s are going to be faster out of the blocks, I'm wary of "319s are slow" becoming Received Wisdom on here (see also "319s aren't suitable for the kind of passengers/luggage you get on Manchester Airport services, despite serving Luton Airport and Gatwick Airport on a regular basis)
Geeves
6 Jan 2009
Rochdale
Yes I guess it was a bit of a ridiculous comparison there!
They run 321s with similar traction equipment and set up along side the 333s over in Leeds and they dont seem to have much problem. I took a 319 up from St Pancras the other week and it seemed to be flying in no time to me.
Looking forward to this across the Moss :D:D:D
http://youtu.be/8hEOcQdbuNk
Starmill
18 May 2012
Bolton
I see that Buckshaw Parkway has been consigned to an early closure programme by the makers of this map....:cry::cry:<(
I too thought of Newton-le-Willows... but thought it might be rude to point this out based on the recived helpfulness of and clear effort that went into the document!
Badly, if reports are to be believed? Not that I'm saying they are slow or can't well serve Airports.
That would be quite something!
northwichcat
23 Jan 2009
Northwich
The morning Crewe-Salford Crescent service is timetabled to be run by a pair of Pacers and even with the extra time it really struggles with accelerating leaving Heaton Chapel and Levenshulme and holds up following services.
With most of the EMUs at peak times between Stockport and Manchester doing Heaton Chapel and Levenshulme calls it means it's only really the Stoke services that need the 90mph capability, the rest need the very fast acceleration more.
I understand a computer simulation of a Glossop-Manchester run doing a 319 was carried out and it was considerably slower than a 323, which is one reason why Porterbrook have looked at options of making the 319s 75mph units with faster acceleration.
In another thread I was making the point about whether the non-refurbished 319/3s (with 3+2 seating) would attract extra passengers by replacing refurbished 156s (with 2+2 seating and tables) which need extra luggage capacity more than extra seats. Other users went off on a tangent as they wrongly assumed I was saying 319/3s weren't good enough for a journey of under 75 minutes, when I was saying they would be a downgrade opposed to the current rolling stock.
Why, in this case, cannot the ScotRail units go directly to Chiltern ?
Scotrail don't have any 2 car 170s and I think Chiltern are looking at making a uniform fleet of 3 car 168s by shortening the 4 car 168s and converting the 170/3s.
Doesn't it depend on what the new Scotrail franchisee wants to do with them?
I don't think you can presume they are "spare".
We'll know in September.
Scotrail is believed to have some DMUs which can be released but it's understood they want to release 156s.
If Chiltern hadnt got to the 170's first it may well have been Scotland taking them from TPE.
Network Rail's provisional platform lengthening plans assumed that either 4 car 170s, 172s or 175s will operate on the Mid-Cheshire Line and the Hope Valley Line but a recent update now implies we'll wait and see what rolling stock is intended to be used before the platform lengthening is undertaken.
(The Mid-Cheshire and Hope Valley lines have been identified as suitable lines to cascade regional DMUs to with no new local DMUs proposed and electrification resulting in regional DMUs being made available.)
Emyr
8 Apr 2014
I meant would using a 323 instead of 319 result in the following trains catching up, allowing no leeway for a single service to be delayed a few minutes without disrupting other services.
Starmill
18 May 2012
Bolton
Surely the timetable would have to contain relevant performance allowances in this case?
I can't imagine northern leaving themselves open to risking delay minutes/lower ppm because the government has given them stock that can't meet the pathing requirements of other TOCs (namely Virgin and their 3tph to Manchester, but also XC via Stoke and possibly TPE between Ardwick and Guide Bridge?).
How long has it been December? Last I heard it was still May.
It was in the last NR update (with the CP5 plans) and also in the last issue of Rail.
NR need more time to resignal and remodel the route into Blackpool.
It's not a slip in the overall electrification effort and Balfour Beatty are expected to start work on the Bolton line instead.
However it means that a large mileage will be finished at the same time at the end of 2016 (Stalybridge-Blackpool, basically).
Not sure how realistic that is.
Beveridges
8 Sep 2010
BLACKPOOL
They should get a load of Mk3s and run TnT 37s to attract more people, to get more money, to get more stock.
Enthusiasts after enthusiasts after enthusiasts.
Most people who use the train for commuting use it because there is no other viable alternative. They are obviously prepared to put up with anything during the journey. Using 37's & twelve Mk3's to increase the comfort won't increase the passengers any more than a single 142 carrying 250 passengers at crush capacity, as like I said before, people who use the train for commuting will put up with anything.
Max
8 Jun 2005
Cambridge
I've noticed that, in the last few days, 185s have become the norm again on the Hull-Manchester services for the first time in several years. There are currently two 185s in Hull station and not a 170 in sight. Are TPE reshuffling the pack already?
northwichcat
23 Jan 2009
Northwich
From May around 3/5ths of Hull services are supposed to be 185s, with there being 2 x 4 car 170 diagrams on South TPE. With the 350/4s being gradually introduced TPE may have been able to make some of the changes ahead of the May timetable change.
YorkshireBear
23 Jul 2010
As far as i am aware with Blackpool, they were given £Xmillion to spend on line speed and remodelling. They went away came up with a plan and it cost £2Xmillion so they have had to go back to drawing board with it and that has cost time.
Curtains for the rumoured 125mph then?
I always thought that was an extreme suggestion.
100/110mph max I would have thought, on the straight bits.
Xenophon PCDGS
17 Apr 2011
Would greater benefit now ensue by completing the Bolton line in advance of the Blackpool line ?
YorkshireBear
23 Jul 2010
Oh yes. That was always an extreme suggestion though. Can't see it above 100mph. There was actually a very good talk on it by the PWI in Leeds.
WatcherZero
25 Feb 2010
No, the Bolton line is primarily throttled by tunnel works.
Blackpool work always seem to have been a bit indeterminate. Originally they just planned electrification then they realised that if you had to insulate the signalling anyway and the lines signalling was nearly life expired you might as well renew it at the same time, meanwhile there was always a plan for electric stabling at Blackpool but without a defined budget and scope, just spend whatever was left.
Haydn1971
11 Dec 2012
Sheffield
There was a 185 on the 5:58 from Meadowhall this morning, typically a 170 except on Fridays - sign of things to come or just a bank holiday week special ? Any idea of which services will be a doubled up 170 ? Hopefully the 17:20 Man-Shf
