Exit and re-entry
themeone
17 Feb 2011
If you exit then re-enter a station using a valid season ticket is there a time within which the gates will reject the ticket for re-entry?
I've an idea the ticket might get rejected for re-entry within 10 minutes of exit, but don't know if I'm right.
Greenback
Emeritus Moderator
9 Aug 2009
Llanelli
You are correct in my experiences with various lengths of seasons over a number of years. I wouldn't like to say what the time period is, or whether it's standard across the network.
jon0844
1 Feb 2009
The times can vary. Potters Bar seems to be nearer 30 minutes, for example.
LexyBoy
23 Jan 2009
North of the rivers
20 minutes at Reading which I think is typical.
Interestingly this applies for single/return tickets too: if you're let out they will open the barriers again after the time period.
Haywain
3 Feb 2013
The time for what is called passback can be set by the TOC for each individual gateline. The standard is 15 minutes, but it will vary according to local requirements.
jon0844
1 Feb 2009
I don't know why it's so high at Potters Bar. It's not as if a Travelcard can be used again (given it's one stop outside Zone 6 so will be rejected as the out boundary part has been used) but I suppose for stations within the zones, you'd want to set it for as long as possible given people could leave and pass/sell their ticket to someone else for re-use over and over until 0429!
SAPhil
27 Jan 2011
It's very annoying at Blackfriars if you are changing from southbound Thameslink to South Eastern and your connection is a bit tight!
12CSVT
18 Aug 2010
Use the south end of the station to change platforms and you won't need to pass through any barriers.
Kite159
27 Jan 2014
West of Andover
Waterloo is quite good at allowing exit and re-entry within a couple minutes. Useful when transferring from platforms on the Wimbledon suburban platforms to the Windsor platforms.
Starmill
18 May 2012
Bolton
How many passengers will be making this transfer at Waterloo rather than Clapham Junction?
Kite159
27 Jan 2014
West of Andover
Quite a few of the long distance services don't stop at Clapham at all, some only stop during the peaks (for a couple peak services the first stop from Waterloo is Winchester)
