Ex-LNER Mk4 sets for Grand Central (Blackpool - Euston)
I think that was the 06:20 Rugby - Euston via Northampton, which was the regular Pretendolino turn. It was always punctual ex Rugby. Hard to imagine it losing 3 minutes from Hanslope. I guess it could have lost time on the climb out of Northampton.
Or maybe just the timetable was wrong even if it had been a Pendo, though I recall when it went over to one it was mostly on time. (Apologies for the misinformation there, I thought it came from Brum - losing 3 minutes NMP-MKC is pretty bad!)
Mollman
21 Sep 2016
Preston
Very true, they tried to order new build ones but they would require modification to be compliant for new builds. I can't remember exactly what was an issue.
I think part of it was to do with cost. If First's original awarding of the ICWC franchise had stuck then GC would have simply tagged on the end of their order for baby Pendolinos, but as it was scrapped then GC would have had to carry the cost of re-starting the production line which was uneconomical for such a small order.
Speed43125
20 Jul 2019
Dunblane
I recall there was talk of ordering 6 car Pendolinos at one point presumably for an OAC, what were first ICWC in 2007 planning to order for the franchise?
Railperf
30 Oct 2017
Exactly. A 390 will comfortably beat a 90+mk4 train - that much is obvious just from looking at the installed power and distributed traction. But a 90 will beat a 91 in acceleration terms for the same train, it'd be interesting to see if the railperf archives have any numbers on just how much the margin is!
With a regular load of ten MK3's , The 90 is only around 15 seconds quicker from rest to seven miles than a 91 with its ten MK4's!
Add extra -another minute minimum - if it is raining
A 390 is almost a minute and a half quicker than the 90!
Domh245
6 Apr 2013
nowhere
Interesting, although I would expect that by the 7 mile mark, both locos are at their respective maximum speeds (hence the 91 bearing down on the 90!) - is there no data about the time to 110mph?
That's always assuming there is still some sort of market for Open Access operations once the lockdown is over. If the "franchised" TOCs are all under Government control, why would anybody want to allow private operators to undermine the publicly-funded operators? Right-wing free-market ideologues, yes, but not very many other people would agree with them methinks?
They'd have to specifically revoke the EU TSI legislation that's automatically copypasted into our own law. I'm not sure how politically palatable that would be.
Very palatable I suspect once we have fully left the EU.
GC has access rights granted by ORR to run on the WCML (notionally until HS2 starts up).
They are in the same position as any other current open access or freight operator.
The government can't just cancel those rights whether we are in or out of EU legislation.
They could offer to buy out those rights, of course, or GC could simply choose not to exercise them if the business case has evaporated.
rebmcr
15 Nov 2011
St Neots
The "Open Access market" of course relies on being able to create and renew (or it's not a market), not just seeing-out existing agreements.
rebmcr
15 Nov 2011
St Neots
Plus, Mk4s are around 20% heavier than Mk3s.
59CosG95
18 Aug 2013
Beeston (Notts)
So, to recap:
HT04 (ex-BN19), HT05 (ex-BN20) & HT06 (ex-BN21) are all now at Widnes for refurb & repaint.
That leaves HT07 (ex-BN22) still at Wembley IIRC; no idea when it'll go into Widnes itself.
Defiance149
30 Dec 2013
So, to recap:
All four are at Widnes, HT07 arrived in March.
Just a gentle reminder this thread is to discuss Ex-LNER Mk4 sets for Grand Central (Blackpool - Euston), thanks :)
If anyone wishes to discuss matters related to Covid19, please use that section. For suggestions/ideas/speculation not related to Covid19 please use the Speculative Ideas section. We also have History & Nostalgia and Timetabling sections. If in doubt please contact us :)
DB
Guest
18 Nov 2009
The existing Pendolino design is also not compliant with current crash requirements - it wasn't when the last four were built, either, but a derogation was granted because one was a replacement for withdrawn 033, and I seem to recall reading that four sets was the minimum viable order. Probably it could be redesigned, but for a small order this would likely make the cost per unit very high.
DB
Guest
18 Nov 2009
Is it clear yet what they will be doing to the interiors of the Mk4s?
XCTurbostar
13 Sep 2014
The Grand Central press release uses the word ‘refresh’ so I would expect seat coverings, stickers and carpets to be renewed and that’s about it.
trainmania100
8 Nov 2015
Newhaven
Quick Facebook search, shows these stunning pictures. I must share my opinions that they look absolutely stunning and fairly confident I'll be booking a day off work to see these in full rake on the WCML
43 302
25 Oct 2019
They do look great. Reminds me of the GNER livery but with the line extending the full length of the class 90. (And different colours obviously). I heard that one set may be used on the ECML to cover for 180s undergoing repairs, not sure how true that is mind.
XCTurbostar
13 Sep 2014
There's not a lot wrong with the interiors, so not a lot of work is needed! Though at least unlike TfW they've been bothered to paint them.
I suppose, just like the HSTs, it demonstrates how adaptable the VTEC Coke Can livery is. Having said that, the TfW consist looks pretty shoddy especially with off white loco and DVT.
Back on topic.
Its an interesting decision to retain the 90s (what I assume are) hallogen lights instead of opting for the HID lights with combined markers and tails.
43096
23 Nov 2015
They are the original lamps - DB only appear to be changing out their Class 66 fleet. No 60s, 67s, 90s or 92 have been changed. Neither Freightliner nor DB have changed their 90s' headlights; the ex-Anglia fleet has been altered - it will be interesting to see if 90016/041-049 get changed if Freightliner get complaints from drivers when the 90003-015 batch enter service.
TT-ONR-NRN
30 Dec 2016
Cambridge
Route clearance wouldn’t be an issue I guess with MK4s as ECML stock anyway, but they’d have to terminate short at Doncaster or Northallerton for West Riding and North East respectively due to lack of electrification beyond
XCTurbostar
13 Sep 2014
I think all they've done to the 90 is paint it, isn't it?
My records indicate that all apart from 90021 have worked LNERs mk4s within the last 3 years so I doubt its anything put paint and a like for like underframe component overhaul.
They look garish to me (maybe that's the idea).
Black is a nod to the LNWR route, but the other branding is too American for me.
supervc-10
4 Mar 2012
I think it looks great! Especially the 90 with the white tyres, although I'm sure those will disappear within days of starting operations!
Definitely going to have to take a trip down south with GC once everything is back to normal.
31160
18 Mar 2018
Are we any closer to knowing when they will start running, i know that may be a difficult question at the minute with the global situation and all
D365
29 Jun 2012
Start of passenger service has been pushed to 2021 (in case you haven’t seen) - so that gives a lot more time for testing/crew training.
Mollman
21 Sep 2016
Preston
That rings a bell as to another reason why a GC only order could not be justified along with changes to the computer system.
Neptune
29 May 2018
I think the branding looks great, especially since they added the orange stripe was added with the first 180 repaint. The logo is of course a nod to Grand Central terminal in New York. Very distinctive compared to most of the pap logos out there.
