Ex LNER (and Grand Central) Mark 4 sets for TfW
Anonymous10
19 Dec 2019
wales
Thanks :) Hopefully it'll be back in action before too long!
Chaos on the Marches today it appears, all gone belly up after I left it this morning and I'm currently melting away on 150267+150208 at Shrewsbury. Such a contrast to the 158 this morning, and even more to the MK4s on Wednesday!
If its belly up there it's worse in Pembroke no trains west of Carmarthen and no rail replacement operating, it says this is only expected today but I can't see it magically getting back to usual overnight
Topological
20 Feb 2023
Swansea
Not a great start for the extra Manchester diagram it seems. The 1250(ish) from Cardiff to Manchester has disappeared after 22:00. It was briefly there as a 67 + Mk4.
The 1052 and 1855 are showing as 67 + Mk4 plus the 0849 and 1649 are also suggesting it has 4 carriages, but not showing what 4. My understanding is that those two are a later diagram to change.
MP393
28 Jun 2021
North West
The 12:49 from Cardiff is starting at Crewe with 67012. That will then work the 16:30 Manchester - Swansea.
The 08:49/16:49 ex Cardiff is 67013
Jez
22 Jan 2011
Neath
Great to see the 1630 that goes through to Swansea is finally a MK4!
The 0536 from Swansea was a 150. However this one isn't due to be a MK4 just yet.
Topological
20 Feb 2023
Swansea
150 as far as Cardiff then cancelled. Was showing Manchester Piccadilly on the screens until around 05:25 and then it suddenly switched to Cardiff only.
Jez
22 Jan 2011
Neath
Assume there wasn't enough train crew to take it onwards from Cardiff?
I see that the 1630 was also cancelled from Manchester to Swansea.
Topological
20 Feb 2023
Swansea
Yes, they didnt seem to get a replacement unit for the 1630.
Was a 2 hour delay coming north and do not want to think about what it is going to be like coming the other way. That said I have a first class advance so let's see.
Jacob Porrett
28 Jan 2022
Telford
Yesterday 67013 + HD02 + 82229 and 67029 were out which was good to see. Both Manchester to Cardiff runs. 013 was cancelled at Wilmslow in the morning and started from Wilmslow after but it was OK after that for the rest of the day.
SuperLuke2334
23 Oct 2021
Welsh Marches
Test runs for HD03 with 67008 today. Looks like a run to Hereford.
3A03 Landore to Hereford.
There's no return path in yet but they should put one in as its due to run the same path tomorrow.
SuperLuke2334
23 Oct 2021
Welsh Marches
Thanks for that, I hope to pop out to somewhere and see that later :)
This is only going as far as Cardiff today now on 3A00. Hereford tomorrow I am told.
Topological
20 Feb 2023
Swansea
HD06 appears to have left Cardiff 26 late on 1W19. That is the first notable delay on the Manchester route today.
No additional delay between Cardiff and Newport.
40 down at Shrewsbury on the return 1V50.
At least it was not turned at Wilmslow.
Edit: Ended 75 late at Cardiff with the Swansea leg cancelled.
Jacob Porrett
28 Jan 2022
Telford
Today only on set on the Manchester to Swansea route. 16:30 is 67012 HD05 (GC02) 82200 the 05:36 from Swansea to Manchester is a pair of 150s like yesterday.
sd0733
7 Nov 2012
The 0536 from Swansea is booked a pair of 150s.
HD01, 02, 05 and 06 are out covering all the booked Mk4 turns.
HD03 is also out on test runs between Landore and Hereford as a 5 car.
Jez
22 Jan 2011
Neath
I think yesterday was the first day this week a set made it to Swansea on the 1630.
Welshguy1048
6 Apr 2023
North Wales
Hello.
Can you help please with with the number of the DVT for each MK 4 set - ie. HD01 to HD06? I think that is all that is in use at the moment.
Just like to put the numbers of the DVT on my YouTube videos as well as the Loco number. Am unable to get the numbers of the DVT sometimes.
Thank you.
Dave
sd0733
7 Nov 2012
Hello.
Thank you.
Dave
HD01- 82226
HD02- 82229
HD03- 82216
HD04- 82201
HD05- 82200
HD06- 82227
HD07- 82230
Topological
20 Feb 2023
Swansea
And what a good way it is to travel too :)
Would still happily swap the option for an advance first on the 1630 for a more reliable train at other times of the day though.
Jacob Porrett
28 Jan 2022
Telford
Ah right so the 0536 from Swansea won't be a mk4 set then by the looks of it?
Jez
22 Jan 2011
Neath
Yes they would be fabulous if they were more reliable !
sd0733
7 Nov 2012
I had a quick look on RTT and it seems to be running a bit better these last couple of days... Weird!
Monday was a bit of a blip but even then was nothing wrong with the sets.
Things work better when they're used regularly, they were picking up anyway before the TT. these extra diagrams also give the crews a big uplift in work so familiarity is increasing quite quickly.
Not yet no, the diagrams are in post 2494.
