Ex LNER (and Grand Central) Mark 4 sets for TfW
sd0733
7 Nov 2012
I noticed that, means the train before hand (21:XX arrival into Piccadilly) needs to be a pair of units as it splits at Piccadilly to form both the 21:30 & 22:30 services. Which tonight seems didn't happen with the 21:30 cancelled.
I presume the ECS goes via Warrington to get route knowledge (especially for Warrington - Crewe) in case they need to get sent that way (instead of TfW throwing in the towel and terminating at Crewe as what normally happens when the line towards Stockport is closed).
Did GC get round to fitting plug sockets in the buffet coach or is that a socket free zone?
The same happens with the other set which arrives at 20:15, that returns empty too so the 19:15 and 21:15 unit arrivals are pairs which then split with 1 pair forming 19:30 and 20:30 amd the other doing the last 2 departures.
The route the ecs takes is different on different days. Whichever route the evening working takes is matched next morning ie Monday night it goes via Warrington so Tuesday mornings go via Warrington, Fri night is via Styal so Saturday morning back is via Styal, this does maintain route knowledge but also supposedly keeps the sets in the right formation, although there's already a mix.
No power points in the buffet, was looked at but there are power issues supplying every electrical circuit plus power sockets in there.
Seems to have been some kind of incident with the MK4 set on 1W93 today (1125 Cardiff-Holyhead), terminated at Abergavenny with "problem with traction equipment".
2-car 150 substituting from Chester onwards and back to Cardiff.
Also knock-on to the following Manchester service (175) which is turning at Crewe.
sd0733
7 Nov 2012
Wasn't an incident as such, just a fault which as a precaution was sent back to Canton.
The set on 1V46 has now totally failed and lost power.
E-Rail
7 Dec 2012
Having been on 1W93, it seemed to be a door locking issue that prevented a departure from Abergavenny.
sd0733
7 Nov 2012
Yes it was. The Integrity (door interlock) system is proving a big problem on the ex-GC sets so far, presumably linked to lack of use over the past few years. HD04 is sidelined at Crewe with it and 06 had the issues today which are planned to be rectified and should be out tomorrow and HD05 has had issues too In its brief stint in service before it went for SDO
And the following Manchester-Carmarthen 175 (1V48) is now being held up for the second time today, having turned at Crewe earlier because of the 1W93 failure.
TfW still showing "good service" for the route.
E-Rail
7 Dec 2012
Superb refurb by Grand Central though. Ambience definitely restored.
Wizard51
8 Jan 2023
Shrewsbury
s
I assume there is little chance of a set now for the start off Manchester tomorrow?
LowLevel
26 Oct 2013
Door systems always go wrong with lack of use - the EMR 170s were horrendous for door faults for quite a while and still have the odd hiccup now, though they've settled down significantly.
Once they're being operated multiple times per hour they'll be working well again I'm sure!
sd0733
7 Nov 2012
The interiors are really good. There's a few bits mechanically...not quite so much. Sure with more use and familiarity things Will soon pick up
s
Doesn't look promising there's a set In Crewe but it's had a fault and has no loco so would be surprised to see that out in the morning.
Yes exactly, sure they'll be fine pretty soon Just teething glitches
Unfortunately 2 failures out of 3 sets on day 2 isn't particularly instilling confidence in crews!
JakeMurphy
30 Aug 2018
I saw HD03 has 67015 now isn’t that available?
RTT thinks HD05 is on the evening Cardiff-Holyhead (1W96) with 67 013.
Nothing seems to be moving southwards from Leominster.
Southbounds queuing back to Shrewsbury, and the 1730 ex Manchester is about to join the 1630 in the platform at Shrewsbury.
SuperLuke2334
23 Oct 2021
Welsh Marches
sd0733 said HD05 had issues prior to SDO fitting.
Sheridan
11 Jan 2012
Rescue will almost always take longer with these than with 175s, simply because you can’t just use the following service or the first one in the opposite direction. Although I suppose with mk4s and 175s alternating that might work both ways now.
sd0733
7 Nov 2012
Oh right I got lucky with 1V46 I had it Manchester to Crewe..
A rescue loco is on the way 1Z99
Yes should be a loco from Canton and fitter en route
HD05 has been working and has so far been OK since it's return.
After speaking to staff on the train sounds like it could be blocked for a while.
TT-ONR-NRN
30 Dec 2016
Cambridge
Is 67015 done with TfW then :)
JakeMurphy
30 Aug 2018
67029 I’ve seen
Caaardiff
9 Jun 2019
Got a friend on this and they've just been taken off the train to a 175 on the other line via a ramp.
sd0733
7 Nov 2012
Could one rightfully assume that tomorrow's diagrams ex Canton and Ex Crewe will be unit substitutions?
Only Mk4s are now 1V91, 1W57, 1V46, 1W65 everything else units today
The failure from last night has been abandoned at Hereford I believe.
