Ex LNER (and Grand Central) Mark 4 sets for TfW
BillStampy
6 Jan 2024
Llanharan
A door fault, so running empty to Canton now as 5V50. Not the best re-entry into service! Fingers crossed it can be looked at on Canton, and that HD06 comes off Crewe tomorrow. Bank Holiday weekend sure does mean the capacity is needed!
Hopefully! If it's a door fault then there shouldn't be too much of a problem to get the set running again hopefully. Canton can probably sort it for its Saturday diagrams!
SuperLuke2334
23 Oct 2021
Welsh Marches
HD02 was always having door faults, so not surprising honestly! :lol:
sd0733
7 Nov 2012
If it all goes to plan should be the regular 3 Saturday diagrams:
67025+HD02
05:30 Swansea to Manchester Pic
10:30 Manchester Pic to Cardiff
16:50 Cardiff to Manchester Pic
67012+HD03
04:54 Crewe to Cardiff
14:53 Cardiff to Manchester Pic
18:30 Manchester Pic to Cardiff
Unit
06:27 Manchester Pic to Cardiff
10:52 Cardiff to Manchester Pic
14:30 Manchester Pic to Cardiff
18:55 Cardiff to Manchester Pic
Unit
(Ironically, this diagram has gone back to a Mk4 tomorrow officially but is a planned swap tomorrow)
04:25 Cardiff to Manchester Pic
08:30 Manchester Pic to Cardiff
12:52 Cardiff to Manchester Pic
16:30 Manchester Pic to Swansea
Sunday should have HD02 on the Crewe Diagram and HD03 on the Cardiff.
HD06 letting the side down once again and not expected out tomorrow now.
Availability of HD02 and 06 is really trashing the diagrams at the moment.
Jez
22 Jan 2011
Neath
It looks like the 0627, 0830, 1230, 1430 and 1630 from Manchester are all 197s today (mostly 3 cars but a 2 car on the 1230)
Therefore only the 1030 and 1830 departures are MK4's. In the week these are the 2 that are least likely to be a MK4
Starmill
18 May 2012
Bolton
There was one minor blessing in that the 1730 from Manchester Piccadilly yesterday was a three car rather than a two car, as it was very much busier than usual from Abergavenny :lol: I always remember it being a two car 175 and have had the misfortune of using it as a two car 197 while CrossCountry are still refusing to stop at Wilmslow and Crewe (and on one Thursday a few months trying to board it at Manchester Piccadilly just before departure and having to give up because I physically couldn't squeeze in).
Western 52
19 Jun 2020
Burry Port
Is the Crewe start today a MK4? Currently showing on RTT as 197103 + HD02.
Tfw journey check shows it with reduced facilities, so probably a unit. The Cardiff start is showing as 67012 on RTT.
BillStampy
6 Jan 2024
Llanharan
Does indeed, doesn't saying anything about a lack of coaches, so it counts on what allocation it shows changes, because it might be automatically saying that it has no facilities due to the 197 on the allocation but still sees plenty of coaches. Just what I think though, unsure of it entirely. I'll see if it changes once it gets moving.
sd0733
7 Nov 2012
Seems to have been swapped off, Certainly was showing but now showing as just the 197 internally. Not sure what happened to it.
BillStampy
6 Jan 2024
Llanharan
That's a little odd, the set should be okay? Not exactly the best with the capacity needed for Cardiff today.
sd0733
7 Nov 2012
HD02 did indeed have (yet another) door fault. They've plague that set for some time.
It's planned back out tomorrow along with HD06 on the Crewe starts, not an especially promising sign relying on those 2.
Tomorrow, HD04 should head back from Crewe ETD following tyre turning whilst a loco (not 020 anymore as that's had to go back to Toton for further work following a test run) will head to Holyhead tomorrow or Tuesday to collect HD05 and take it to Canton for an exam to get it back in service albeit as a 4 car.
Jez
22 Jan 2011
Neath
The 1032 Swansea is definately a MK4. Ive just seen it passing. At least they managed to get this one out today as last Sunday it was a pair of 153s.
BillStampy
6 Jan 2024
Llanharan
1 set is better than none, saw it pass empty from Canton 2 hours ago. The door issue on HD02 is getting very repetitive.
Plodster
21 Feb 2019
North
It’s time the set that ‘rests’ over the weekend at Holyhead is used in service.
There has been an acknowledgment that travel patterns have shifted since the pandemic with growth in weekend and leisure travel.
Capacity is need across the network especially now that spring and summer are here.
1V90 was a two car 197 today full and standing (circa 200) for most of the journey along the North Coast with Platform Support staff at a number of stations to help with passenger numbers.
I’m sure this is just one example of many…
MP393
28 Jun 2021
North West
The capacity is definitely needed, but it would require a lot of jigging around of stops and crew. The Mk4 couldn’t do todays 1V90, for example, as it can’t call at the request stops on the island, the locals between Bangor & Llan Junction or Shotton. It would also require to only be on trains on the coast worked purely by Holyhead crews as Llandudno Jn & Chester don’t sign them, and to use 1V90 as an example it’s also a Shrewsbury driver between Chester & Shrewsbury who don’t touch them either.
Definitely beneficial to get it out over the summer weekends and whilst it’s probably not impossible, it probably is the resourcing that causes the most issues and headaches, as well as the “missed” stops.
It would certainly be good to get it out on Holyhead - Crewe runs if it was possible, like the 67/Mk3 workings did a few summers ago, which I think doubled up as a maintenance swap between Crewe & Holyhead over the weekend.
Kite159
27 Jan 2014
West of Andover
Agreed there, even if they run it as an additional service between Holyhead & Crewe with a similar calling pattern to an Avanti service. Would help soak up crowds for when it gets a bit hot and every man & his dog from the Wirral ends up wanting to visit Rhyl or Llandudno. Anything is better than a 2 coach 197 leaving passengers behind at Chester etc
MP393
28 Jun 2021
North West
67013 + HD06 missing in action again today. 197107 covering the 04:54 start from Crewe (1V31)
EDIT 12:30hrs
67013+HD06
1V42 13:10 Crewe - Cardiff
1W23 16:49 Cardiff - Manchester
3 sets are currently
67012+HD03
1W11 04:35 Cardiff - Manchester
1V37 08:30 Manchester - Cardiff
1W96 17:14 Cardiff - Holyhead
67022+HD07
1V91 05:30 Holyhead - Cardiff
1W57 10:52 Cardiff - Manchester
1V46 14:30 Manchester - Cardiff
1W55 18:55 Cardiff - Manchester
67025+HD02
1V33 06:26 Manchester - Cardiff
1W19 12:49 Cardiff - Manchester
1V50 16:30 Manchester - Swansea
Lurcheroo
21 Sep 2021
Wales
HD06 is missing as Arriva Train Care did not have time to prep HDO6 overnight due to a staff shortage and that the unit needed the water treating so a 197 was used to cover its diagram.
At least it’s a 3 car but the extra capacity of the MK4 and freeing up the 197 for something else would be most welcome on this lovely bank holiday no doubt.
Perhaps it Will get swapped onto its diagram later ?
BillStampy
6 Jan 2024
Llanharan
Lurcheroo
21 Sep 2021
Wales
Now allocated to swap into 1V42 down to Cardiff from Crewe
Fantastic!
I notice the 11:25 From Cardiff to Holyhead and the 11:30 Manchester - Camarthen are both 2 car 197’s and reported full and standing from their origins. Hopefully that 3 car can be put to good use to relieve overcrowding elsewhere.
sd0733
7 Nov 2012
HD06 is now finally on its way, at about 5 days later than originally planned! It's now planned to be kept on the 04:54 from Crewe start for the next couple of days allowing it to be monitored, finishing at Crewe each evening.
Of the other sets, 67008 has moved from HD01 to HD02, 67025 is planned to head to Holyhead later to go onto HD05 which will then head to Canton tomorrow.
67014 should go onto HD01 which is stopped on Crewe for B exam with HD03 expected to stop on Friday for its exam.
HD04 should also be available from Thursday as the 6th 5 car rake.
Lurcheroo
21 Sep 2021
Wales
That’s great ! Things seem to be looking up and we will hopefully manage to have 4 sets out fairly consistently.
Any idea when the last set will become a 5 car ?
sd0733
7 Nov 2012
Certainly looks better than the recent poor performance! Hopefully the spate of issues ends.
Not totally sure of what the plan is now to get HD05 done with regards to 5 car to be honest.
@sd0733 Hello
Is 67025 still due to head to Holyhead today?
Dave
The latest plan I heard was its still planned to go but unsure of any timings, certainly was the aim to get HD05 to Canton tomorrow so if it doesn't go today potentially it could head down in the morning.
