Ex LM 321 TSO's to be scrapped
Class455
19 May 2016
Apologies if mentioned elsewhere, but I couldn't find any existing threads on this topic
According to the RAIL Magazine, the 7 Class 321 TSO's (71959-71966) which were removed from 321411-417 are to be scrapped.
My personal opinion on this is that Eversholt could have at least retained these TSO's as spares in case anything happened to its BREL MK3 stock (318/320/321/455) since the last vehicle they kept spare (67301) was sold to Porterbrook and is now in 455 913. Alternatively, they could have been used in the first 7 455/7's enabling the old 508 TSO's to be scrapped instead.
NSEFAN
17 Jun 2007
Southampton
I imagine any spares will be taken from these vehicles before they're scrapped. They may possible have had a use as extending some class 455s to 5 car for SWT's 10 car suburban railway, however I don't know how much this would affect the acceleration, or if it'd be worth it for the hassle of creating a microfleet of 7 units.
47802
6 Mar 2010
Why most people in the know seem to think whoever wins the SWT franchise will replace the 455's, there will be loads of spare 321's in a few years, I wouldn't be surprised to see the W Midlands franchise take new trains in preference to the Siemens units which maybe spare other than maybe the 350/4.
So let the scrapping begin, and bad news for the oh you carn't scrap that, you can get another 60 years of use out of that brigade.
61653 HTAFC
18 Dec 2012
I'm not sure there'd be much to gain in replacing the 508 trailers in the 455/7s. There are more 455/7s than there are spare TSOs, so you'd be creating yet another variation in the SWT fleet. They'd need a fair bit spent on them to bring them up to SWT standards too. Additionally as the 508 cars are aluminium rather than steel there'd be weight differences too, along with the differences in when and where corrosion issues crop up in the two different types. The only real advantage would be a more consistent look to the units, which isn't worth the cost.
I can see the argument for retaining a few shells as spares, but given the large numbers of mk3-based EMUs that will soon be going off-lease, there's unlikely to be a shortage of donors in the unlikely event of a single vehicle being written off.
XCTurbostar
13 Sep 2014
I'm not why this would be the case because theyre (Class 455s) currently being put through a re-tractioning programme. So that would suggest that theyre being re-tractioned for.. nothing?
Thanks,
Ross
D365
29 Jun 2012
We've been through it on the relevant discussions, the retractioning came about as part of the Class 707 order and would not have been done otherwise.
D365
29 Jun 2012
I think that this thread was doomed from the start.
Wivenswold
24 Jul 2012
Essex
I think the imminent abundance of 2nd Generation EMU stock, some of which will be DDA compliant, has led to this.
The 321s are nearing their 30th birthdays, a few will be around when they're 40 I'm sure but I can't see the point of keeping coaches that will sit and rust just in case they're needed in the short term. Once the 319s have found new homes, there will a small batch of 317s and 60-odd 315s available from TfL for a short term fix.
43021HST
11 Sep 2008
Taunton
I was literally just about to say that!!!
Thanks,
Ross
Mount Ford engines under them, couple them between a 442 set to provide power for the traction motors and a Pacer driving car to provide a driving trailer on the other end and you have a perfectly reconditioned, Bimode EMU perfect for the Waterloo - Exeter runs. Splendid!
You beat me to bringing 442s in, I was going to say if the 455s are scrapped move the traction equipment over and away you go...umm... :)
Bit of rewiring, and you've got a TSO for a 150!
The problem is that a 150 with a TSO is going to be rather sluggish.
Stick an engine under it?
If you can't beat 'em, join 'em...
Probably easier to double up a pair of 150s (or make 3-car sets by putting a 150/2 vehicle in the middle of two halves of 150/1) and build a D-319 to go with them, to be honest.
Sad though it is when things get scrapped, there's going to be a glut of Mk3-based EMUs on the market soon...
387star
Strange turn of events considering there are a lot of older trains including the 313s but unfortunately I can see there is no home for them
D365
29 Jun 2012
I can't see a home for seven orphaned TSOs either ;)
Mikey C
11 Feb 2013
But then these aren't whole trains, just left over spare carriages...
Tracked
30 May 2011
53.5440°N 1.1510°W
Beaten to it :cry:
Can a couple of 37's haul them round some little coastal route somewhere?
SpacePhoenix
18 Mar 2014
Why did ScotRail remove them? Would the 321s have been to long for the route(s) they are used on had the TSOs been left in place?
61653 HTAFC
18 Dec 2012
Glasgow suburban services via the "low level" lines work on a basis of 3/6-car formations. 4-car units would be too long to double up with other units.
