Eurostar viewing location
5 Sep 2016
Evening, where would you recommend close to London as somewhere I can read off Eurostar / Javelin numbers and preferably also see freight / c2c / SE units (less need to be close enough to read as I can use RTT).
I thought Barking was perfect until I realised HS1 was underground there :s
Peter Mugridge
8 Apr 2010
Epsom
Stratford International should do for the Eurostar and 395s?
For freight you can then move across to the normal Stratford - usually two or three freights in each hour there.
165009
5 Sep 2016
Thanks, I was hoping more for somewhere to see all at the same time. Rainham or Dagenham possibly but I've never been and don't want to waste a trip if you can't see both lines there
deltic14
13 Oct 2019
Ossett
Rainham and Dagenham offer opportunities to see both freights, Eurostars, and 395's but the later two move fast and being quite close it is almost impossible to get the numbers..
Peter Mugridge
8 Apr 2010
Epsom
The RSPB reserve at Rainham Marshes is adjacent to the line but yes, you will likely need binoculars to stand any chance of getting the numbers... The 374s will be easier as they have larger digits, but at speed ( the linespeed is 140 mph at that location ), yes, binoculars will be a must.
165009
5 Sep 2016
Thanks both, I went to Dagenham Docks and eventually ended up sat at the London end of the eastbound platform. Could read both the Javelins and Eurostars
MatthewE707
17 Apr 2025
Essex
Did this require binoculars in the end? Isn't HS1 higher up than the c2c platforms?
165009
5 Sep 2016
Nope, could read them with my eyes. I started on the London-bound platform but it's too close; the eastbound platform was fine.
They're at the same track level at this point, I think HS1 has only just come out of the tunnel so hasn't yet got higher
