Europhoenix acquire Class 91s for use overseas
fgwrich
15 Apr 2009
Hampshire
Certainly would have thought 90s would be a better fit, and the GA examples will be freed up in the coming months. The only reason to select 91s instead (unless they're also significantly cheaper than 90s would be) would be if they're needed before any 90s become available.
I believe Porterbrook may have a use lined up for their 90s, whereas Eversholt clearly doesn't have as much use for the 91s.
westcoaster
4 Dec 2006
DTOS A or B
I spoke to a colleague the other day who said ROG were getting 2X91's for testing the new wires on the MML.
davewolves
19 Sep 2016
as for selling Mk4 coaches with them, the problem is there long-wheelbase probably won't fit into many on their stations that are on tight curves seem to remember something about them having clearance issues on some UK lines
hexagon789
2 Sep 2016
They've been replaced with 90's as they'll only operate at 110 and 90's are faster to 110 than 91's.
Not sure about that actually, certainly to at least 80 but then the 91 starts catching up ;)
I thought they had plenty of ex-DB/DR 26m stuff? Surely that's got a longer wheelbase than our Mk4s?
ExRes
16 Dec 2012
Back in Sussex
WNXX update this evening says that this is a joint venture with Voith for up to 20 Class 91s to be re-geared after export as freight hauling pairs in blunt end to blunt end formation
hexagon789
2 Sep 2016
Be quite punchy with over 12,000hp!
hwl
5 Feb 2012
If they re-gear for 70mph (down from the current 140mph max) then the pairing should have roughly the same continuous tractive effort as 2.5 of the latest spec GE/EMD locos in the states at the same speed so pretty useful for freight on the continent.
hexagon789
2 Sep 2016
I'm not sure how fast freight can run in Bulgaria, but 100km/h max seems typical. I could see a regearing to say 120-130km/h though.
Richard Scott
International Transport
Railtours & Preservation
13 Dec 2018
Having travelled on a few lines in Bulgaria even 100km/h seems optimistic!
hooverboy
12 Oct 2017
Just as a thought, I'm a master at knowing nothing about the technical side of things, if we put a 91 against a 90 as a passenger loco then the 91 is obviously in the lead but a 90 is perfectly capable, what though if we were to compare the two as freight locos? how would a 91 perform given a couple of thousand tons to haul? if you needed an available electric loco for freight would a 91 be worth the effort?
the gearing is different.
cl90's are very quick off the blocks but not so good high end.as freight loco's they are pretty well proven workhorses,and a good cl86 replacement.
no reason why cl91 coudn't be regeared. ok lower speed but extra poles in traction motors= way extra torque.
for freight use realistically only 75mph/90mph operation required.
they can pull 500t at 140mph with existing setup, so 1000t at 75mph is not that far off with new traction motors.
malc-c
1 Dec 2017
There is a report on WNXX this morning that 91120 is to transfer tomorrow to Leicester in Europhoenix livery, coincidentally there is an 0857 0Z91 Bounds Green to Leicester LIP being operated by GBRf, fact or fiction? could be a few people on the platforms at Leicester around 1215 tomorrow ....
How certain are you that this will this run....
hexagon789
2 Sep 2016
Just an arbitrary figure, not knowing which lines they'll run on or anything, but some short stints of 100km/h doesn't seem too unlikely.
Besides, if it's like the 87s, they might get used on rail tours.
Likely more as they are being used in pairs.
SPADTrap
15 Oct 2012
It has been said before on this thread, there is no use for a high-geared racehorse that was designed to race up the ECML with no other intentions. There is no market for these kind of locomotives in Eastern Europe (If anybody can prove me otherwise then fire away!) Also they're incredibly knackered, so I doubt they would get far in Mainland Europe.
No market you say? Any idea what they're going to do ?
malc-c
1 Dec 2017
Ignore my post, see there are two 91's listed in their facebook page https://www.facebook.com/EurophoenixLtd/
I must say they look great - shame they are being exported and not used in the UK
hexagon789
2 Sep 2016
Not immediately, they'll be here for a bit yet. If anything it's nice to see them going on to further use, though it's a bit of a shame it has to be abroad but better than the knacker's yard.
malc-c
1 Dec 2017
I agree 100% - it's so sad seeing so much stock being dragged for scrap. I know the 91's are old and progress moves on, but it seems that the old trend of "repair and making do" has long gone for "throw it away and replace with new" - Nice to see Europhoenix bucking that trend and living up to their name. These two have certainly risen from the ashes in true phoenix style.
I assume by MML that will be the testing of the new OHLE on the midland line through Bedford ? - If so I'm going to make sure I get some video of them before they depart for Belgium.
Well done Europhoenix for giving these two a further lease of life.
malc-c
1 Dec 2017
Well that will keep the guys at Bound Green Depot busy then... :)
Hopefully, with so much interest and support Europhoenix might make that a total of 21 and keep one running (geared or not) for use on the UK rail... maybe we should start a petition / campaign :)
Speed43125
20 Jul 2019
Dunblane
I would remain Hopeful with Europhoenix, they seem to know what they're doing, and much like ROG seem to do surprisingly well with old traction (I mean compare their 37s with DBs experience with them).
Are all of theirs going to be exported or is there a possibility of them working freights here?
If some stay here the irony of one standing in for a 90 on a mk4 rake when they're in for maintenance would be a joy to behold.
