ETCS expansion into London Bridge station
RichardGore
15 Jul 2018
Coulsdon
On passing through London Bridge recently I could not help but notice an ETCS block marker within the station, as well as a number of end of cab signalling signs on the approach (and one on the curve from Blackfriars to Cannon St) which were not there before.
I recall the limits of ETCS being just the Thameslink core itself; how far is it expanding now and is there any public documentation on what the ETCS rollout plans actually are?
Thanks in advance!
Thanks in advance!
There’s a Network Change Notice about this - probably linked in an previous thread. The south end ETCS boundaries are definitely wider than just Blackfriars. Will try and find it in the morning.
Meanwhile this rail engineer magazine article includes an ETCS/ATO coverage schematic:
https://www.railengineer.co.uk/2017/03/22/thameslink-signalling-update/
collexions
18 Jan 2010
Avoncliff Halt
ETCS covers the Thameslink Core South workstation area extension through lines 4 and 5 to beyond Bermondsey Diveunder.
Also provided at London Bridge platform 3 (Cannon Street workstation) and platform 6 (Charing Cross workstation) for operational flexibility if issue at LB dedicated Thameslink platforms 4&5.
RichardN
29 Nov 2013
Any idea when the ETCS/ATO will be going live? My understanding is that the colour light signals will be showing flashing single yellows when ATO is active. Since every time I go that way I see normal colour light operation I guess it isn't in normal use yet.
From all the previous discussions, which will be buried in one of the Thameslink threads, ATO is not required until the 24 tph peak service becomes the normal situation, and is definitely not in normal day to day use now. But it has been successfully tested and demonstrated in public service over the section between St Pancras and Blackfriars.
ETCS/ATO is live. It’s just not being used.
The signals won’t be flashing yellow either. They will be lit as normal.Not sure where that suggestion comes from.
aleggatta
28 Sep 2015
I think the suggestion might have come from the thought a train having to pass a 'danger' signal trackside when they might be receiving a 'proceed' aspect in-cab?
carriageline
11 Jan 2012
Just a minor correction! It isn’t provided through 3 & 6. The train will transition out if signalled into either of these platforms.
RichardGore
15 Jul 2018
Coulsdon
It still seems odd to me that drivers are not using it to gain familiarity, since it’s there anyway.
collexions
18 Jan 2010
Avoncliff Halt
Block markers removed from platforms 3&6 between scheme plan version 2.1 & 2.2 (current approved version 2.3). Misunderstanding as we're still instructed to 2.1! ;)
RichardGore
15 Jul 2018
Coulsdon
The drivers aren’t trained yet....
Sure, but they could be? Forgive me if I am wildly misunderstanding the situation but they must be trained eventually; now is as good a time as any, well in advance of the new timetable. It is not my impression that GTR has cash flow issues, and having all the drivers already trained and very well familiar with ETCS/ATO having operated with it for months to years by the time it becomes strictly necessary seems to me prudent.
I don’t know the current situation, but I expect that Thameslink still has plenty of driver trying to do for route knowledge, and that will take priority before the ATO training. Someone with better knowledge than I will en able to advise how long the ETCS conversion is, but I should imagine it is fairly substantial. With 800+ drivers to get through, that is a big ask of the trainers.
ATO is only a 2 day course I think, though. At one point there was a suggestion that the training would only be for ATO, ie drivers would not be trained for driving under ETCS without ATO. Not sure what the end result was.
FOH
17 Oct 2013
Interesting experience on a 700 this morning. Long hold at London Bridge. Once underway the driver announced apologies with a really informative announcement saying the train software had switched into the wrong mode which allows in cab signalling that is being introduced during the year but that he hadn't yet been trained in it so had to reset the system once at London Bridge, hence the delay.
I always assumed the switch to ATO was via a button but perhaps it can be automatic as well and the computer got ahead of itself.
Need2
15 Jun 2016
Or he forgot to (or notice it hadn't been done when he took over the train) 'inhibit' the ato system.
It’s sort of automatic. AIUI if a driver is driving a train with ATO active, it is triggered by a Balise (actually, two) on the approach to the core to contact the Block Centre. The driver has to either accept or inhibit the transition. If he/she does neither, then a quick reset is required.
jeff_44
7 May 2020
Driver training was due to commence but COVID-19 has delayed the process. Once SD measures allow, the drivers will be trained (conversion course is approx a week, 2 days classroom and PH over 2/3 days)
System is ready to go and is in use regularly now b by the limited trained staff, with services running in L2 and ATO every day.
